Dirt bikes don't count
- Has thanked: 10113 times
- Been thanked: 6649 times
- Has thanked: 6263 times
- Been thanked: 4614 times
Could be that for the clutch Hoss but I can't see a brake lever (there's something welded/brazed into the bar above the right hand but it doesn't look like a pivot) and they're discs...has there ever been a cable operated disc?Horse wrote: ↑Wed May 24, 2023 9:36 pmCould be as on many vintage bikes, where the lever pivots at the bar end and the cable runs through the bars.
From an engineering pov, your strongest fingers are at the end of the lever where they can have most effect.
- Been thanked: 2499 times
Some small Hondas in the 1980s had cable discs, upto 250cc maybe, certainly some of the 125s
- Has thanked: 5944 times
- Been thanked: 4926 times
RH side? Dunno, I gave up at that pointCount Steer wrote: ↑Thu May 25, 2023 6:24 amCould be that for the clutch Hoss but I can't see a brake lever (there's something welded/brazed into the bar above the right hand but it doesn't look like a pivot) and they're discs...has there ever been a cable operated disc?
Honda did a cable disc, CB200 IIRC
- Has thanked: 2609 times
- Been thanked: 6012 times
- Has thanked: 626 times
- Been thanked: 4063 times
- Has thanked: 2632 times
- Been thanked: 1498 times
Linked brakes, innit?Count Steer wrote: ↑Thu May 25, 2023 6:24 am Could be that for the clutch Hoss but I can't see a brake lever (there's something welded/brazed into the bar above the right hand but it doesn't look like a pivot) and they're discs...has there ever been a cable operated disc?
Presumably both operated by the foot. Wouldn't be legal in most countries, but hey, when has that ever bothered a custom bike designer?
Guessing bikes are required to have two independent circuits, just like cars?
In the Honda system and the like the two systems are still independent even though they use the same calliper, aren't they? A leak in one doesn't kill both?
I guess. I don't know how many custom designers have the technical knowledge to do a proper job of it though...unless Guzzis (I'm only assuming that's what it is/was) of an era with solid discs had it to start with? Then it wouldn't be too difficult.The Spin Doctor wrote: ↑Thu May 25, 2023 8:36 amLinked brakes, innit?Count Steer wrote: ↑Thu May 25, 2023 6:24 am Could be that for the clutch Hoss but I can't see a brake lever (there's something welded/brazed into the bar above the right hand but it doesn't look like a pivot) and they're discs...has there ever been a cable operated disc?
Front suspension doesn't make much sense to me either.
I've trawled Google but can't find it. The irritating thing is I think I've seen it before.
Starting to think it's AI!
On Guzzis with linked brakes, the handlebar lever did one front disc and the foot pedal did the other and the rear disc.
I'm not sure that's a requirementCount Steer wrote: ↑Thu May 25, 2023 8:55 am I don't know how many custom designers have the technical knowledge to do a proper job of it though...
True!Mr. Dazzle wrote: ↑Thu May 25, 2023 8:59 amI'm not sure that's a requirementCount Steer wrote: ↑Thu May 25, 2023 8:55 am I don't know how many custom designers have the technical knowledge to do a proper job of it though...
- Has thanked: 2000 times
- Been thanked: 1275 times
- Has thanked: 532 times
- Been thanked: 7217 times
I've seen plenty of the 500's, but never a 1100 like that, looks like it's a dct one too.
That leather bag is perfect for the beard trimming accessories
- ogri
- Has thanked: 1028 times
- Been thanked: 218 times
- gremlin
- Has thanked: 776 times
- Been thanked: 4514 times
And let's hope we never have to see one again....
- Has thanked: 15604 times
- Been thanked: 9848 times
I've never seen one and not keen to see one again, but out of interest, what is it?
