Inflation
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Re: Inflation
Post by Yambo »
gremlin wrote: Thu Sep 21, 2023 4:07 pm I reckon you and Mehmet Simsek should go out on the lash together. You've got a lot in common. :D
Turkey’s central bank hikes interest rate to 30%
https://www.cnbc.com/2023/09/21/turkeys ... rcent.html
Quite a few people locally are suggesting that both Şimşek and Hafize Erkan (the Central Bank Governor appointed by Recep in March) will both be toast after the local elections next year. They think that if the Lira is stabilised and maybe starts to recover against the dollar it'll be enough to get the AKP elected/re-elected in a lot of areas and once that is done they'll both be sacked and he'll appoint people to do things his way.
Not a good time to be a Türk. Not too bad if your income is sourced from elsewhere.
irie
Has thanked: 1482 times
Been thanked: 411 times
Re: Inflation
Post by irie »
Potter wrote: Thu Sep 21, 2023 4:40 pm
irie wrote: Thu Sep 21, 2023 3:54 pm
Potter wrote: Thu Sep 21, 2023 1:47 pm
Even if I could get through to them on the phone they are not capable of understanding, if they were then the UK wouldn't be in such a shocking fiscal mess.
"Fiscal" means government revenue/taxes. :lol:
Oh come on, don't make me continually have to explain everything to you.
Do you think that the current fiscal mess is entirely separate to the monetary policy mess and that this move wasn't politically motivated?
I don't know why you comment when you've never been able to keep up with the conversation since the thread started years ago.
Yeah, nobody knows as much as you, do they? Despite previously dissing it you've obviously been on Google genning up on monetary theory! :lol:
Has thanked: 6375 times
Been thanked: 4746 times
Re: Inflation
Yambo wrote: Thu Sep 21, 2023 5:45 pm
Sums it up. You can bugger up an economy as much as you like as long as you do enough in time to get re-elected then you can bugger it up all over again until just before the next one*. Ah, 'democracy', ain't it marvellous?
* But make sure you, your family and friends profit as much as possible from it each time.
MyLittleStudPony
Has thanked: 614 times
Been thanked: 405 times
Re: Inflation
Post by MyLittleStudPony »
Where now?
I was thinking of putting everything into a structured note which looks a bit like a bond. But I haven't really bothered reading the small print.
irie
Re: Inflation
Post by irie »
At the same time as money velocity has dropped like a stone the Bank of England is still keeping interest rates high apparently to reduce current inflation in spite of the well known lag between interest rate changes and their effect on the economy. The BoE continuing this policy at the same time as the UK is entering a recession is a recipe for deflation ...
Has thanked: 5449 times
Been thanked: 13084 times
Re: Inflation
irie wrote: Tue Feb 20, 2024 9:10 am At the same time as money velocity has dropped like a stone the Bank of England is still keeping interest rates high apparently to reduce current inflation in spite of the well known lag between interest rate changes and their effect on the economy. The BoE continuing this policy at the same time as the UK is entering a recession is a recipe for deflation ...
Do you have a solution you'd prefer ? Or at the least, an opinion ?
irie
Re: Inflation
Post by irie »
weeksy wrote: Tue Feb 20, 2024 9:37 am
Immediately reduce interest rates.
Re: Inflation
Given the time and the inclination I could probably build a case that suggests a bout of deflation might be good medicine after the recent atypical inflation. After a bout of high inflation reduced prices may not lead to reduced spending but increased consumption. The main issue with deflation usually is prices drop and so does spending/consumption so manufacturers cut production and the economy spirals downwards.
In the current scenario a lot of people would go back to buying what they did before without spending more money.
Unfortunately, a lot of that is stuff in the supermarket that has been imported. (Or indeed stuff on Amazon etc that's been imported). Then again, when money is tight people buy cheaper stuff anyway and the UK doesn't produce cheap stuff.
irie
Re: Inflation
Post by irie »
Count Steer wrote: Wed Feb 21, 2024 12:36 pm Given the time and the inclination I could probably build a case that suggests a bout of deflation might be good medicine after the recent atypical inflation. After a bout of high inflation reduced prices may not lead to reduced spending but increased consumption. The main issue with deflation usually is prices drop and so does spending/consumption so manufacturers cut production and the economy spirals downwards.
The main risk with deflation is that purchases will be put off in the expectation that prices will drop, thus creating a deflationary doom loop. I can not see how that would be "good medicine".
Re: Inflation
irie wrote: Wed Feb 21, 2024 2:17 pm
Most people don't defer buying food and fuel. Yes, there's a risk but deflation is usually seen as a bad thing as part of the typical economic cycle. The last few years have not exactly been typical. Locking in abnormal bounces in inflation has risks too (wage inflation etc which don't get reduced when/if things settle down again). Reducing inflation doesn't reverse it, a bout of deflation might take some of it out.
Yes, I realise it's economic heresy - deflation is bad, growth is good but excessive inflation is bad etc.
Abnormal times and all that.
irie
Re: Inflation
Post by irie »
Count Steer wrote: Wed Feb 21, 2024 4:03 pm
Just for starters, deflation is absolutely not part of a "typical economic cycle"!
As for "Locking in abnormal bounces in inflation" and "Reducing inflation doesn't reverse it [inflation], a bout of deflation might take some of it [inflation] out", one can only :lol:
Re: Inflation
irie wrote: Thu Feb 22, 2024 8:10 pm
Try reading what I wrote, slowly, with your fingers under the words, move your lips if it helps.
Has thanked: 2402 times
Been thanked: 3625 times
Re: Inflation
irie sees things the rest of us don't. Or differently. Or both.
Has thanked: 2549 times
Been thanked: 2285 times
Re: Inflation
Inflation = all prices rise, money loses value.
Deflation = all prices fall, money gains value.
You can see why all Govts, who have HUGE debts, like nice gentle inflation. I quite fancy some deflation myself.
Re: Inflation
Yeah, I wasn't trying to rewrite economic theory. Just thinking eg food prices have soared (something like 31% since Dec 3021). People therefore buy less, buy cheaper and/or demand more £ and/or need more taxpayer support. If prices came down, (deflated) rather than locking the increases in it could be beneficial.
I know deflation isn't a natural part of the 'normal economic cycle' but that's not what I said. However, China is experiencing a second bout in 2 years due to declining domestic demand and falling property prices, so it's not exactly a once in a blue moon phenomenon. I've lived through it too here in the UK.
Maybe it wouldn't be the end of the world if house prices dropped too but for the cosmetics, of it we'll call it a 'correction'. :D
irie
Re: Inflation
Post by irie »
irie wrote: Tue Feb 20, 2024 9:43 am
In spite of inflation dropping like a stone the Bank of England has kept base rate unchanged at 5.25% :roll:
Whereas by contrast the Swiss Central Bank has reduced rates, at least they're not behind the curve!
Has thanked: 808 times
Been thanked: 4793 times
Re: Inflation
irie wrote: Thu Mar 21, 2024 12:06 pm
You're comparing apples and pears.
Swiss inflation was 1.2%, within their 0-2% band. UK inflation is still above the 2% target the UK Govt sets for the BoE.
Conversely, both Taiwan and Turkey raised their rates recently, but there you go. Different gravy, innit.
irie
Re: Inflation
Post by irie »
gremlin wrote: Thu Mar 21, 2024 1:52 pm
It is the trajectory of the inflation curves that matter.
Edit: In both Taiwan and Turkey the rate of inflation is increasing so yeah, different gravy.
Re: Inflation
Lol I love how you seem to know better than everyone else on the planet.
irie
Re: Inflation
Post by irie »
weeksy wrote: Thu Mar 21, 2024 3:36 pm Lol I love how you seem to know better than everyone else on the planet.
I'm not even small fry, I'm nobody, but I am saying the same thing as many prominent economists.
