- rodbargee
- Has thanked: 398 times
- Been thanked: 1116 times
- Contact:
- Been thanked: 2737 times
So much so it's enough to make your head spin.David wrote: Sun Mar 19, 2023 8:04 am There is a world of difference betwixt a rotary and a radial......
- rodbargee
- Contact:
- Has thanked: 628 times
- Been thanked: 9522 times
Alan Millyard's Flying Millyard has an engine made from two barrels and pistons from a Pratt and Whitney radial aero engine. It's 5l, the pistons are huge!!
- Has thanked: 222 times
- Been thanked: 789 times
- Been thanked: 14207 times
A 545 Kawaski 2 stroke four. £30k to you sir.
https://www.ebay.co.uk/itm/266104962020 ... R4Dq2P_fYQ
- Has thanked: 12650 times
- Been thanked: 8557 times
Offering a test ride when it's not run in yet?Skub wrote: Mon Mar 20, 2023 5:10 pm A 545 Kawaski 2 stroke four. £30k to you sir.![]()
- Has thanked: 602 times
- Been thanked: 4529 times
Early rotaries,like Sopwith Camels, have the crank stationary and the cylinders spin, but someone worked out this was stupid, and on most rotary engines the crank spins and the cylinders are stationary.
That's the difference between a rotary and a radial engine, the cylinder layout is the same.Le_Fromage_Grande wrote: Mon Mar 20, 2023 8:22 pmEarly rotaries,like Sopwith Camels, have the crank stationary and the cylinders spin, but someone worked out this was stupid, and on most rotary engines the crank spins and the cylinders are stationary.
Pfft, all engines hold on to the crank and spin the entire universe around, everyone knows that.
- Has thanked: 246 times
- Been thanked: 1233 times
- Contact:
It wasn’t stupid at the time. The rotary had a high power to weight ratio (compared to other contemporary engines) and didn’t vibrate the airframe to bits.Le_Fromage_Grande wrote: Mon Mar 20, 2023 8:22 pmEarly rotaries,like Sopwith Camels, have the crank stationary and the cylinders spin, but someone worked out this was stupid
It was overtaken by developments in radial, inline and V-configuration engines.
- rodbargee
- Contact:
- Has thanked: 2322 times
- Been thanked: 1827 times
2 rear shocks so close to the pivot point!! That's gotta be a hard ride !
