Page 16 of 35
Re: Are vans better offroad than cars ?
Posted: Fri Jun 10, 2022 6:26 pm
by Couchy
Mussels wrote: Fri Jun 10, 2022 4:54 pm
Couchy wrote: Fri Jun 10, 2022 2:20 pm
weeksy wrote: Fri Jun 10, 2022 1:17 pm
Elgrand to North Wales this weekend would be £330!
Mine did 25mpg on a run last weekend, but you could sleep in it and carry all your stuff easily and hopefully less repairs than the QQ
Working it out at 25mpg it’ll cost you £170, it’ll cost you £95 in QQ so only £75 more
Is that like my Jeep was, 25mpg at 56mph slipstreaming behind an arctic?
Nope just driving carefully with traffic, 50mph road most of the way
Posted: Fri Jun 10, 2022 6:54 pm
by cheb
25mpg at 50mph? What's it do if you press the throttle down?
Posted: Fri Jun 10, 2022 7:05 pm
by weeksy
cheb wrote: Fri Jun 10, 2022 6:54 pm
8
Posted: Fri Jun 10, 2022 7:17 pm
by cheb
I had a classic Range Rover that did about that, it had a V8 and it wasn't a huge mumbus.
Posted: Fri Jun 10, 2022 7:39 pm
by Felix
I know the Qashqai is no oil painting but a Elgrand
Must find the picture. Some bloke put an Elgrand front end on a Convoy to try and cheer it up. Think he managed to turn an ugly pig into an ugly pig.
Posted: Fri Jun 10, 2022 7:43 pm
by weeksy
Felix wrote: Fri Jun 10, 2022 7:39 pm
Elgrands are awesome
Posted: Fri Jun 10, 2022 8:12 pm
by Felix
weeksy wrote: Fri Jun 10, 2022 7:43 pm
Its the lights i hate. It just reminds me of looking at this
Posted: Fri Jun 10, 2022 8:38 pm
by demographic
Felix wrote: Fri Jun 10, 2022 8:12 pm
That pic reminds me of one of daughters mates who did this.
All done with makeup though.
Posted: Fri Jun 10, 2022 8:50 pm
by Felix
Could you imagine her in a pub after a few beers. Folk would be puking up all over the shop. Quite smart though
Posted: Fri Jun 10, 2022 9:27 pm
by Mussels
weeksy wrote: Fri Jun 10, 2022 7:05 pm
8
That's what I got driving slowly round town, the mpg display would show 1 if I was going fairly quickly up a long hill.
It was fine when I lived inside the M25 and everything was close by, when I moved out into the sticks £100 a week on petrol got boring quickly.
Posted: Fri Jun 10, 2022 9:38 pm
by Felix
Different. Thin the latter oned get more rounded outer edge lamps what dont look as bad
Posted: Fri Jun 10, 2022 9:42 pm
by demographic
Felix wrote: Fri Jun 10, 2022 8:50 pm
She's fairly easy on the eyes normally mind.
Posted: Fri Jun 10, 2022 9:44 pm
Which ones?
Posted: Fri Jun 10, 2022 9:55 pm
by demographic
Mr. Dazzle wrote: Fri Jun 10, 2022 9:44 pm
Which ones?
MIne.
Posted: Tue Jun 14, 2022 10:22 am
by weeksy
Ah FFS and fiddlesticks... lol.
You recall (or not) i bought a new battery for this 6 months back.. It seems to be fooked.
I've had a couple of instances where it seems to take a bit more time on starting, instead of first crank it's 4-5 revolutions.
Just checked this morning and when cold i've got 12.22v on it. Running it's showing 14.5v. Which i'm happy with... but overnight it's dropping too much IMO. Well, clearly it's too low.
I bought it via RAC and had it installed by them, so i'm now trying to get someone useful from there, they've logged it as a breakdown, which isn't really what i was after, esepcially as i'm no longer a member. I'm simply trying to get it done as a warranty... lets see how this goes
Posted: Tue Jun 14, 2022 10:28 am
Have you got a obd scanner and app such as Torque? They can log a fault code if the charging system is dropping voltage during running time. Worth a look as charging faults can be intermittent and not always show with a DVM across the terminals.
Posted: Tue Jun 14, 2022 10:29 am
So cold this morning, 12.22v.
What's wrong with that?
Is it cranking slow, or is it just taking 'more' cranks to start it?
If it's taking more cranks, it's more likely to be a fuel leaking back from the injectors (it is a dirty derv, innit?)
Posted: Tue Jun 14, 2022 10:34 am
Mate had starting problems with his Picasso and it turned out to be a fuel filter. Despite the s/history saying it had been done, it certainly hadn't. The Mechanic told him a HDi should turn over once and fire up, if it doesn't there's a reason for it and often it's fuel and often it's because of the fuel filter. Never given it much thought until he said that and now it's something I'll make sure is changed on any diesel I own.
Posted: Tue Jun 14, 2022 10:35 am
by Numnut
The alternator on my qashqai decided to die about 90k miles...Thing is, it would sometimes work and sometimes not, so it seemed like a dud battery when it was actually fine.
Posted: Tue Jun 14, 2022 10:38 am
by weeksy
Taipan wrote: Tue Jun 14, 2022 10:34 am
Same issue as when i had the other battery replaced, it then started instantly, for months....
I suspect it's the battery.
After being run it's then an instant start, it's only the cold start.
