- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
Here's a pic of the other side - so some kind of training aid although I'm not entirely sure exactly how this worked.
- Has thanked: 4089 times
- Been thanked: 2516 times
According to Google translate,the photo is of the world hour record & his trainers
- Has thanked: 11041 times
- Been thanked: 4071 times
yeah - it's an aero-pace bike - the guy at the back sitting up creates a vortex which pulls the cyclist along.ChrisW wrote: Thu Jan 26, 2023 5:01 pm Here's a pic of the other side - so some kind of training aid although I'm not entirely sure exactly how this worked.
Nice to have a different pic from obviously the same day! (same jumpers!
Incidentally - the current bicycle speed record was done in virtually the same way - but with a dragster equipped with bodywork the size of a barn door!
- ChrisW
Huh! So the 'wheelie bar' is presumably a roller that the bike's front wheel can bump up against.Rockburner wrote: Thu Jan 26, 2023 5:25 pmyeah - it's an aero-pace bike - the guy at the back sitting up creates a vortex which pulls the cyclist along.ChrisW wrote: Thu Jan 26, 2023 5:01 pm Here's a pic of the other side - so some kind of training aid although I'm not entirely sure exactly how this worked.
Nice to have a different pic from obviously the same day! (same jumpers!)
- G.P
- Has thanked: 1994 times
- Been thanked: 1283 times
I still Like it though.Le_Fromage_Grande wrote: Mon Jan 23, 2023 2:15 pmIt doesn't run, it did pre turbo, but as far as I know it hasn't run since the current owner put the turbo on, it's now a show pony.
- Has thanked: 8076 times
- Been thanked: 5732 times
More info: https://motorcyclemojo.com/2022/05/motor-paced-cycling/ChrisW wrote: Thu Jan 26, 2023 5:01 pm Here's a pic of the other side - so some kind of training aid although I'm not entirely sure exactly how this worked.
Or just a bar, won't necessarily be a roller.ChrisW wrote: Thu Jan 26, 2023 5:32 pmHuh! So the 'wheelie bar' is presumably a roller that the bike's front wheel can bump up against.Rockburner wrote: Thu Jan 26, 2023 5:25 pmyeah - it's an aero-pace bike - the guy at the back sitting up creates a vortex which pulls the cyclist along.ChrisW wrote: Thu Jan 26, 2023 5:01 pm Here's a pic of the other side - so some kind of training aid although I'm not entirely sure exactly how this worked.
'The bicycles had small front wheels in order to ride as close as possible to the pace bike, and the pace bike was often equipped with a small roller just aft of the rear wheel to avoid disaster should the cyclist make contact with the pace bike. Despite this safety feature, many pacers and cyclists got killed in crashes due to the high speeds and lack of protection.'Rockburner wrote: Thu Jan 26, 2023 7:17 pmOr just a bar, won't necessarily be a roller.ChrisW wrote: Thu Jan 26, 2023 5:32 pmHuh! So the 'wheelie bar' is presumably a roller that the bike's front wheel can bump up against.Rockburner wrote: Thu Jan 26, 2023 5:25 pm
You were spot on about the different sized pulleys giving different gearing RB.
(There were no brakes and no exhaust either
- Has thanked: 602 times
- Been thanked: 4529 times
I'd happily have one, I've got the engine already, but the frame cost more than my whole Suzuki did.G.P wrote: Thu Jan 26, 2023 6:17 pmI still Like it though.Le_Fromage_Grande wrote: Mon Jan 23, 2023 2:15 pmIt doesn't run, it did pre turbo, but as far as I know it hasn't run since the current owner put the turbo on, it's now a show pony.![]()
Seen it before on Veteran bikes. If you're touring Europe it helps to have a different final ratio when you reach the Alps!Count Steer wrote: Fri Jan 27, 2023 10:15 amYou were spot on about the different sized pulleys giving different gearing RB.![]()
(There were no brakes and no exhaust either).
Before Deraileurs were invented cyclists used to have a different sized sprocket on the drive side / non drive side.To change the gearing they'd take out the rear wheel & fit it back with the non drive side sprocket now becoming the drive sprocket.
A Belgian bike! One careful owner, 52km on the clock, suitable for UK roads....and a small family.
Built in a 'mountainous area'...of Belgium.
- Has thanked: 2314 times
- Been thanked: 2708 times
The guy I bought my house from years ago built a turbo Gixer1100 quad for Sand Drag's. I found the original 500 stroker engine buried in the back yard.
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Didn't help 'em much in 1940!Count Steer wrote: Fri Jan 27, 2023 3:59 pm A Belgian bike! One careful owner, 52km on the clock, suitable for UK roads....and a small family.Built in a 'mountainous area'...of Belgium.
Our local spiffy bike shop is converting a Honda RC213V-S for road use... Probably won't be tempting that to play on Mulholland... They had one before & sold it for $265,000
Aren't they already road legal? The 'S' is for 'Street' I assumed. I.e. differentiated from the RC213V prototype racer.
They've got lights and plates from Honda AFAIK. But they did come with an "optional" track pack, the box for which was surely ticked by 100% of buyers?
- Has thanked: 628 times
- Been thanked: 9522 times
It took me a while to work out what the base bike was!
- 327592663_741521854157012_2492998613845887184_n.jpg (108.8 KiB) Viewed 839 times
- Been thanked: 14207 times
Tonka Toy.
