Guy I knew had a curved springy piece of metal bolted on the bars of his bike, as an artificial wrist He used it to hold a watch with metal 'elasticated' bracelet.Mr. Dazzle wrote: ↑Fri Jan 01, 2021 9:20 am I've also been looking for a watch I can wear on the outside of my leathers. None of my bikes have a clock and for some reason that's something I really miss!
The Official Watch Thread.
- Has thanked: 6195 times
- Been thanked: 5088 times
- Has thanked: 1346 times
- Been thanked: 1722 times
I used to just have a watch minus strap velcro'd to the headstock of my bike using that peel off sticky sided velcro.Horse wrote: ↑Fri Jan 01, 2021 9:02 pmGuy I knew had a curved springy piece of metal bolted on the bars of his bike, as an artificial wrist He used it to hold a watch with metal 'elasticated' bracelet.Mr. Dazzle wrote: ↑Fri Jan 01, 2021 9:20 am I've also been looking for a watch I can wear on the outside of my leathers. None of my bikes have a clock and for some reason that's something I really miss!
Just a cheap analogue face Timex or Casio but it was that cheap it wasn't worth nicking.
- Been thanked: 2618 times
Mr. Dazzle wrote: ↑Fri Jan 01, 2021 9:20 am SKXs are tantalisingly cheap aren't they?
At those sort of prices I wouldn't mind exposing one to the outside world at high speed.
Is that not a justification for buying the Rolex with the really long strap designed to be worn outside one's spacesuit?
- Has thanked: 2551 times
- Been thanked: 6249 times
Omega actually.
Already got one of those, complete with the strap. It does two laps of my wrist.
- G.P
- Has thanked: 2029 times
- Been thanked: 1310 times
Just put a watch around the bars or on the dash so (a) you can see it easily and (b) its as not exposed to the elements. IanB of this parish used to have a fake Bell & Ross on his Ducati supersport. It was a white faced model to match the instruments on the DucatiMr. Dazzle wrote: ↑Fri Jan 01, 2021 9:20 am SKXs are tantalisingly cheap aren't they?
- Yambo
- Has thanked: 598 times
- Been thanked: 1647 times
- Has thanked: 1264 times
- Been thanked: 1188 times
Wasn't something posted on the TRC watch thread about concern over a watch being damaged when being worn on a bike, possibly even with the manufacturer showing a rider in their advertising?
High frequency vibrations are quite different to what you experience on a wrist aren't they? You also get quote a lot of isolation from being on a wrist vs. being adhered to a hard surface.
I bet you could ride with a quartz digital for 100 years and not have a problem, but gluing it to a buzzy engine might crack solder etc. in no time.
Kinda begs the question, how do they factory fit clocks and electronics doesn't it? "Not always successfully" would be my answer.
Cheapo Timex* for the win.Mr. Dazzle wrote: ↑Sun Jan 03, 2021 8:49 am High frequency vibrations are quite different to what you experience on a wrist aren't they? You also get quote a lot of isolation from being on a wrist vs. being adhered to a hard surface.
*Yes, I remembered what it was. Timex Indiglo thing. Analogue face and it spent maybe a year on the bike when I used it to go to and from work. I guess its possible the velcro helped dampen it down slightly but realistically who cares, it cost about 20 quid and lasted about a year on the bike.
Never did big miles doing that, maybe 5000 in a year.
After that sometimes in my back pocket cos I can't stand watchstraps and I bought a van.
I was given a bike clock, simple digital display, that clipped into a holder bolted onto the handlebars. That would have been on an older BMW twin. No problems. As D says, bikes are full of electronics, etc.
Vehicle electronics have quite in depth shock/vibration requirements....or at least, the proper OEM stuff does. Quite a lot of attention is paid to the effects of vibration etc. It's standard practice to put stuff on shaker tables for extended periods.
I was gonna say "watches probably don't" but in fact I would guess they do. It will just be a different set of inputs.
Many mechanical watches have some shock protection for stuff like the jewelled bearings.Mr. Dazzle wrote: ↑Sun Jan 03, 2021 9:47 am Vehicle electronics have quite in depth shock/vibration requirements....or at least, the proper OEM stuff does. Quite a lot of attention is paid to the effects of vibration etc. It's standard practice to put stuff on shaker tables for extended periods.
Think some versions call it Incabloc but I doubt it's aimed at high frequency vibration like bike engines.
Heres a brief summary of what NASA did back in the 60s when looking for mechanical watches to use in space.
https://www.bobswatches.com/rolex-blog/ ... -nasa.html
....linear acceleration test (taking the watch from 1 to 7.25 g within 333 seconds), a vibration test (3 × 30 minute vibration between 5 and 2000 Hz with a minimum of 8.8 g impulse), and an acoustic noise test which blasted the watch with 130 dB from 40 to 10,000 Hz for 30 minutes....
True.
Back the you were allowed to fire a Chimpanzee up there first though.
- Has thanked: 7817 times
- Been thanked: 2529 times
Would probably depend on the watch. My TAG 844 has been on my wrist for years (and lots of miles), it's only since I stupidly let a "local" jeweller poke around inside that its started playing up.Harry wrote: ↑Sun Jan 03, 2021 7:40 amIt was Zebby with his IWC that cost about the same as a terraced house in the north of England.
They said the vibrations from his bike might have buggered it. If you think about it, a mechanical watch is a delicate bit of kit.
But my pop swatch was digital and it knackered it fairly quickly, a few weeks of daily use IIRC.
- Has thanked: 566 times
- Been thanked: 755 times
Once or twice I've needed to carry a few £1000s. It always made me nervous and I was glad to get where I was going and get rid of it. I can't imagine choosing to wear that sort of money on my wrist. I'd be a nervous wreck.Harry wrote: ↑Fri Jan 01, 2021 4:57 am...
I haven't been wearing a watch much but yesterday I had to attend something and I put one on because I felt like it. I hadn't worn one for ages and I was very conscious that I was wearing something expensive, that particular one has gone up several grand in the time I've owned it ...
The key is to be a nervous wreck all the time, regardless of your watch.
- Has thanked: 10266 times
- Been thanked: 6886 times
A pal here has several expensive watches. He never wore them coz the looky looky men sold perfect replicas for 20€.
His wife died a few months ago and now he's given them to his daughter in UK to sell for him.
He reckons about £60k which will allow him to fund a move to a better house.
- wheelnut
- Has thanked: 907 times
- Been thanked: 1001 times
I think most wearers of decent auto (or mechanical) watches are careful with shocks. I wouldn’t start hammering stuff wearing mine for instance, on the watch forums some don’t wear them when they’re golfing.Harry wrote: ↑Sun Jan 03, 2021 7:40 am It was Zebby with his IWC that cost about the same as a terraced house in the north of England.
