Appears to be twin cow horn things - not attached to a central steering stem like regular bars.Count Steer wrote: Wed May 25, 2022 7:51 pmIt doesn't appear to have any steering....given the ground clearance, that's probably wise.v8-powered wrote: Wed May 25, 2022 6:50 pm image_0d7a8a82-34b2-4792-9766-4e691480fd9620220525_184849.jpg![]()
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
- Has thanked: 2318 times
- Been thanked: 1824 times
It's possibly on air bags..... but it isn't going round corners on those tyresCount Steer wrote: Wed May 25, 2022 7:51 pmIt doesn't appear to have any steering....given the ground clearance, that's probably wise.v8-powered wrote: Wed May 25, 2022 6:50 pm image_0d7a8a82-34b2-4792-9766-4e691480fd9620220525_184849.jpg![]()
- Been thanked: 9505 times
- Has thanked: 8048 times
- Been thanked: 5699 times
The suspension is adjustable to compensate for the weight of the rider.
- Has thanked: 245 times
- Been thanked: 1228 times
- Contact:
It’s so cool the block in the blazer/cardigan ensemble has to play with his willy while he looks at it.
And why stop there!
Traditional French housewife setting off home with the fresh loaf:
The things she does to make them eat the heel!
And why stop there!
- Has thanked: 1080 times
- Been thanked: 1010 times
They've gone to a lot of effort, I wonder why they didn't go for a full tank cover?
- Has thanked: 12620 times
- Been thanked: 8541 times
Me and my enduro pals are just discussing this. If it was on this island one of us would have bought it.
But we're not sure how good an auto box is on an enduro bike ???
- Been thanked: 14171 times
Eccentric adjuster on left side and conventional on the right. That's odd. (ha)
- Has thanked: 2852 times
- Been thanked: 1611 times
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
Husky had a lot of success with autos in the eighties. Can't remember the name of the guy that rode for them but I;m sure they won championships. Larry Roesler maybe...?Yorick wrote: Sat Jun 04, 2022 4:22 pm Me and my enduro pals are just discussing this. If it was on this island one of us would have bought it.
I think the advert is misleading. Can't find any auto Huskies. He probably has the auto clutch thingyChrisW wrote: Sun Jun 05, 2022 5:02 pmHusky had a lot of success with autos in the eighties. Can't remember the name of the guy that rode for them but I;m sure they won championships. Larry Roesler maybe...?Yorick wrote: Sat Jun 04, 2022 4:22 pm Me and my enduro pals are just discussing this. If it was on this island one of us would have bought it.
Rekluse are great, especially in tight technical going. Take a bit of getting used to but once you 'get them' they make life so much easier.
The clutch cover is worth it on its own. A lot stronger than standard and increases the oil capacity.
Do you lose engine braking ?crust wrote: Sun Jun 05, 2022 6:17 pm Rekluse are great, especially in tight technical going. Take a bit of getting used to but once you 'get them' they make life so much easier.
IIRC it's centrifugal, the clutch only activates when the revs drop to tick over. So you should still get engine braking... until the revs drop.
Cool. I'm having trouble with left hand and fingers, but ATM it's good exercise. But maybe in future.KungFooBob wrote: Sun Jun 05, 2022 6:19 pm IIRC it's centrifugal, the clutch only activates when the revs drop to tick over. So you should still get engine braking... until the revs drop.
Thats the bit that takes some getting used to. As long as the revs are up, then no you don't lose engine braking, however if you let the revs drop then the clutch disengages which is fun on really steep descents as the bike takes off, only requires a blip of throttle then it re-engages and you've got engine braking. Once you get used to it it's not an issue.Yorick wrote: Sun Jun 05, 2022 6:18 pmDo you lose engine braking ?crust wrote: Sun Jun 05, 2022 6:17 pm Rekluse are great, especially in tight technical going. Take a bit of getting used to but once you 'get them' they make life so much easier.
They really come into their own on rocky bits as you just don't bother with the clutch, like riding a twist and go scooter.
The clutch is still there if you want to use it like a normal one, even now I use the lever for pulling away on the road, force of habit.
Pop over and I'll show you some terrain you've never riddencrust wrote: Sun Jun 05, 2022 6:26 pmThats the bit that takes some getting used to. As long as the revs are up, then no you don't lose engine braking, however if you let the revs drop then the clutch disengages which is fun on really steep descents as the bike takes off, only requires a blip of throttle then it re-engages and you've got engine braking. Once you get used to it it's not an issue.Yorick wrote: Sun Jun 05, 2022 6:18 pmDo you lose engine braking ?crust wrote: Sun Jun 05, 2022 6:17 pm Rekluse are great, especially in tight technical going. Take a bit of getting used to but once you 'get them' they make life so much easier.
