Find me a van then...
- Has thanked: 10117 times
- Been thanked: 6649 times
- Has thanked: 5503 times
- Been thanked: 12760 times
- G.P
- Has thanked: 2113 times
- Been thanked: 1310 times
Re: Find me a van then...
I think I'd need a 2nd mortgage.G.P wrote: ↑Sun Dec 18, 2022 11:26 am These guys will come to your house and rack it to your spec.
https://comm-ply.co.uk/our-services/
The reality is, at the moment I don't really know what we want or where we want it. It's all guesswork right now until we get used to things and how they all play out.
@Welsh Muffin drove it today. Whilst it wasn't a love affair, she hated it less than expected lol.
Security installed today on the van... Happy
OK so you can still open it with a can opener but it's as secure as a van gets
I do have the Question now of the Pragmasis ground anchor. It has a van fitting kit with break away bolts... but it does mean of course drilling 4 holes in the van floor (correctly and not damaging anything underneath lol
What's the forum thoughts on a ground anchor in a van ? somewhat silly ? excessive ? or "yeah go for it".
I do have the option of returning it.
- Has thanked: 6263 times
- Been thanked: 4614 times
I wouldn't drill holes in a newish van floor, personally. a) not a great thing to do to the corrosion protection and b) what do you do when you sell it, leave 4 holes in the floor or just stick bolts in the holes? It wouldn't help sell it to me.weeksy wrote: ↑Tue Dec 20, 2022 8:46 am I do have the Question now of the Pragmasis ground anchor. It has a van fitting kit with break away bolts... but it does mean of course drilling 4 holes in the van floor (correctly and not damaging anything underneath lol
Edit: I assume that, given the job it does, it won't be easy to remove....
- Has thanked: 532 times
- Been thanked: 7236 times
I wouldn't be concerned about drilling holes in the van floor, most ply kits just self tap into the floor so lots of vans have loads of little holes (and you could just fill them with grommets if it was removed.
I'd be more worried about how easy it would be to just pull out, it's surprisingly thin the floor metal, unless it bolts to a chassis rail?
I suppose it is what people do with vans and I have a car mindset. I definitely wouldn't be taking a drill to a car floor, double skinned or not. Floor panel corrosion is probably not why most vans reach the end of the road either. I had to have a plate welded into the footwell in mine when it corroded. But that was mainly because it used to fill up with water when it rained.
I'd be fitting it to the partition.
Ok, you'd need a longer chain but no holes in the floor, you can see where the holes are going to come out and no-ones going to complain about holes in the lower part of the partition or just leave it there as a selling point.
Not sure there's a long enough chain in the world lol. It'd need to be about 7' long....crust wrote: ↑Tue Dec 20, 2022 9:55 am I'd be fitting it to the partition.
How big are the wheels now? You running 129" wheels? From floor to frame is not much more than radius of wheel, from back of wheel to rear of chain stays is not much more than radius of wheel. Chain will be roughly same length whether it goes up and over or out and through.weeksy wrote: ↑Tue Dec 20, 2022 10:05 amNot sure there's a long enough chain in the world lol. It'd need to be about 7' long....crust wrote: ↑Tue Dec 20, 2022 9:55 am I'd be fitting it to the partition.
- Has thanked: 2611 times
- Been thanked: 6015 times
Feels like holes in the floor would help with that.Count Steer wrote: ↑Tue Dec 20, 2022 9:21 am But that was mainly because it used to fill up with water when it rained.
- Potter
- Has thanked: 2216 times
- Been thanked: 4612 times
Are you likely to leave the bikes in the van for long enough unattended to warrant the faffing about with anchors and things?
I've never done that and my assumption would be that if someone is sufficiently tooled up to get into the van then they're probably going to quickly defeat any sort of bolt down device.
I'd maybe put a plate on the bulkhead with a loop (like a ground anchor I suppose but on the vertical sheet bulkhead) and then use a cable type lock to secure the bikes, it wouldn't stop a proper thief but it might stop a smackhead chancer if he did manage to get into the back.
I took the rubber grommets out so it drained. I used to get in on wet mornings and have to roll my flares up.Mr. Dazzle wrote: ↑Tue Dec 20, 2022 10:21 amFeels like holes in the floor would help with that.Count Steer wrote: ↑Tue Dec 20, 2022 9:21 am But that was mainly because it used to fill up with water when it rained.
(It was the windscreen that leaked, it then ran down into the footwell).
- Has thanked: 353 times
- Been thanked: 2168 times
Yup fit it to the bulkhead, or don't tbh and just drill a couple of holes in the bulkhead a metre or so apart and get a long loop of steel wire and a padlock and run through all the frames/wheels. It'll be enough to stop most people, anyone that can defeat that is gonna take them anywaycrust wrote: ↑Tue Dec 20, 2022 9:55 am I'd be fitting it to the partition.
- Potter
Or get one of those devil dogs from the video and keep that in the back and keep it hungry
At some point you've got to hold your hands up and leave it to chance though, if someone wants it badly enough to get past what you've done so far then even if you catch them in the act they're probably just as happy to hold you at bay with a hammer whilst they take an extra minute to get through another chain.
- Pirahna
- Has thanked: 1773 times
- Been thanked: 1109 times
The tie down points are pretty solid but not very big. I padlock a chain to the tie down point, run out through the bikes then a padlock at the other end. There's only so much you can do.
- Has thanked: 15607 times
- Been thanked: 9850 times
- dern
- Has thanked: 1003 times
- Been thanked: 1722 times
Did you get someone else to do it? That's my job on Friday to install the locks on mine.
