Tool purchases
Has thanked: 711 times
Been thanked: 2014 times
Re: Tool purchases
How loud is that pump and max PSI? I have a small 12v compressor pump that does up to 150PSI and it dont half make a racket. I use it for my camperbus suspension and can be quite noise when at camp sites if i need to leave early.
Has thanked: 12556 times
Been thanked: 8519 times
Re: Tool purchases
Felix wrote: Tue Feb 08, 2022 7:49 pm How loud is that pump and max PSI? I have a small 12v compressor pump that does up to 150PSI and it dont half make a racket. I use it for my camperbus suspension and can be quite noise when at camp sites if i need to leave early.
It's fairly quiet. A bit on the slow side, but who's in a rush ?
Re: Tool purchases
Yorick wrote: Tue Feb 08, 2022 7:52 pm
The bus is only two small air bags say about 6lt and only need 65PSI so would probably do the job. Just my 12v thing apart from noise is a faff getting it out the box, unrolling the long cable to reach the 12v outlet, do the deed then same in reverse so aye, I may put one of these in my must buy list
Re: Tool purchases
Felix wrote: Tue Feb 08, 2022 7:56 pm
https://www.ebay.co.uk/itm/233522147368
Re: Tool purchases
Ach what did you show me that for. I was going to wait till later in the year but had to order it at that price :D
Bit less power at 120PSI than my noisy pump but it also says 12lt per minute so thats a lot faster than what i have also.
Re: Tool purchases
Yorick wrote: Tue Feb 08, 2022 8:16 pm https://www.ebay.co.uk/itm/233522147368
I looked at that a while ago,it seems like a good deal and a big discount.
Oddly the cordless thing bothers me a little,I'd prefer a plug in jobbie.
Re: Tool purchases
Skub wrote: Tue Feb 08, 2022 9:26 pm
CBA with fetching cables anymore.
Re: Tool purchases
Yorick wrote: Tue Feb 08, 2022 9:28 pm
Ya gotta buy a battery and charger too. That might be ok for some if it shares a battery with other tools,but my cordless stuff is DeWalt,which kinda makes it less of a bargain for me.
Re: Tool purchases
Skub wrote: Tue Feb 08, 2022 9:33 pm
I already have a few of them tools with three genuine and three Chinese batteries. This is only for when away in the camperbus as cables are a pain as the 12v outlet is in the front with suspension valve up the back and six tyres (Seven counting spare) to get around.
Re: Tool purchases
Felix wrote: Tue Feb 08, 2022 8:58 pm Ach what did you show me that for. I was going to wait till later in the year but had to order it at that price :D
Was funny when a mate called me late last night with a flat tyre.
Pumped up a 180 tyre from flat to 42 PSI in a couple of minutes.
Has thanked: 8009 times
Been thanked: 5666 times
Re: Tool purchases
I looked at mains powered ones. I don't know if I was looking in the wrong places but, the price :shock:
V tempted by the Makita one. I do appear to have 5 that plug into the cig lighter type though. :oops:
dern
Has thanked: 1180 times
Been thanked: 2276 times
Re: Tool purchases
Post by dern »
So much easier with the right tools, just have to work out how to remove the bearing on the other side I broke with the wrong tools now.
Has thanked: 1059 times
Been thanked: 1643 times
Re: Tool purchases
Festool OF 1400 router. Mines the 110 volt version with a yellow site rated plug though.
dern
Re: Tool purchases
Post by dern »
Woohoo, bearing drifts, no more pissing about with sockets...
Re: Tool purchases
New toy arrived :D
Even with a cheap Chinese copy battery it did as it says on the tin. Van tyres were all low (Mid 40psi) so took them all up to 58psi in no time and my spare was only 17.5 so that took a tad longer but way quieter than the 12v one what will get relegated to the wifes car :D If i was to pick a fault it could have done with a trigger lock.
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Re: Tool purchases
Post by DefTrap »
Nice!
I wish I hadn't recently bought myself a bog standard inflator as I'd have been all over that Makita - love 'em.
Re: Tool purchases
DefTrap wrote: Thu Feb 10, 2022 5:10 pm Nice!
They are only cheap if you already have the battery. I have three genuine and three Chinese copy's. Last genuine i got was 5Ah and was about £70
Has thanked: 316 times
Been thanked: 1078 times
Re: Tool purchases
Post by Silly Car »
I picked up a cheap n nasty honing guide and a range of wet and dry paper from 120 through to 5000 grit
I’ve spent an enjoyable time fettling a couple of old wood chisels using a small piece of 18mm MDF from the garage as a flat plate under the wet and dry.
With the first chisel, I had to start with a 40g sanding belt to get rid of a nail divot and a slopey bevel, gradually worked through the grades up to 800grit on the primary bevel, then on the second bevel up to full 5000 grit, 10-15 strokes per grade, with the end result of a fairly polished second bevel which could shave the hair on my arm. That level of sharpness is a first for me.
Second chisel just needed 10-15 strokes per grade to re-establish a clean primary and the same to get a hair shaving edge on the second.
Just need to work my way through my other chisels and planes now :D
Has thanked: 1080 times
Been thanked: 1010 times
Re: Tool purchases
Post by slowsider »
Would you not be quicker buying a razor? :D
dern
Re: Tool purchases
Post by dern »
Latest tool... huge fun, noisy and effective...
