JAPton blog
Has thanked: 10959 times
Been thanked: 3995 times
Re: JAPton blog
The new rear-shock mount bolts turned up.
Exactly as specced:
The left side:
With the pannier-mount in place, the shank does reach through to the outside of the mounting plate - exactly as measured. :)
Did the nuts up loose, just to hold things together for now.
On the right side I can either spin the die down one of the bolts to make the shank the right length - or simply pack out the nut like this, with a couple of extra spacers.
This is how the pannier will sit, but it will have a secondary nut and bolt to hold it straight as well. :)
Should be much better, out of the way, and won't interfere with anything that moves. :thumbup:
I'll probably use tie-clips or something similar to prevent the bag moving along the axis of the bike (currently it can do that - but it won't fall off the mounting bar, the bar is too long). I'll get it all mounted tight and see what the best solution for that is later on.
Re: JAPton blog
err, not been in the shop much over the hoidays... but managed to get in last week for an afternoon of shivering.
It's been preying on my mind somewhat that the measurements I took for the crank play weren't very accurate... so I decided that I really ought to do it properly with a dial guage. It was with this in mind that I entered the shop....
.. and pulled out the toolbag support bracket to finish off that job first. :D :roll:
So - first the next hole up needed a little file so that I could get a small bolt through it inline with the hole in the frame
Top view of the assembly in situ:
Internal view: Washer and lock washer in place
Just a view of the main shock support bolt in place.
And this is the tie-clip just stopping the toolbag falling forward or backward during riding (it can't fall off)
SO - with that done.... I remembered the dial guages...
I currently have 3: an imperial one and 2 metric ones - all bought randomly from jumble shows ( why I haven't just bought a new one from wherever.com is a mystery.... it had just never occurred to me.)
The imperial one seems to move and work ok, the Draper one seems to have a sticky movement, and the other metric one is ...well... just iffy.
So - in the best bulldog spirit of pressing forwards with the most important jobs....
I prevaricated again and started dismantling the sticky dial guage to figure out what the problem is.... :D
Looked ok at first glance...
However..... the eyeglass reveals all... (this thing is turning out to be really useful! )
(open the photo in Flickr and you can zoom in.)
The teeth on the main shaft are fucked. :roll:
So - instead of hurling the thing across the workshop in a fit of pique (it was tempting.... )
I calmly placed it to one side to see what was wrong with the other metric guage.
Hmm - something missing from here... I'm sure of it!
Can you see where this is going??
Can you?
I bet you can.
Yup !
FIXED IT!
:D :D
In addition... the knackered guage had a mounting lug on the back, and the newly fixed one didn't... so I figured that while one lug may not be as good as two lugs, it's still better than no lugs if lugs are to be needed.... (ahem) so I decided to fit the back from the dead guage onto the fixed one.....
which has 3 equally spaced threaded holes to secure the backplate.
The backplate with the lug... has 4 .... equally spaced ... holes.
<sigh>
FINE!
Get the drill out, carefully layer the 2 backplates so the old one can be used as a template..
And bingo!
A fully functioning, belugged, metric dial guage! (sorry, no photo. :P )
I also dug out a nice bit of ally hanging bracket (or something) to use as the "stand" for the guage - I can screw it to a bolt-hole on the cases easily enough.
I just need to reassemble the crank in the cases and figure out the arrangement of the guage....
Which will probably happen this week at some point... hopefully.
in the meantime... I'd be a lying little toerag if I claimed I wasn't strongly pondering the purchase of one of these...
(or similar)
Has thanked: 5953 times
Been thanked: 3571 times
Re: JAPton blog
Top faffery there chief :thumbup: Reminds me of work, amount of times I come in of a morning and think I'm doing 'A' today and that's that. 2 Mornings later I think I really should be doing A :think: :lol:
Re: JAPton blog
Most excellent thread. :thumbup:
That Amazon jobbie may be on my list sooner than later. At the grand old age of 7 decades I am now noticing a little difficulty seeing small things properly unless the light is very good. I've an old Moore & Wright 0 - 1" micrometer where the barrel is worn shiny and it's getting more difficult to read. I'm not at the reading glasses stage yet,but I daresay it's yet another indignity in the offing.
Re: JAPton blog
Skub wrote: Thu Jan 22, 2026 4:10 pm Most excellent thread. :thumbup:
Oh - I've hit the reading glasses requirement and I'm only 52. :(
and yes... I did buy the digital dial guage. :D
Been thanked: 1228 times
Re: JAPton blog
You lot don’t know you’re born!
I’m short sighted and long sighted now.
Has thanked: 2846 times
Been thanked: 1609 times
Re: JAPton blog
Hey - I'm at the stage where I have varifocals, but 2 sets! Normal ones for general life and special computer use varifocals for 2m or less!
Feeling like a right old fucka these days!
Re: JAPton blog
Had a fun afternoon yesterday fiddling with the flywheel (dem tings are heavy)
Parts assemble!
First assembly:
Yes - I did you a little video!
(yes, the music was too loud... my bad!)
(I initially wanted to do a time-lapse video... but I ended up just posting it as is)
This is how the dial guage ended up being mounted - seemed to work well and enabled a consistent (mostly!) location:
It took a bit of fiddling to get the dial to zero properly (with the crank pulled all the way to the left).
Finding the initial float:
Correction: the end float should be 0.012" - 0.015" (I made the same misread last time - because it's written in the booklet as .012" (the initial 0 is missing so I keep misreading it!)
Maths.
I initially chucked in 2 0.023" shims, one each side to see where that got me - theoretically, that should have been very nearly there....
The results:
I was also trying to get the conrod as central as possible - using the crank-case split line as the centre-line (an assumption - but I think a relatively safe one.... I hope!)
The polished crank means it's "relatively" easy to see where the conrod is
Crank pushed to left
Crank pushed to right.
I then added a 0.020 shim to the Timing side (right side) of the crank, and still had too much float (0.02xx something IIRC)
So I added a 0.010 shim to the left side as well
Too much??
Or just right?
While I pondered that...
I pulled out the compression plates that I have (which would sit under the barrel), which I was going to use as templates for the base gasket, and luckily had the thought to try them on the cases while I had the cases together.
They're not JAP.
Well - they might be JAP.... but they're not THIS Jap!
GAH!
I suspect they're from one of the other bikes... the Matchless maybe?
So - I also checked the spare head gaskets I found... and THEY'RE not right either! I could possibly use them... because while the inner diameter of the gaskets is larger than the bore, the outer diameter is considerably smaller than the outer diameter of the depression the gasket sits in! GAH!
I also have a box full of piston rings that I know are wrong (I think they're pre-war JAP)
So - I did a bit of tidying up...
TBH, I think the float is now acceptable, so I dry assembled the piston and barrel (no rings or gudgeon pins)
On a full 500cc engine with 15:1 compression... the piston should come right to the top of that barrel....
There's a fair bit of play in the small end - so I figured I could see roughly how central the conrod/piston is by gently lifting the barrel and observing the small end :
It looks ok to me!
Happy Bunny! Didn't need to buy more shims this time around.
Next job is to do some light grinding paste action with the barrel and the cases - the faces of the cases where the barrel mounts are a little lumpy, so I'm going to use some light grinding paste just to get the barrel and crank meeting faces "flat" which will a) help the paper gasket seal better and b) maybe possibly increase the compression by a gnat's chuff?? hey - every little helps! :D
After that - make up the barrel gasket and the oil-chest gasket (the volume under the timing chest where the oil collects for dispersal post use), and the gasket for the fitting under the oil-chest. I'm thinking I'll probably make up 2 or 3 of each: so I have spares for the future, and in case I have any accidents in assembly....
Then it's <gulp> time to start final assembly....
Although - I do still need to assemble the head and check the valves are sealing: using meths or paraffin this time! :D
I hope it gets a bit warmer soon.... at the end of every evening like this the ends of my fingers are freezing. :(
Re: JAPton blog
I'm starting to think that I really need to get in the workshop a bit more often - there's still a lot to do, and I'm definitely taking my time with things.
So - last night I went in and made gaskets. ... I know, it's soooo exciting! :D
Some of the parts that need gaskets, with existing old ones:
I started with the output side shaft seal plate gasket - this is a "non-standard" fitment anyway to slow down the loss of oil around the output shaft.
The outer and the fitment holes were relatively simple - but I need to break out the school-boy drawing tools for the inner circumference.
Note to self... for f*cks sake draw on the OTHER side....
But a reasonable finished product. :)
Next - the oil-drain chest cover.
Should be functional:
Funnily enough - the oil-collection chest gaskets can be bought, but this is an older one that's been used, and I can use it as a "master" template: it's a bit out of shape, but not enough to be a problem:
Much easier to work on the non-printed side of the paper! :D
With the old one that I pulled off: I'm going to leave this one as is, and not bother to trim out the internal "web" - it's not necessary.
The last gasket is the base gasket, but first I wanted to get the surfaces a tad smoother, so I dug out the fine grinding paste....
It's an improvement (I hope).
The initial circles I drew out with a compass, then tested for fit on the barrel
I then put the barrel onto the cases and marked the cut-outs for the bolts that tie the head & barrel down, then trimmed them out and checked the fit
I also trimmed out a smalle cutout on the inner of the gasket to match the slight cutouts which allow the con-rod to not-hit the cases.
I've put them in "storage" for now, (under a couple of books as well), and will very likely make up another complete set, using these as templates.
I then decided to make another fix:
The timing chain cover has another little cover over the mag-cog to allow you to adjust the timing without taking the entire cover off: you can lock the mag-shaft, then loosen the pinion nut and tweak it through a hole in the timing chain cover.
BUT - the threads on the tiny holes were tired - so I found some new set-screws with wide heads in the box of bits: figured out what thread they were M6 as it happened, ideally it would be nice to use Imperial all over, but there's other Metric threads on the bike so I'm kinda beyond caring at this point; re-cut the threads in the timing chain cover and hey presto!
I cut the set-screws down to ensure they don't interfere with the timing chain
And there'll be another paper gasket going under that cover to reduce any oil weep (the timing chain isn't lubed much, I don't think..., so it shouldn't be an issue really).
Actually quite pleased with the evening's progress.
Like I say - I'm going to make up another complete set of gaskets and will use that 2nd set for the build, and keep the first ones (the ones made directly from the mating faces) as the "master-templates". I may well find there's other places where a gasket might be useful, but we'll cross those bridges when we get to them.
Re: JAPton blog
Someone is bound to mention Corn Flakes packets.
Re: JAPton blog
JackyJoll wrote: Tue Jan 27, 2026 11:45 am Someone is bound to mention Corn Flakes packets.
My Dad preferred Rice Krispies.
Personally I had good experiences with Frosties.
Ian
Has thanked: 1361 times
Been thanked: 578 times
Re: JAPton blog
Post by Ian »
There is something very satisfying about making gaskets
Re: JAPton blog
Ian wrote: Thu Feb 05, 2026 7:28 pm There is something very satisfying about making gaskets
Even more satisfying when they actually hold in the oil. :D
Re: JAPton blog
Air cooled Ducati's don't have head gaskets.
My race engined air cooled RD250 had the heads and barrels machined so closely that you just used the tiniest amount of high temp silicone.
Re: JAPton blog
Well, since I'd got my head down during the week, I figured I was owed an afternoon in the shed....
I've always liked the "exploded diagram" photos you see in some of the magazines... so I had a go myself. :D
Unfortunately I kinda ran out of room on the bench.... so there's a few items not shown. :roll:
After I tidied everything back up again, I got on with the things I had planned:
First wash the grease off the main crank bearings:
one bowl of petrol :
Aaaand about ten minutes later...
One bowl of R30 with all the pins in. :) I figure they'll be safe in there until final assembly.
I also remembered that I wanted to check the valves properly, as discussed a lot further up the thread....
First I did a bit of cleaning up on the inlet manifold while I was there :
Much better. :)
Collected up all the valve bits.
Inlet valve went in first
Couple of Mica washers to slow down the heat transfer to the springs. I've already done all the work checking the spring-weights
The base cup and washer... and it's time to dig out the spring clamp!
This part always terrifies me..... it's like having a loaded gun with a hair trigger sitting on a jack in the box...
Especially when you realise you forgot to put the circlip on the stem. FFS.
Anyway - managed to fineagle it on without firing the springs into my face..
I actually did have to loosen it off because the springs were all leaning one way and I had to re-center the jaw of the clamp so I could get the collets on.
Note to self... put the circlip on FIRST.
(Well - after the valve goes in the guide... natch....)
Cocked and loaded.
Had to dig around for a plug, but found one.
NOT for drinking! (well - a last resort...)
Believe it or not... that's full.
Definitely full!
And NO DRIPS!!
I am SOOO fucking pleased with myself! I even did a little dance! :D
Waste not want not...
So - that's the head sorted! :D
Like I say - I am really happy that the valve seal, I spent a lot of time doing that and it's very very satisfying to see that it appears to have all gone right. :D
I put the head away but kept the Meths out...
The next job was cleaning up the cases.
I mainly wanted to get all the grease off the main bearing liners.
There's a feed oil that gravity feeds oil from the underside of the barrel, down to the liner...
Obviously there was grease in the feed hole.
Yeah - that got messy.... I pulled some meths into the syringe and blasted it into the top of the feed hole!
I blew air through the hole quite a few times, pretty sure it's 99% grease free now - anything left will just join the general gunkiness that is the end result of CastrolR getting hot. :D I used the meths to clean both cases up as best I could, including the main joining faces.
Then I started to look more closely at some of the peripheral bits of the cases.
This is the "sludge trap" which slows down the feed of oil out to atmosphere (these engines are designed to be total loss, and piss oil out onto the track - it's a speedway engien remenber!)
As in that photo, I have spare parts to replace those in the cases - but I'm not sure how to get them out, you can't really get a hammer inside the cases to knock them out from the inside, and I didn't want to get all Conan with a screwdriver....
So, while I pondered that... I spent an hour or so checking all the screws and threads for the peripherals.
These feckers are M5.
The dreaded silicon sealant....
If you look closely.... you may notice that yes, indeed, the black set-screws (for the sludge trap catchbox) are VERY closely aligned with the oval-headed screws for the oil-trap cover...
They actually interfere with each other!! But it's actually not a problem because the black set-screws are the right length for the catchbox. But it gave me pause for thought as I was cleaning everything out!
I cleaned up all the threads for the oil-trap cover as well - now there's plenty of thread to ensure the cover is held down tight.
And I found a nozzle in with one of the tubes of Blue Hylomar! that'll make life easier! :D
So - all the threads are clean, I've got the Hylomar all ready, the bearings are clean and soaking in oil (mainly so there's "something" to just about keep them in the cages when I assemble the cases), I've got the gaskets I need (I tried to make up some carboard templates last week, but had limited success).
I just want to get that sludge trap sorted out before I really get going on the full assembly. I've asked a question on a popular group on FB, so hopefully I'll get a response soon!
Oh - I also found that all the little parts that hold the rockers in place in their box - the washers and bearing liners had gone fecking rusty! I think my mistake was storing them all in sealed plastic boxes after I'd been fiddling with them repeatedly last year - a mix of trapped humid air and acidic finger grease. :( So I gave them all a good brass-brushing and we'll see how they fare. The actual bearing surfaces seem to be fine - it's the rest (eg the outer surfaces of the liners) that had surface rust on them. my dumb mistake, but I doubt they'll be problematic.
So - progress and some mistakes, but, mostly progress! :D
Tricky
Has thanked: 3043 times
Been thanked: 3309 times
Re: JAPton blog
Post by Tricky »
Brilliant thread 8-) :thumbup: Albeit it is making me feel very guilty about the piles of old Brit bike bits in my garage that haven't moved for years... looking forward to the next episode, and motivation for me to get my arse in gear!
Re: JAPton blog
Tricky wrote: Wed Feb 18, 2026 10:30 am Brilliant thread 8-) :thumbup: Albeit it is making me feel very guilty about the piles of old Brit bike bits in my garage that haven't moved for years... looking forward to the next episode, and motivation for me to get my arse in gear!
Maybe when your racing contract expires in 2040,you'll swop being a racing god for being a spanner god. :thumbup:
Re: JAPton blog
Just a brief status report.
The sludge trap has been soaking in white spirit for a couple of weeks.
And, with some gentle encouragement....
All the little discs seem to be more or less sludge free and loose enough to rattle, just about.
So, its all, i think, ready for reassembly once i get back from Latin America. :D
Re: JAPton blog
Is a sludge trap common on old Brit machinery?
Re: JAPton blog
Skub wrote: Tue Feb 24, 2026 4:19 pm Is a sludge trap common on old Brit machinery?
No idea. In this engine it's basically a filter to stop "too much" oil falling out during a race. :D
