Has thanked: 6115 times
Been thanked: 15467 times
Felix wrote: Tue Feb 03, 2026 12:02 pm I can do a cock n balls in the slab so well chuffed :lol: :lol:
only just.... that's a bit of a stretch.
Has thanked: 711 times
Been thanked: 2014 times
Motherinlaw is up at the weekend. As long as she can see it from the living room window i am happy :lol:
Has thanked: 2844 times
Been thanked: 3495 times
Might give that ago next time. it's a good test of power. Reckon yours has more. 👍🏻
Has thanked: 2273 times
Been thanked: 2655 times
Dodgy69 wrote: Tue Feb 03, 2026 11:00 am Further tests completed... It works, not the most powerful I'm sure but should do for job purposes, blowing mud away.
On initial prime I found i sometimes had to lower gun to bucket level, once primed it worked. I've shortened the tube but makes no difference, it's like the suction isn't quite there.
Like fuel pumps etc, they work much better at pushing the liquid instead of pulling it. That's why electric fuel tank pumps are far better than pumps mounted on the firewall by the engine (which have a habit of burning out in short order)
If it could be modified so that a garden hose attached where the feed line goes into the pump it would likely perform better... but that buggers up the mobility aspect.
Might give that a go or try raising the bucket. The hose will be easy to attach though but was hoping to use up free water, though what I'll use don't really matter.
Dodgy69 wrote: Tue Feb 03, 2026 1:09 pm
Is this the same as yours? The specifications say its 38 Bar
https://www.ebay.co.uk/itm/406647041342 ... 26.m162918
Where as mine is allegedly 100 Bar. Great difference when converted to psi :D B
https://www.ebay.co.uk/itm/326217904515 ... 26.m162918
But i would take that with a pinch if salt as the Makita one is only 24 Bar
https://www.diy.com/departments/makita- ... 468_BQ.prd
Felix wrote: Tue Feb 03, 2026 4:27 pm
A worx hydroshot is showing as 24bar and seems WAY more than his.
Fuck off.... i'm not opening a TEMU site.... go and sit in the corner and think about what you've done.
Yep, top one I think without fancy box.
Been thanked: 3208 times
A pinch of salt, more like the whole sodding salt mine, If you believe those figures you need your bumps feeling.
I was dealing with a client last year looking to get some garden machinery made over in the land of the stolen IP, and was told by the forced labour sweat shop it was OK to label his stuff as being 4000 watts despite being only 1000 watts :think:
weeksy wrote: Tue Feb 03, 2026 4:38 pm
Delete if you want.
Wasn't getting on with cheap 1 cup cafetiere, so one of these has been delivered to see if it's any better;
Has thanked: 12556 times
Mucho cheapo mirror visor for my Arai.
Perfect fit and no draughts :)
Has thanked: 19491 times
MrLongbeard wrote: Wed Feb 04, 2026 5:06 pm Wasn't getting on with cheap 1 cup cafetiere, so one of these has been delivered to see if it's any better;
Is that for home or for out and about??
Noggin wrote: Thu Feb 05, 2026 6:32 pm Is that for home or for out and about??
Home, no need for out n about coffee kit.
MrLongbeard wrote: Thu Feb 05, 2026 7:56 pm
Does it make a much better espresso than a machine? (Only cos I had one similar and it was just a faff - but then espresso isn't my go to, so a machine works pretty well for me!). Although it does look rather lovely!!!
Noggin wrote: Thu Feb 05, 2026 8:36 pm
No idea, never had an espresso, mine's just a mug of black coffee, that stove top jobbie is said to be 300ml which is just a smidge shy of a mug full.
A set of rear wheel bearing from Wemoto. Only reason it pleases me it came with a free scribble pad. It has been years since i had anything free from them. I remember you got a scribble pad or keyring with every order. I am sure i got a pen also.
MrLongbeard wrote: Thu Feb 05, 2026 8:56 pm
Ok so coffee nerd I am not, a nice hot strong mug of black coffee is all I need, with that said.
This thing (6 cup, 300mml) takes 2 scoops of coffee in its basket, which is half of what I would use in an Aeropress and about the same as I would use in a single cup cafetiere, and by crickey it makes a strong cup of coffee.
It's more of a faff than my usual methods, and there is some sludge in the cup (maybe the grind I get is too fine, but it is store bought pre-ground https://skullcrushercoffee.com/products ... g-free-mug ) but yeah I reckon for the one cup I make a week it's worth it.
