New bike thread!
Has thanked: 2098 times
Been thanked: 2558 times
Re: New bike thread!
Taipan wrote: Thu Jan 14, 2021 12:17 pm Yay centre stand bracket is here! Boo! It’s pissing down! 🙄
Anyone speak Japanese?
Chin Cin can don con dung do la remvem dak! Or something. Beats me!
asmethurst99
Has thanked: 1331 times
Been thanked: 484 times
Post by asmethurst99 »
My son says it somthing to do with the springs ...
Something about shandy drinkers ?
The M6 box says,"thank you for shopping Ali Express". :thumbup:
Fakerapovic fitted, albeit sans Akra sticker. Fieves is fick innit and they might chore it thinking its real! :roll:
Couldn’t resist. Looks authentic now! :lol:
Has thanked: 2848 times
Been thanked: 1609 times
Looks wonky? Keeping in with the fake look? 🤣
v8-powered wrote: Sat Jan 16, 2021 10:46 am Looks wonky? Keeping in with the fake look? 🤣
Deffo lol! Dunno whether it slid when it was hot or something, but I was convinced i'd got it level lol!
I had a couple of hours spare today, so I fitted the hand guards. All pretty straightforward apart from one pinfukit moment when a 10mm nut disappeared into a parallel universe. :roll:
So as I had a bit of time I thought I may as well get the 2 rounded off allen bolts out that hold the front mudguard off. An hour later they are nothing more than rounded off even more. HTF something can round off so easily, yet resist anything I try and wedge in there! :roll: After a few :angry-cussingblack: exchanges I left it. Wonder if I can take the forks out with the mudguard attached...
Had the same with the Beemer, it'll be because the threads of the bolts stick out a tiny bit into all the crap being flung off the wheels.
If you drill the heads off to remove the mudguard there might be enough stud stuck out to get the mole grips on... after a lot of Plugas/WD/GT, etc...
I hadn't thought about the threads sticking through the forks and getting covered in shite. I'll get the wheel out and see if that is the case and clean them up and plus gas them before attacking them again. Effin' nuisance really as I could have had it all done the other day but was thwarted by these dastardly bolts! :D
We need a video of blowtorch action on a plastic mudguard. :thumbup:
Skub wrote: Mon Jan 18, 2021 3:00 pm We need a video of blowtorch action on a plastic mudguard. :thumbup:
Bear with me, cos its probably going to happen! :D
G.P
Has thanked: 1994 times
Been thanked: 1283 times
Post by G.P »
Taipan wrote: Mon Jan 18, 2021 3:04 pm
What could possibly go wrong! Deffo needs to be videoed :D :thumbup:
Has thanked: 5954 times
Been thanked: 3572 times
My Bro had four rounded nuts on the footpeg hangers on his new to him Z750 discovered when he went to fit a top box. Think it look heating, several drill bits, 12 odd hours and much effing and jeffing to get em out.
I think i'm actually beaten by it! :wtf: I've never had this before. I've undone rounded off disc bolts with less problems! This has had the exposed threads cleaned up and lashings of plus gas and i've now tried drifting it round with a chisel, but it ain't budging at all?!?! I slipped and gouged the mudguard a bit anyway :roll: so I guess heat is going to be the only way? But the mudguard aside, I don't really want to ruin the finish on the fork leg?
I've read before about syringing the old oil out and just put the new stuff in and that could be an option I suppose? I think i'd rather remove them as a pair with the mudguard attached though. What a PITA! As they say, its never easy...
Lets see some pics so we can visualise better ?
Big Red
Has thanked: 3 times
Been thanked: 81 times
Post by Big Red »
You should be able to remove the wheel and you will see the captive nuts inside a cage and the end of the rusty bolts sticking through.
Carefully remove the cages with a dremmel and you should be able to dremmel of the nuts without generating to much heat.
Just replace the bolts with new and you will be able to secure with new nuts on inside.
inewham wrote: Mon Jan 18, 2021 5:51 pm My uncle used to weld a nut on the end, the heat was enough to loosen the bolt and the new nut gave you something to get a grip on
He did a few for me that way and saved me hours of grief on bolts that wouldn't shift with blow lamps, hammer and chisel etc.
Do you know anyone with welding gear?
I did but the F-i-L gave his up when he moved house, something we both regret!
