If it goes into reverse heat pump mode it may heat the inside? @Rockburner will probably remember what the issue was.Mr. Dazzle wrote: ↑Sun Apr 14, 2024 2:44 pmKinda don't need the fridge in that situation anyway right, even if it were the case?Count Steer wrote: ↑Sat Apr 13, 2024 3:21 pmI think it's less of a problem for freezers but iirc if the exterior temperature is less than the device interior they can go into reverse or summat.
A right now thread
- Has thanked: 6376 times
- Been thanked: 4752 times
Re: A right now thread
- Has thanked: 2550 times
- Been thanked: 6244 times
I wouldn't have thought so, but maybe...
The 'hot side' is always outside the box, I can't think of way for a fridge to run in reverse but I certainly haven't spent an enormous amount of time poking around domestic fridges
Way more fundamentally though, if the interior gets very cold then the thermostat just won't kick in anyway. The fridge won't try and run 'cause the inside is already cold. At which point it just becomes an overblown cupboard?
There's a few explanations if you Google 'why don't fridges work in the cold' inc coolant operating temperature range, thermostat. One thing suggested that, because there's only one compressor on a fridge/freezer and the fridge thermostat thinks everything is cold enough...the freezer thaws out.Mr. Dazzle wrote: ↑Sun Apr 14, 2024 4:17 pm I wouldn't have thought so, but maybe...
- Has thanked: 7817 times
- Been thanked: 2527 times
The inside didn't get hot. It just didn't get cold enough because iirc a domestic fridge it's designed for an exterior temperature above about 7 degrees, (or something). Below that they just don't operate, and the internal temp rises to match the external.Count Steer wrote: ↑Sun Apr 14, 2024 3:53 pmIf it goes into reverse heat pump mode it may heat the inside? @Rockburner will probably remember what the issue was.Mr. Dazzle wrote: ↑Sun Apr 14, 2024 2:44 pmKinda don't need the fridge in that situation anyway right, even if it were the case?Count Steer wrote: ↑Sat Apr 13, 2024 3:21 pm
- Cousin Jack
- Has thanked: 2551 times
- Been thanked: 2285 times
Sitting in the dentist's waiting room. Only a check up, but always a tad unsettling.
Bloody cold here today, not the 23 C it was in Spain.
- Has thanked: 6188 times
- Been thanked: 5087 times
Puppy asleep, so sit quietly / coffee / book* ... and enjoy it while it lasts
* Jo Nesbo (Harry Hole) Killing Moon
- Has thanked: 15952 times
- Been thanked: 10243 times
Picking up after having two Bobcats* fighting in the house. Like a bastard wrecking crew when they are chasing each other around the place and fighting! Good entertainment though!
*French Bulldogs
*French Bulldogs
- Has thanked: 1079 times
- Been thanked: 720 times
Washed the bike ready for MOT, so did the car too, just got to vac it. Off out for a ride after vac and cuppa.
Then some sleep ready for nights later.
Suns out, 9 degrees but it’ll do for now!!
Mick
Mick
- Has thanked: 836 times
- Been thanked: 1238 times
The reason I read years ago was some fridge freezers only have one thermostat in the fridge which controls cooling for both, if the unit is used in freezing temps then the fridge thermostat never gets warm enough to switch on and the freezer ends up defrosting.Rockburner wrote: ↑Sun Apr 14, 2024 7:30 pmThe inside didn't get hot. It just didn't get cold enough because iirc a domestic fridge it's designed for an exterior temperature above about 7 degrees, (or something). Below that they just don't operate, and the internal temp rises to match the external.Count Steer wrote: ↑Sun Apr 14, 2024 3:53 pmIf it goes into reverse heat pump mode it may heat the inside? @Rockburner will probably remember what the issue was.Mr. Dazzle wrote: ↑Sun Apr 14, 2024 2:44 pm
So fridge freezers with 2 thermostats would be ok.
Chilling with a pre-dinner glass of fizz on the rooftop terrace of the Malta Marriott on my last visit here for possibly ever.
Unless I set up a near-shore office here for my new place
- Has thanked: 16206 times
- Been thanked: 3923 times
Standing at a very cold bus station. Looks like the bus times have changed bus no one has amended any of the info! Here’s hoping the 19:15 one arrives cos I’ll be peeved if it doesn’t
- Cousin Jack
Sitting in a crap airport hotel . Take off for Malta at 0625 tomorrow morning.
- Cousin Jack
We (me and Mrs CJ) arrive tomorrow, staying at the Phonecia. Wave as you go to the airport.
Nice place Will do Have fun!Cousin Jack wrote: ↑Thu Apr 25, 2024 7:03 pmWe (me and Mrs CJ) arrive tomorrow, staying at the Phonecia. Wave as you go to the airport.
- Has thanked: 2941 times
- Been thanked: 1883 times
Eating a late breakfast.
- Cousin Jack
- Cousin Jack
You had the better weather. Cloudy here this evening, and a bit chilly.
It pissed it down on Wednesday afternoon/evening if that helps! Lovely yesterday and this morning thoughCousin Jack wrote: ↑Fri Apr 26, 2024 5:58 pmYou had the better weather. Cloudy here this evening, and a bit chilly.
Here's hoping you get more of that
