Can we have an "Unpopular Opinion" thread?
McNab
Has thanked: 261 times
Been thanked: 319 times
Re: Can we have an "Unpopular Opinion" thread?
Post by McNab »
I don't like these new 400cc Triumphs. They look arse and the engines are too small.
Has thanked: 3010 times
Been thanked: 1749 times
Taff wrote: Tue Sep 10, 2024 11:30 am Unpopular opinion - wasps are aces 🐝🐝🐝🐝👍
They're pollinators and might come in handy when bees run out.
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
I wouldn't buy/own an Indian built motorcycle
Has thanked: 8040 times
Been thanked: 5694 times
Sadlonelygit wrote: Wed Sep 11, 2024 8:59 am I wouldn't buy/own an Indian built motorcycle
That's not unpopular with me. You buy what you like, I don't mind. :thumbup: :D
Has thanked: 20859 times
Been thanked: 13679 times
I think Farage should start a Make England Great Again, just so we can have baseball caps with MEGA on them! :thumbup:
Sadlonelygit
Count Steer wrote: Wed Sep 11, 2024 9:51 am
As the forum is turning into the unofficial RE/Himalayan owners club :?
A mate of mine used to develop some clever pipe inspection kit which Tata bought. After 6 months of use he was summoned to India to find out why they had such a high failure rate.
After examining their processes and recalibrating the machine he came to the conclusion that they just made shit pipes.
Senior management wanted to know if there was any way to lower the failure threshold on the inspection equipment :wtf:
These were oil/gas pipes by the way, not the kind of thing you want to fail in situ
Taipan wrote: Wed Sep 11, 2024 10:14 am I think Farage should start a Make England Great Again, just so we can have baseball caps with MEGA on them! :thumbup:
Baseball caps??!!! Away with yer forrin hats, we want English hats for English people.
Has thanked: 2318 times
Been thanked: 1822 times
Post by Jody »
The rounded 'tiles' used on French roofs are a bad design that hasn't aged at all well.
Count Steer wrote: Wed Sep 11, 2024 10:19 am
Can they still be made in a Chinese sweatshop or am I undermining myself? :think:
Sadlonelygit
Jody wrote: Wed Sep 11, 2024 10:27 am The rounded 'tiles' used on French roofs are a bad design that hasn't aged at all well.
Speed of application and ease of use.
Have you seen those new plastic sheets of tiles they use now?
Post by Jody »
Sadlonelygit wrote: Wed Sep 11, 2024 10:32 am
Vrs, they always slip and you have to take half the roof off to fix a few tiles.
They are also fairly brittle and not universally shaped.
I WISH we were using the plastic sheets, it's only a workshop anyway :(
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Post by DefTrap »
French roofers must rub their hands in glee after every high wind - there's an infinite backlog of repair work to get through.
Most of my 'unders' have been replaced by wriggly cement board.
Post by Jody »
DefTrap wrote: Wed Sep 11, 2024 10:39 am
If it was my roof (it is for my parents). I'd take all the tiles off, put some felt or similar over the wood, then plastic roofing sheets over the top. Then I wouldn't have to think about it for 20 years !!
Has thanked: 1926 times
Been thanked: 1728 times
French food is vastly over-rated
Has thanked: 3004 times
Been thanked: 2522 times
Steaks should be cooked at most to medium rare. Any more and it is no longer food, it is leather.
Has thanked: 2556 times
Been thanked: 4167 times
Jody wrote: Wed Sep 11, 2024 10:47 am
Roofing felt on southern French roofs is a Very Bad Idea - it just melts in the temperatures that are routinely achieved. You need foil-based roof lining, whether multifoil or single layer, with the preformed wiggly concrete-based sheets on top. Then if you wish you can add the tuiles canales on top of the sheet to make it look 'authentic'. Plastic sheets will degrade very quickly due to high levels of UV.
Post by Jody »
mangocrazy wrote: Wed Sep 11, 2024 12:12 pm
We're in the Vendee, granted the weather is better than the UK, but it's not as hot or for as long as the South. The neighbour has the plastic sheets on his garage !
DefTrap
Post by DefTrap »
mangocrazy wrote: Wed Sep 11, 2024 12:12 pm Roofing felt on southern French roofs is a Very Bad Idea - it just melts in the temperatures that are routinely achieved. You need foil-based roof lining, whether multifoil or single layer, with the preformed wiggly concrete-based sheets on top. Then if you wish you can add the tuiles canales on top of the sheet to make it look 'authentic'. Plastic sheets will degrade very quickly due to high levels of UV.
Mostly wriggly cement sheets used around here (Charente-Maritime) AFAIK, but I've seen the wriggly plastic in the Bricos. I'm maybe consider using it on an outbuilding I spose (although I didn't I just used what I was used to, the cementy stuff).
Last year it got so hot that the roof lining in the car detached itself. :(
BTW I dunno about French food being over-rated (depends where you go), but I find the overall quality far higher that the UK (not that that is too hard). However the menu choices get a bit samey.
DefTrap wrote: Wed Sep 11, 2024 12:51 pm
The French spend the most disposable of any European country on food - dunno it that is because the quality of the offer or just French supermarket pricing. (Two examples: Epoisses cheese - Tesco 3.50 GBP, In France 8.00 euros for similar quantities. Lays ready salted - France - 4 euro plus, UK 2 GBP and change)
Has thanked: 781 times
Been thanked: 1072 times
Mr Moofo wrote: Wed Sep 11, 2024 4:14 pm
Is that due to protectionism driven by protesting farmers? So imports can't undercut them?
