Bmw r1200gs battery??
Has thanked: 7852 times
Been thanked: 2554 times
Re: Bmw r1200gs battery??
Count Steer wrote: Wed Aug 21, 2024 3:23 pm
Taipan wrote: Tue Aug 20, 2024 8:35 pm I'm with Yorick here, never jump a bike from a running vehicle. A spike can kill your ecu.
Well, you live and learn eh?. (Not that I've ever tried to jump start a bike with a car, but have done car to car many times). Puzzled as to why a car on tick over would have an output spike and why this isn't a problem for a modern car on the receiving end too. (Our 'laptop on wheels' car instructs you to have the 'donor' car running).
Car to car isn't an issue: the systems on both are designed to handle the outputs of batteries with similar specs.
But Car to Bike is not to be recommended because bikes aren't designed to accept current from car-spec systems, they're only designed, or rather, manufactured, to accept current from the rather meagre outputs of bike-size batteries and generators.
Has thanked: 6409 times
Been thanked: 4795 times
Rockburner wrote: Wed Aug 21, 2024 3:56 pm
Interesting, but a bit confusing - being a non-electrician I'd thought that 12v is 12v and things draw the current they need but that's probably a bit too i=e÷r :D
OTOH if I needed to jump start a bike, I'd use my Noco. :thumbup: Although from memory, if I hadn't added 'tails' from the battery I'd still have to take the tank off to access the battery terminals on the GS. :(
Has thanked: 1765 times
Been thanked: 2107 times
I've had a tech do some tests tonight. It looks like battery failure only. Bloody hope so. Starter motor is fine, Starter relay in fine. He also has no qualms on jumping from a running car to bike. It seems some do and some don't. 🤷🏻‍♂️
Has thanked: 541 times
Been thanked: 7591 times
I reckon 99% of the time it's the battery.
Which is good, because it's the cheapest thing to replace (except for fuses).
Saying that, I've had bad earth points cause some really weird shit on cars.
Has thanked: 2636 times
Been thanked: 1525 times
Unlike the old wet lead acid batteries that would gradually die, gel batteries seem to fail almost instantly. They're often fine one day, shagged the next.
I rode the old Hornet from Kent to Oxford one morning to run a course. It started fine out of the garage, parked up to meet the trainee, only for the battery to fail when I tried to restart - it wouldn't even turn the motor over. Fortunately, I was right next door to a bike shop who ripped me off for a ultra-cheapo R*b H*nter battery that was equally dead just 9 months later. Yuasa went in. Lasted years.
FWIW, I finally replaced the OE Yuasa on my 62 plate Yamaha XJ6... yep, twelve years old.
New battery on and all sorted. I've replaced with the same one that came off. Tanya batteries £48 delivered. Thanks for everyone's input. 👍
