Ignition feed to reg/rec
Re: Ignition feed to reg/rec
JackyJoll wrote: Wed May 22, 2024 3:11 pm
iansoady wrote: Wed May 22, 2024 12:33 pm True, but still makes no sense to me being brought up on simple Lucas stuff. The red is the output from the reg/rec but must be at the same potential difference as the brown as it's connected to exactly the same place ie the battery.
This is a guess: the sensing circuit in the reg/rec box drains a bit of current, so it’s cut when the bike is parked.
It doesn't, some reg/rec only have 5 wires, the feedback wire is internal to the reg/rec, as I previously said, the feed back wire doesn't need to be switched.
Has thanked: 261 times
Been thanked: 1265 times
Le_Fromage_Grande wrote: Wed May 22, 2024 4:57 pm, the feed back wire doesn't need to be switched.
Yamaha, or Rupe, thought it should be.
It's not just a feedback wire, it's the main 12V feed for everything on the bike, most older Japanese bikes are wired like this, but it doesn't have to be switched. Most cars have the reg / rec built into the alternator with just a +12V and an earth connection, none of it is switched.
Saying that, there's no reason to change it from how Yamaha intended it to be.
iansoady
Has thanked: 59 times
Been thanked: 169 times
Post by iansoady »
Now fitted with the brown wire connected and all looks good - c 14 volts at 3000 rpm. A bargain at £15 or so.
