Bosch Performance Line CX Gen 2 Strip Down
crust
Has thanked: 604 times
Been thanked: 515 times
Re: Bosch Performance Line CX Gen 2 Strip Down
Post by crust »
Excellent posting, Beanie. :thumbup:
Mines just done 750 miles, I've never jet washed it and am very careful with the hose but it has got soaked more than a few times.
Am thinking either before Morzine in August or at the 1000 mile mark I'll probably send it to ebike motor pepes.
DefTrap
Has thanked: 2259 times
Been thanked: 2189 times
Post by DefTrap »
:thumbup:
Good work.
Pushiron parts always seem so feeble compared to even light motorcycle parts. The juxtaposition of all those electronics and rusty, manky bearings are frightening ...
Beancounter
Has thanked: 2869 times
Been thanked: 554 times
Post by Beancounter »
Nordboy wrote: Mon May 13, 2024 5:54 am
Beancounter wrote: Sun May 12, 2024 9:47 pm I can see me going for the Bosch Service Kit + on this occasion. Still cheaper than a secondhand motor.
They are good kits and nice to see Bosch supplying them tbh, rather than making people pay for it to be done.
There's youtube videos showing how and where all the bits go as well. Makes even people like me think they could have a go without totally cocking it up :D
Ordered the Service Kit + today. The difference between it and the Mega kit is that the Mega kit contains the tools needed to remove the crank arms and front sprocket. Still haven't fully stripped the motor yet but I figure that if I know what new bearings I've got I can be a little less cautious with removing the old.
Haven't looked at the Ebike Motor website fully yet but there appears to be a load of helpful info on DIYing. :thumbup:
crust wrote: Mon May 13, 2024 2:28 pm Excellent posting, Beanie. :thumbup:
The service kit that I've bought talks about using different bearings because the standard Bosch ones are felt and just let water by, keen to see the difference.
DefTrap wrote: Mon May 13, 2024 2:48 pm :thumbup:
Good work.
Indeed. There's still a lot of heavy grease in my motor but I've no idea hos much, if any, has been washed out over the last four years. I'd be tempted to pack out the whole thing but am sure that would have other negative effects.
**Edit** just had a message from Parcelforce saying they've collected my package from Ebike Motor peeps and it'll be delivered tomorrow. Excellent service thus far! 👍
Beancounter
Work and family-time has diverted my (lack of) focus elsewhere. As mentioned, ordered the Service Kit + from Ebike Motor Centre and it turned up a day later.
IMG_20240517_213426_914 (Medium).jpg (111.49 KiB) Viewed 1084 times
IMG_20240517_213551_990 (Medium).jpg (95.07 KiB) Viewed 1084 times
IMG_20240517_214040_389 (Medium).jpg (121.05 KiB) Viewed 1084 times
Beancounter
The contents of the pack claim to be and certainly appear to be everything required to do a full strip down, including a new DS cover with some bearings already installed:
IMG_20240517_213546_393 (Medium).jpg (115.31 KiB) Viewed 1083 times
IMG_20240517_213717_433 (Medium).jpg (136.78 KiB) Viewed 1083 times
IMG_20240517_213750_514 (Medium).jpg (105.73 KiB) Viewed 1083 times
Beancounter
The inclusion of a new assembled DS cover is a nice touch but it does present me with a problem. When I was removing the old cover a small locating pin broke off and remains in the motor case - circled red on the screen shots below:
Screenshot 2024-05-28 095503 (Medium).jpg (72.37 KiB) Viewed 1074 times
Screenshot 2024-05-28 095523 (Medium).jpg (77.05 KiB) Viewed 1074 times
As I see it, my options are:
1. Try to remove remnants of the locating pin from the motor case. It's not very deep and only a few mm wide so there's not much room for error;
2. Grind off the locating pin on the new cover;
3. Remove the bearings from the new cover and install on the old.
Number 2 is my preferred option as I don't really want to be drilling out the broken part.
Beancounter
I'm not called the King of Procrastination for nothing...
Progress limited to cleaning up the rust on the crank and gear cluster. Used Kurust and rotary tool brass brush:
IMG_20240630_130052_146 (Medium).jpg (91.46 KiB) Viewed 984 times
That photo is part-way through the cleaning, you can see the cleaned area is much better but not brilliant. Am considering buying a cheap ultrasonic cleaner to see if it makes much difference.
Also purchased this at the weekend, should get it in a few days' time:
Hydraulic Press.jpg (99.76 KiB) Viewed 984 times
It's a cheap eBay item but should be sufficient for my needs.
IMG_20240630_130055_271 (Medium).jpg (96.21 KiB) Viewed 984 times
Beancounter
Hydraulic press arrived yesterday as planned. Standing at 95.5cm it's quite tall for a bench press but it's still useable. Very heavy and cumbersome as you'd expect so it's not really something to be moved around regularly. Putting it together took about half an hour, mainly because of the agg of trying to fit the bottle jack in place whilst fighting the return springs. In the end I used a scissor jack to extend the springs and tied six chunky cable ties around the platform which the bottle jack sits on (this platform being the ram for the press) which allowed me to fit the bottle jack.
IMG_20240702_220231_487 (Medium).jpg (109.02 KiB) Viewed 937 times
IMG_20240704_200913_807 (Medium).jpg (113.03 KiB) Viewed 937 times
Beancounter
Once assembled it made quick work of removing the seized NDS outer crank bearing and the battered/partially removed needle roller bearing from the gear cluster:
IMG_20240704_194208_692 (Medium).jpg (48.66 KiB) Viewed 925 times
IMG_20240704_193915_604 (Medium).jpg (65.3 KiB) Viewed 925 times
Beancounter
The NDS outer crank bearing doesn't look too bad but once I pried the seals away it was a different story:
IMG_20240704_194446_040 (Medium).jpg (108.5 KiB) Viewed 923 times
Scraped a lot of dirt out but most was still trapped in the bearing itself:
IMG_20240704_194802_363 (Medium).jpg (177.2 KiB) Viewed 923 times
Even using some pretty cheap and nasty engine degreaser could free the ball bearings.
The outer race of the needle roller bearing:
IMG_20240704_193934_873 (Medium).jpg (44.32 KiB) Viewed 923 times
Beancounter
Next stage is to remove the bearings from this gear cluster:
IMG_20240704_195354_841 (Medium).jpg (86.55 KiB) Viewed 923 times
The gears are sandwich between a needle roller bearing and a small ball bearing and to remove both bearings means removing both gears. Once the gears are removed you are left with this:
IMG_20240704_195545_015 (Medium).jpg (108.07 KiB) Viewed 923 times
This was one of the reasons for buying the bench press as to try tapping out the bearings could easily damage the 'fork' - not to mention how difficult it would be to tap them out in the first place.
Beancounter
Not particularly good close ups of each bearing:
IMG_20240704_195558_650 (Medium).jpg (81.43 KiB) Viewed 920 times
IMG_20240704_195602_388 (Medium).jpg (84.57 KiB) Viewed 920 times
Neither bearing feels rough but no point coming this far and not replacing them.
Beancounter
With the kit I've bought I only have to swap four bearings myself as most of the others mentioned earlier are pre-installed:
IMG_20240704_200654_978~2 (Medium).jpg (75.58 KiB) Viewed 919 times
The red one is the NDS outer crank bearing.
The yellow is the needle bearing for inside this gear cluster:
IMG_20240704_193915_604 (Medium).jpg (65.3 KiB) Viewed 919 times
The final two are for this gear cluster:
IMG_20240704_195354_841 (Medium).jpg (86.55 KiB) Viewed 919 times
Hoping to get these swapped/installed over the weekend and the motor put back together if not installed on the bike.
Beancounter
Beancounter wrote: Tue May 28, 2024 10:10 am The inclusion of a new assembled DS cover is a nice touch but it does present me with a problem. When I was removing the old cover a small locating pin broke off and remains in the motor case - circled red on the screen shots below:
A bit of a result when pressing out the NDS outer bearing - the broken locator pin fell out too so no need for drilling or cutting.
Has thanked: 6374 times
Been thanked: 4745 times
Beancounter wrote: Fri Jul 05, 2024 12:43 pm Hydraulic press arrived yesterday as planned. Standing at 95.5cm it's quite tall for a bench press but it's still useable. Very heavy and cumbersome as you'd expect so it's not really something to be moved around regularly. Putting it together took about half an hour, mainly because of the agg of trying to fit the bottle jack in place whilst fighting the return springs. In the end I used a scissor jack to extend the springs and tied six chunky cable ties around the platform which the bottle jack sits on (this platform being the ram for the press) which allowed me to fit the bottle jack.
Now that's a proper boy's toy. :thumbup:
Beancounter
Well I screwed this up quite spectacularly.
IMG_20240706_131754_684 (Medium).jpg (109.09 KiB) Viewed 864 times
The ball bearing came out very easily but getting the needle bearing out was proving very tricky because I wasn't comfortable with the pressure on the casting. I wanted to use a cheap socket to fill the gap left by the gears but the socket kept falling through the now-larger hole left by the ball bearing. To fix this I thought I would re-install the ball bearing and I naively thought it would go back in as easy as it came out - not so. The casting broke like a matchstick.
Spent the whole weekend feeling very annoyed with myself and contemplating the cost of a new/refurbed motor but the guys at Performance Line Bearings have saved the day - £24 for a new part.
Has thanked: 5449 times
Been thanked: 13084 times
Whoops, we've all felt your pain
Beancounter
Finally had a spare weekend and the gumption to return to this. Won't lie, the longer I left it, the more daunting the task seemed in my head.
A mate from work wants to pop his uplift cherry so I had some external motivation. Everything had been bunged into a shoe box due to a friend from the States crashing at ours so first thing was to carefully unpack said shoe box and take stock of what parts I had and what the next step was:
IMG_20241004_152528_327 (Medium).jpg (203.99 KiB) Viewed 352 times
IMG_20241004_154421_186 (Medium).jpg (261.69 KiB) Viewed 352 times
Motor clearly still in pieces however the bearing pack I bought came with the RHS/drive-side casing pretty much assembled - RHS crank shaft bearing, small idler gear and its clutch needle roller bearing were already assembled. This photo shows the new one at the top, old one below. You can see the new one already has the main motor needle clutch bearing pressed in - I removed the old one prior to buying the bearing kit, you can just make out the damage from the bearing needles on the old one.
IMG_20241004_153157_565 (Medium).jpg (239.66 KiB) Viewed 352 times
Beancounter
Next was to press this needle bearing into this gear:
IMG_20241006_151930_182 (Medium).jpg (201.77 KiB) Viewed 349 times
Easily done with the hydraulic press but you could probably do it just as easily tapping in with a hammer and drift.
And then fit it into this:
IMG_20241006_153806_618 (Medium).jpg (182.76 KiB) Viewed 349 times
This is a push-fit however my old one was all but seized together and was what made me decide on buying the hydraulic bench press.
IMG_20241012_130053_069 (Medium).jpg (189.42 KiB) Viewed 334 times
Beancounter
Next was to start working on the motor unit, first thing is to press in the LHS/non-drive side crank shaft bearing:
IMG_20241006_164640_589 (Medium).jpg (180.45 KiB) Viewed 344 times
IMG_20241006_164733_383 (Medium).jpg (171.67 KiB) Viewed 344 times
Remember to fit the new circlip as that's not mentioned in the How 2 video.
