Mechanical experts - Help needed.
Has thanked: 9828 times
Been thanked: 10145 times
Re: Mechanical experts - Help needed.
Yorick wrote: Fri May 10, 2024 3:47 pm I thought metric was metric. But no.
Had to buy a front brake lever guard for the Suzuki . So took the 12mm bolt out of the bar end and wandered into town to buy a longer one.
Bugger, it's a finer thread than standard 8mm :(
No shops had them.
So had to buy another guard with adapter kit.
50 of your feelthy Engleesh Quids :(
Pitch can vary. For example M10 x 1.25 pitch or M10 x 1.5 pitch.
Has thanked: 10265 times
Been thanked: 6886 times
Skub wrote: Fri May 10, 2024 4:15 pm
No shops had them.
Aye. That wobbled my memory a bit.
And I'm sick that the bloody guards weren't even checked :(
Has thanked: 2551 times
Been thanked: 6245 times
No shops had them.
Somewhere 'round here I've a little doodad I kept from Mercedes GP just to prove how daft F1 is sometimes. It's got MJ5* threads on the inside, MJ7 on the outside and a 95° countersink :D Nobody uses 7mm threads...except Mercedes F1. :obscene-birdiedoublered:
*WTF is an MJ thread? Exactly
porter_jamie
Has thanked: 253 times
Been thanked: 143 times
Post by porter_jamie »
It puts extra requirement on the root like a whitworth. So presumably better for strength and fatigue and so on
Druid
Has thanked: 276 times
Been thanked: 898 times
Post by Druid »
Mr. Dazzle wrote: Fri May 10, 2024 4:30 pm
Some Borg Warner turbochargers use M7x1.0 bolts. They need an 11mm spanner to undo them :roll:
Saga Lout
Has thanked: 565 times
Been thanked: 754 times
Post by Saga Lout »
Cousin Jack wrote: Thu May 09, 2024 2:04 pm...
Back in the day I would go down to my local ironmonger and tell him what I want and he would either produce one from the dusty recesses of he shop, or at least tell me what to search for elsewhere. Unfortunately ironmongers are no more.
Any ideas?
A year or so ago I had a similar problem. I don't remember whether I needed a nut to fit a screw or a screw to fit a nut, but I took the offending item to B&Q and the nice man there was very helpful. That's where I'd start.
Has thanked: 218 times
Been thanked: 689 times
Saga Lout wrote: Mon May 13, 2024 10:15 am
[/quote]
Most of the staff at B&Q won't know a screw from a nut....
Been thanked: 2286 times
David wrote: Tue May 14, 2024 10:39 am
[/quote]
And much of the stuff is now sealed in little plastic pouches, so no more try before you buy.
porter_jamie
have you done what i suggested?
porter_jamie wrote: Tue May 14, 2024 8:00 pm have you done what i suggested?
Not yet, I've been busy.
