State of the roads
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Re: State of the roads
Post by Bigyin »
I assume everyone is aware of my love for potholes after being lucky to survive hitting one a few years ago so clearly not the biggest fan.
Managed to clip one I couldn’t avoid on Saturday (narrow country road with oncoming traffic so couldn’t swerve enough) while out in the go faster roller skate and felt the steering was funny so drove straight to tyre place just in case as modern cars don’t have spare wheels or jacks anymore.
Good job I did as this was a couple of minutes after pulling in
Has thanked: 8042 times
Been thanked: 5695 times
Bigyin wrote: Fri May 10, 2024 8:35 am I assume everyone is aware of my love for potholes after being lucky to survive hitting one a few years ago so clearly not the biggest fan.
Oof! Tyre and rim OK?
Bigyin
Post by Bigyin »
Count Steer wrote: Fri May 10, 2024 8:47 am
Tyre was split on the inner sidewall, rim was ok if you don’t count the kerb marks which magically appear when the wife drives it. Suspension seems ok as well :thumbsup:
Has thanked: 2850 times
Been thanked: 1610 times
Funnily enough was just flicking through my phone and came across this pic - pothole on the M11 slip cost 2 AMG rims and 2 tyres!
Has thanked: 12608 times
Been thanked: 8539 times
Pah. This is a proper knackered tyre. Had to drive it a mile to road.
Yorick wrote: Fri May 10, 2024 11:23 am Pah. This is a proper knackered tyre. Had to drive it a mile to road.
Cheap Romanian rubber :thumbup:
v8-powered wrote: Fri May 10, 2024 12:33 pm
I was in the volcanoes and got puncture from sharp rock in sidewall.
Couldn't get wheel off so had to drive to civilisation for signal.
I knew the engine would damage the front tyre, so put in 4WD to lessen the load.
When I got a signal, I found out that you have to partially undo all wheel nuts, then drive about 20 yards until wheel frees itself from the hub.
Has thanked: 2908 times
Been thanked: 1678 times
Rockburner wrote: Thu May 09, 2024 11:25 am Yup - on the ride up to Box last night the roads were terrible. At times I actually thought the rear wheel had come loose it was wandering around so much.
Wet winter, and shitty repairs haven't helped.
I stopped on a ride the other day - I thought the rear wheel bearings had gone. Everything checked out fine, so I can only assume it was the road surface.
I used to do pre-training season checks on the roads, and make adjustments if there was a particularly poor stretch I could bypass. Now, there are no good surfaces left.
I've lost count of how many tyres we've had to replace on the car.
Last edited by The Spin Doctor on Fri May 10, 2024 2:10 pm, edited 1 time in total.
Has thanked: 7623 times
Been thanked: 5930 times
Mountain300 wrote: Thu May 09, 2024 6:46 pm In Devon we are now playing spot the tarmac!
We used to drive on the left of the road. Now it's on what's left of the road.
Has thanked: 3005 times
Been thanked: 2522 times
Just had the good news that braking and hitting a pothole has fubared one of my front calipers, so new caliper plus discs and pads. Oh joy, I love living in s 3rd world country.
I received my first ever pothole related damage recently.
It's also the first time I've had a car with 19" wheels and 245 section low profile tyres.
I wonder if those things are related :hmmm:
Has thanked: 10964 times
Been thanked: 3996 times
Cousin Jack wrote: Fri May 10, 2024 3:09 pm Just had the good news that braking and hitting a pothole has fubared one of my front calipers, so new caliper plus discs and pads. Oh joy, I love living in s 3rd world country.
Damaged the calliper?? Is this on your car? wow. :wtf: :wtf:
You can generate enormous torques at the wheels with potholes and the like. The most onerous load case on a racing car drive shaft, by miles, is riding the kerbs on full power...the on/off/on/off/on/off nature of it as the wheel gains and loses grips easily exceeds what the engine can do on a smooth road by 100% or more.
Same goes for being on the brakes and encountered a sudden step change in grip.
Whysub
Has thanked: 1276 times
Been thanked: 1014 times
Post by Whysub »
The roads in (most of) Spain are very well maintained. Even the 8km cul-de-sac i live on gets repaired if it gets damaged by one of the lorries transporting the oranges away from the groves.
Whysub wrote: Mon May 13, 2024 2:07 pm The roads in (most of) Spain are very well maintained. Even the 8km cul-de-sac i live on gets repaired if it gets damaged by one of the lorries transporting the oranges away from the groves.
The roads around here are terrible. Cadiz/Jerez. Dunno why.
Ian
Has thanked: 1361 times
Been thanked: 578 times
Post by Ian »
A side effect I've noticed ( particularly between Dane End and Buntingford when visiting rellies) is Range Rovers coming the other way on the wrong side of the road presumably because they are wary of going through a puddle in case there is a big pothole under the water.
Hot_Air
Has thanked: 1454 times
Been thanked: 288 times
Post by Hot_Air »
That makes two of us lucky to be alive because of a pothole.
MyLittleStudPony
Has thanked: 832 times
Been thanked: 586 times
Post by MyLittleStudPony »
I had a tyre losing pressure on my Arteon due to damage to the wheel. I got a wheel goon to brae is straight for 40 quid.That's the price you pay for rolling on sweet 20s.
Scootabout
Has thanked: 587 times
Been thanked: 373 times
Post by Scootabout »
Remember how, in the '70s, everyone drove Citroens with hydrolastic (?) suspension, because of the appalling state of French roads? Well the situation's reversed now, except that here it's 4x4s instead of Citroens.
Incidentally, I'm just back from a weekend's riding in Wales. Isn't Wales supposed to be poorer than England? If so, it's not reflected in the road surface quality. I noticed the difference as soon as I crossed the border.
MyLittleStudPony
Decent road surfaces - Brexited away!
