Why would a bleed nipple leak, when tightened.
Has thanked: 9819 times
Been thanked: 10144 times
Re: Why would a bleed nipple leak, when tightened.
Mr. Dazzle wrote: Tue Mar 05, 2024 12:45 pm
wull wrote: Tue Mar 05, 2024 12:28 pm almost 100% of the time it stops.
Just what you want from your brakes of course :thumbup:
Pah,Wull never bothers with those brake thingies,they only slow him down. :thumbup:
katana
Has thanked: 68 times
Been thanked: 36 times
Post by katana »
dern wrote: Tue Mar 05, 2024 10:36 am
You should really pull that bleed screw out and make sure the seat, taper, thread and bore are clean and intact. I'd want to know or at least to be sure that it's ok, things don't fix themselves.
Seeing as the brakes have been cable tied a few times an no more issues, all I can thing that I didn't tighten the nipple the first time.
wull wrote: Tue Mar 05, 2024 12:28 pm After bleeding brakes you sometimes have fluid left within the thread area that works its way out, the thread area is tapered so some fluid gets trapped in there and seeps out, I’ve had this quite a few times, all you do monitor it for a few days and almost 100% of the time it stops.
Monitoring every day, some times twice.
