Cutting rectangle holes in 1.8 OSB wood
formula400
Has thanked: 444 times
Been thanked: 863 times
Re: Cutting rectangle holes in 1.8 OSB wood
Post by formula400 »
Looks easy enough
I’ll come back with my wonky holes 🤣🤣🤣
CBR650r :mrgreen:
Been thanked: 2612 times
formula400 wrote: Wed Jan 24, 2024 11:50 am Ok cool, a few different routs to go. I already have a jigsaw and drill.
I like the box cutter, but most of what I need to cut will be rectangular.
What will give me the cleanest finish??
A cnc laser cutter.
I'd use a multitool, but then I'm not on building site and I've got ear defenders. Plus my multitool doesn't have to be run at full chat. And I don't have a jigsaw.
Has thanked: 2550 times
Been thanked: 6241 times
cheb wrote: Wed Jan 24, 2024 12:01 pm
A cnc laser cutter.
Wire erosion FTW!
Has thanked: 7810 times
Been thanked: 2527 times
A decent blade in the jigsaw, would be my guess.
Has thanked: 1346 times
Been thanked: 1722 times
Decent blade in the jigsaw and knock the orbital action setting to zero.
Its a slower cut but neater.
The faceplate on most sockets covers a few mm outside the hole anyway.
A cnc laser cutter.
Mover over puny multitool and let the chainsaw have a go.
A 100mm 18V pruning saw is perfect for cutting holes in a wood cladding. Easily controllable for depth and no fumes either. Apart from the delicate smell of cut cedar wood.
Has thanked: 6375 times
Been thanked: 4746 times
Funnily enough, re cutting squares/rectangles, this just popped up on IG. Can't decide if it's genius or silly. :lol:
wheelnut
Has thanked: 905 times
Been thanked: 999 times
Post by wheelnut »
Count Steer wrote: Mon Jan 22, 2024 5:59 pm Or, you can pull the sockets and switches off and mount them on the new interior boards if they're surface mounted types.
You can't do that with the windows, obvs. :lol:
That would be my suggestion, just a drill a hole for the cable and mount new sockets and back boxes.
Has thanked: 143 times
Been thanked: 497 times
Post by Silly Car »
Router with bearing guided bit, drill a hole and run it around the inside of the back boxes. Cut out screw lug sections with Stanley knife. Can do the same around windows and doors. That or simply surface mount switches and sockets and cut boards before fitting around windows and doors.
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Post by Yambo »
:lol: I know it's not OSB but you have to think outside the box!
Has thanked: 2402 times
Been thanked: 3625 times
Which is why the back boxes for french power sockets are circular. Just use a core drill or hole cutter (depending on substrate) of the right size and you're good to go.
mangocrazy wrote: Fri Feb 23, 2024 1:26 pm Which is why the back boxes for french power sockets are circular. Just use a core drill or hole cutter (depending on substrate) of the right size and you're good to go.
We don't want any of your "intelligent" ideas here!!
Modern fast fix lighting back boxen can be circular.
What happens with a Fronch double socket then? Massive circular hole? Or do they just not have 'em?
Two circular holes, maybe opened out to a stadium shape.
Mr. Dazzle wrote: Sat Feb 24, 2024 10:17 am What happens with a Fronch double socket then? Massive circular hole? Or do they just not have 'em?
It's as cheb says, kinda like an oblong with rounded edges. Alternatively two circular holes side by side. You can buy single or double back boxes, as in UK.
In fact you can buy triples, as well...
