shed insulation using polystyrene sheets
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
Re: shed insulation using polystyrene sheets
Something like this ?? https://www.screwfix.com/p/soudal-geniu ... lsrc=aw.ds
What kind of vapour barrier???
Does it go barrier/insulation sheets/OSD? Or insulation sheet/ barrier/OSD
CBR650r
- Has thanked: 1346 times
- Been thanked: 1722 times
Inside to outside.
OSB, vapour barrier, then insulation sheets between the studs.
I usually staple the vapour barrier to the studs(as few staples as you can get away with) then the OSB over it. Oh don't forget to tape the joints on the vapour barrier
One place I worked at had what was called Smartply which is OSB thats got a solid plastic surface that acts as a vapour barrier and you just tape the joints up but I've been told it was very expensive, not sure how much I believe that.
Thick enough OSB and you can put a screw in it anywhere for shelves/whatever.
Oh and I always use Gun grade foam, partly because I already have the gun but I use a lot of it pretty regularly so its in my interests to have the gun which can be shut off without wasting the rest of the tin.
I don't take a tin off the gun til I have another one ready to go on, hardly ever need the cleaner.
I never ever leave the gun without a tin of foam on it.
I clean the end of the nozzle by rubbing on timber as it cleans it without unnecessary abrasion that knackers the front valve.
Oh and I never lend them to fucking divvys.
- Has thanked: 2550 times
- Been thanked: 6241 times
I've lent a few out and theres always some rivet who runs the foam out and leaves it empty, or removes the can and can't find another or just so dense that they remove the old can and bugger off to have their butties so whatever is left in the gun goes off and thats my 20 quid gun knackered.
Oh and the best gun I've had yet is made by Yato and has a PTFE coated valve and the bit the can screws into is PTFE coated as well.
Lasts way better than any other, as long as you follow those rules up there ^.
- formula400
Something like this???
https://www.screwfix.com/p/no-nonsense- ... -gun/28483
Never used anything like it before
CBR650r
- formula400
demographic wrote: ↑Sun Nov 19, 2023 11:41 am Inside to outside.
Would this be what I want https://www.screwfix.com/p/capital-vall ... x-4m/59191
CBR650r
- Has thanked: 6375 times
- Been thanked: 4746 times
I reckon that'd do. You may need a few. Hardly seems worth buying a gun if you are unlikely to use it again.formula400 wrote: ↑Sun Nov 19, 2023 11:14 am Something like this ?? https://www.screwfix.com/p/soudal-geniu ... lsrc=aw.ds
PS if you haven't got a staple gun and are likely to be cycling anywhere near the Surrey Hills in the near future you can borrow mine.
- formula400
Last question
Timber that I’ll be filling is 60mm, sheets of foil backed insulation is 50mm
Is that gap ok?
Is that gap ok?
CBR650r
- formula400
Count Steer wrote: ↑Sun Nov 19, 2023 12:43 pmCheers for the offer, but unsure when I am out that wayformula400 wrote: ↑Sun Nov 19, 2023 11:14 am Something like this ?? https://www.screwfix.com/p/soudal-geniu ... lsrc=aw.ds
CBR650r
- formula400
Count Steer wrote: ↑Sun Nov 19, 2023 12:43 pmI reckon that'd do. You may need a few. Hardly seems worth buying a gun if you are unlikely to use it again.formula400 wrote: ↑Sun Nov 19, 2023 11:14 am Something like this ?? https://www.screwfix.com/p/soudal-geniu ... lsrc=aw.ds
CBR650r
If you're buying one I can recommend the Bosch cordless. It should be man enough for the job and it's not a hulking big thing so it's nice to use if you're doing a fair number of staples. They're about £57 though.formula400 wrote: ↑Sun Nov 19, 2023 1:37 pmCount Steer wrote: ↑Sun Nov 19, 2023 12:43 pmI reckon that'd do. You may need a few. Hardly seems worth buying a gun if you are unlikely to use it again.formula400 wrote: ↑Sun Nov 19, 2023 11:14 am Something like this ?? https://www.screwfix.com/p/soudal-geniu ... lsrc=aw.ds
formula400 wrote: ↑Sun Nov 19, 2023 12:22 pmdemographic wrote: ↑Sun Nov 19, 2023 11:41 am Inside to outside.
The black stuff is usually thicker than you actually need for walls as its for floors before the concrete goes down and gets stood on a bit through the process.
Mind, the stuff we often end up with is so thin that it doesn't staple well so the black stuffs better than that.
- formula400
Just in B&Q 2.4 x 1.2m is bloody huge
Not sure what I was expecting
Basically going to get a little bit and order the rest on line
- IMG_3259.jpeg (821.9 KiB) Viewed 512 times
CBR650r
- Has thanked: 2402 times
- Been thanked: 3625 times
Don't get expanded polystyrene - it's shit. Celotex/Kingspan etc is the stuff to go for.
Agreed. Jablite is polystyrene I believe.mangocrazy wrote: ↑Sun Nov 19, 2023 4:37 pm Don't get expanded polystyrene - it's shit. Celotex/Kingspan etc is the stuff to go for.
- formula400
I got a few small sheets of this to see how I get on.
https://diybuildingsupplies.co.uk/produ ... KIQAvD_BwE
What have I learnt from this small endeavour already
Don’t use a saw, use a small sharpe knife nicked from the kitchen. Much much cleaner
- IMG_3263.jpeg (404.99 KiB) Viewed 490 times
CBR650r
Wait until Chef finds out what you've been doing with his /her knives.formula400 wrote: ↑Sun Nov 19, 2023 7:29 pm I got a few small sheets of this to see how I get on.
- formula400
2 of 18 roof bits done
Where should I be stapling the vapour barrier
- IMG_3266.jpeg (500.52 KiB) Viewed 482 times
CBR650r
Through the vapour barrier onto the studs. So they hold the vapour barrier holds on til yer fixing the OSB on.
Oh and make sure theres something to fix the OSB to, especially on corners.
