heated gloves
Has thanked: 6238 times
Been thanked: 5120 times
Re: heated gloves
KungFooBob wrote: Tue Oct 31, 2023 8:47 pm ... but the waistcoats go under kit anyway.
Be wary of any gear that has a high collar, make sure it fits under your outer gear. If a zip together two piece suit, try that too.
Also, if you buy a heated item powered from the bike and you wear a one piece oversuit, you'll need to get the lead in somehow. If it has a two-way zip, that might be an option. Otherwise, a hole in a pocket inner. For my one piece, I made up an extension lead.
[Edited for clarity ;) ]
Has thanked: 541 times
Been thanked: 7594 times
Re: heated gloves
All the Workwear stuff is battery powered.
You can't have your chippy tethered :)
Beancounter
Has thanked: 2872 times
Been thanked: 554 times
Re: heated gloves
Post by Beancounter »
Horse wrote: Tue Oct 31, 2023 10:15 pm
I've got two heated jackets, one from Keis and another from Blazewear. The Keis has a softshell quality to it which is great for off the bike, it's also better at retaining heat but the thicker collar means I can't fully zip up my jacket. The Blazewear is thinner and feels lesser quality but it fits easier under any jacket and has better heat output.
I've got a pair of Gerbing heated gloves which connects to both jackets. They're warm enough to burn your hands slightly - unfortunately I can't control the heat setting on the gloves because I'm not using them with a Gerbing jacket (my own fault - I got the gloves cheap from a mate).
Heated vest/jacket is the first thing, then gloves if needed.
formula400
Has thanked: 444 times
Been thanked: 864 times
Re: heated gloves
Post by formula400 »
Kies gilet and heat controller ordered.
quite excited about getting it.
CBR650r :mrgreen:
Re: heated gloves
formula400 wrote: Wed Nov 01, 2023 7:44 pm
When I bought mine (an EXO2 no longer available), I was shocked how hot it got (it would then switch off until it got cool, then heat up again - like a heat massage).
But even more shocking that it showed how much heat you can lose when riding.
formula400
Re: heated gloves
Fitted the power cables Sunday and gave it a test today in 7oc
Decent. Provides good warmth. Low and medium are good, i out it on high for 5 mins and it’s proper warm.
Looking forward to see how it performs once it’s proper chilly.
Only complaint is that there are not heating elements on the tops of the shoulders.
CBR650r :mrgreen:
