Oil change regardless..🤷🏻‍♂️
DefTrap
Has thanked: 2276 times
Been thanked: 2199 times
Re: Oil change regardless..🤷🏻‍♂️
Post by DefTrap »
It's fairly easy to do so people do it.
Because secretly they're ashamed they couldn't-be-arsed/arent-able-to to change the brake fluid and the coolant.
Has thanked: 541 times
Been thanked: 7594 times
DefTrap wrote: Sun Oct 01, 2023 9:03 pm It's fairly easy to do so people do it.
If it wasn't for this dash idleness I'd find and post the meme of the 20,000 mile fork oil being shocked at the purchase of a new loud exhaust.
Has thanked: 609 times
Been thanked: 4133 times
I wonder how many of the people who change their engine oil by time do the same with their fork oil and brake fluid?
Though I've used brakes with 30 year old brake fluid in them with no problems
I seem to recall that a lot of manufacturers also recommend rubber brake hose replacement every 4-5 year, wonder how often that happens?
Probably never, my GSX-S 750 had all it's brake fluid replaced on it's 15000 mile service, the brakes felt better after the service.
MyLittleStudPony
Has thanked: 629 times
Been thanked: 412 times
Post by MyLittleStudPony »
I do get the brake fluid changed on my cars now because de children is de most important ting!
MyLittleStudPony wrote: Sun Oct 01, 2023 9:27 pm I do get the brake fluid changed on my cars now because de children is de most important ting!
I believe the children are our future.
MyLittleStudPony
KungFooBob wrote: Sun Oct 01, 2023 9:28 pm
Mine are all very self centred little sods. I've had to buy a seven seater too as there's so many of them now. :o
Has thanked: 604 times
Been thanked: 2470 times
Le_Fromage_Grande wrote: Sun Oct 01, 2023 9:15 pm I wonder how many of the people who change their engine oil by time do the same with their fork oil and brake fluid?
I've never changed the brake fluid in any vehicle. :banana-wrench:
MyLittleStudPony wrote: Sun Oct 01, 2023 9:33 pm
You've fucked the planet. Each one will potentially have another seven, all carboning like a boss. dropping plastic shit in the ocean and insisting on single person transport.
SHAME ON YOU!
Been thanked: 2628 times
And the polluters will pay. Have they got used to textured insect protein yet?
Has thanked: 262 times
Been thanked: 1278 times
porter_jamie wrote: Sun Oct 01, 2023 7:53 pm You want steam Inside your engine?
Loads of water vapour passes through the crankcase of any running engine. Suspended water being boiled out of the oil and expelled by the breather is a continuous and necessary process.
Water in engine oil in a vehicle stored somewhere damp can be a problem (eventually), but it comes from condensation on the metal engine surfaces, rather than any hygroscopic effect.
Has thanked: 2415 times
Been thanked: 3659 times
KungFooBob wrote: Sun Oct 01, 2023 7:38 pm I'm 50/50 on this.
I'm more 15/50. On the Falco at least.
mangocrazy wrote: Mon Oct 02, 2023 8:54 am
Go thick, or go home.
Has thanked: 3286 times
Been thanked: 1738 times
I change my oil on mileage or every other year,which ever comes first.When I was trucking the fitters took samples of the engine oil & sent it for testing, I think it got changed when it's acid content got high.
One of my mates does the annual MOT & service on my car & when I've asked him,he says that when he drops the oil in my car it's always clean,we put that down to me doing very little short journeys & the commute was 15 miles each way so everything was always at operating temperature.I think that if you do short journeys the condensation builds up quickly & has a negative effect on things.I very rarely do a short ride or drive & never do that run the bike for a few minutes in winter thing.
How often do people change their injection hose? To my knowledge my 2008 SV650 has never had the injection lines changed.
JackyJoll wrote: Mon Oct 02, 2023 8:59 am
10/60 on the KTM...
Bustaspoke wrote: Mon Oct 02, 2023 9:03 am How often do people change their injection hose? To my knowledge my 2008 SV650 has never had the injection lines changed.
I changed the fuel hose on the 888 and the VFR a few years back and was glad I did. Both sets of hoses were original and had gone very brittle, but neither set of hoses had been designed for ethanol, which was the main reason I changed them.
Using expensive 20W/50 in my ancient Triumph engine.
MyLittleStudPony
KungFooBob wrote: Sun Oct 01, 2023 9:57 pm
SHAME ON YOU!
cheb wrote: Mon Oct 02, 2023 7:54 am
Despite knocking the old work on the head, I'm still embraced to the warm bosom of the Fixers Flourish scheme.
mangocrazy wrote: Mon Oct 02, 2023 9:17 am
That reminds me,on the SV650 there's a small length of hose between the throttle bodies,on the forum people occasionally post about some fuel leak & this small piece of hose is the problem.So far mine's been good :thumbup:
