1100's were single plug, 1150's went dual plug about 03.v8-powered wrote: Sun Aug 13, 2023 10:35 am Could be single spark or twin spark head? Think the 1100's were a 50/50 mix, dependent on build year.
NBT: BMW (lack of) Power
Bigjawa
- Has thanked: 225 times
- Been thanked: 969 times
Re: NBT: BMW (lack of) Power
- Has thanked: 2849 times
- Been thanked: 1609 times
Some of the later 1100's were twin too apparently?Bigjawa wrote: Sun Aug 13, 2023 2:47 pm1100's were single plug, 1150's went dual plug about 03.v8-powered wrote: Sun Aug 13, 2023 10:35 am Could be single spark or twin spark head? Think the 1100's were a 50/50 mix, dependent on build year.
EDIT: December 2002 onwards models apparently, not sure what mine is - will see when it arrives.
- Has thanked: 20859 times
- Been thanked: 13679 times
I’m pretty sure I spied one of those in the loft of plenty the other week. If you need to use one I’ll check it wasn’t a figment of my imagination…Demannu wrote: Sat Aug 12, 2023 12:11 pm Oh, don't forget to buy a twin max balancer, essential for all bimmer flat twin owners!
- Pirahna
- Has thanked: 3010 times
- Been thanked: 1749 times
I had one, bought it barnd new in 2001 it exploded in 2003 at 60k miles, melted both pistons on the way home from work one evening. The bike seemed to enjoy regular trips to the dealer to fix stuff with tools a home mechanic wouldn't have. The most expensive to own bike I've ever had, I vowed never to own another BMW. I used it for daily commuting, I would highly recommend a backup bike if this is your plan.
Standard they run very, very lean. I would recommend changing the fuel pressure regulator for one from the K1200. As mentioned, Twinmax is essential.
Looking at the pic it looks standard. I think the centre stand was an optional extra, so quite normal to find them without.
Demannu
- Has thanked: 65 times
- Been thanked: 1234 times
As an aside, it's the only bike I've ever hit the limiter in top on, and the BB chip gave it another 500rpm as well!
Draughting a zx9r down the autobahn 145......46................47 duh duh duh 45..............................42.......................38 as the tow was broken
Bet the zx was still in 5th!
Demannu
Mine 'failed to proceed' just the once In the 35k i put on it.Pirahna wrote: Mon Aug 14, 2023 5:09 pm The bike seemed to enjoy regular trips to the dealer to fix stuff with tools a home mechanic wouldn't have.
Stuttered to a stop after pulling a minger of a mono. Fixed it at the side of the road with the supplied toolkit (somehow the ECU plug had come loose, too many crack handed wheelies I suspect).
Only issues I ever had were the paralever bearings failing, and they were BMW only, so had to schtum up £36 a time!
- Bigyin
- Has thanked: 1436 times
- Been thanked: 2738 times
I like that in the weird way as an ex GS1150 owner.
Enjoy confusing pursuing bikes by trail braking into corners
- Has thanked: 10964 times
- Been thanked: 3995 times
Or not breaking at all!Bigyin wrote: Mon Aug 14, 2023 11:18 pm I like that in the weird way as an ex GS1150 owner.
Enjoy confusing pursuing bikes by trail braking into corners![]()
Almost sounds like.me justifying buying another bike to the missus, lower maintenance costsRockburner wrote: Tue Aug 15, 2023 7:38 amOr not breaking at all!Bigyin wrote: Mon Aug 14, 2023 11:18 pm I like that in the weird way as an ex GS1150 owner.
They have good engine braking, if you're at all smooth in your riding style, then you will hardly need the brakes.
Monokey box purchased, shall ditch the side cases and consign them to the garage shelf.
On the look out for some smoked indicator lenses and then that will probably do me.
Well the tractor has arrived - very happy with the condition, better than the 10 years newer Triumph I've traded against it! Added bonus - it has a decat fitted, just need to open ECU and see what chip is fitted.
Bummer is I can't use it until the V5C arrives - I stupidly insured against the cherished plate I have on my bike but until the V5C arrives, I can't assign the plate. Twat......
- Has thanked: 8039 times
- Been thanked: 5694 times
Demannu
Do you see what I mean about a disc lock?
Those mudguards are made out of unobtainium and costalotium, be warned!
- Has thanked: 7622 times
- Been thanked: 5930 times
When using a disc lock:Demannu wrote: Fri Aug 18, 2023 5:48 pm Do you see what I mean about a disc lock?
1. ALWAYS position it so the wheel is unable to rotate more than, at most, a very small amount before hitting the caliper
2. ALWAYS use one of those 'curly cables' from lock up to the bars
3. NEVER change your mind and decide, instead of wheeling backwards, to ride a feet-up U turn out of the space
DAMHIK
Demannu
Dont feel too bad about it.Horse wrote: Fri Aug 18, 2023 6:09 pmWhen using a disc lock:Demannu wrote: Fri Aug 18, 2023 5:48 pm Do you see what I mean about a disc lock?
DAMHIK![]()
You could have been my 'mate' who, in an attempt to impress everyone at the bike meet, gave it the beans away from the meet, obviously forgetting about his latest security purchase. Cue one very second hand 1000rx on the n/s and about 300 people roaring with laughter!
Same part on the Rockster.... I used to have a spare but must have sold it at some point....Demannu wrote: Fri Aug 18, 2023 5:48 pm Do you see what I mean about a disc lock?
Not 100% sure TBH, my cheapo disc lock fits? Guess the mudguards are carbon but to be fair they could do we a rub down and re-lacquer.Demannu wrote: Fri Aug 18, 2023 5:48 pm Do you see what I mean about a disc lock?
And for those that are really interested, build list. Wider rear wheel, sports suspension etc
Demannu
Its the front edge of the mudguard you have to worry about, especially if 'someone' tries to move your bike
And look at you Mr Black motor, ooooooh lardy dah!
Forgot to mention, drop a hid in the dip side, you'll thank me!
