Bike security thread
Has thanked: 1349 times
Been thanked: 1726 times
Re: Bike security thread
KungFooBob wrote: Wed Aug 02, 2023 8:30 pm My GP100 got nicked from the works carpark!
Dunnowotyeronabout, I don't know nuffink.
Been thanked: 7537 times
demographic wrote: Wed Aug 02, 2023 8:44 pm
Actually, I'm confused.
My KC100 got nicked from the works carpark, the GP100 got stolen from my 'rents garage when the centre lock of the up and over door got punched out. They got my mums TS50X at the same time.
KungFooBob wrote: Wed Aug 02, 2023 8:46 pm
I had to Google KC100, looks a bit like the YB100 I had.
I remember KH 100 and KE100's but couldn't remember the KC100. None of my mates had one.
Has thanked: 9835 times
Been thanked: 10148 times
Yorick wrote: Wed Aug 02, 2023 8:22 pm Early 80s RD Yams were easy to steal.
Unscrew the headlight and disconnect the ignition switch connector.
Bike starts
Same with some early Kawasaki strokers. Unplug or cut the black/white wire from the ignition switch and you're away.
Has thanked: 1750 times
Been thanked: 2085 times
These same crimes continue, decade after decade. Are we doing something wrong. ? 🤔
Has thanked: 15970 times
Been thanked: 10249 times
You can even buy theYamaha immobiliser bypass units on eBay! :roll:
loading screen 6 banner
Has thanked: 599 times
Been thanked: 2449 times
demographic wrote: Wed Aug 02, 2023 8:15 pm
MrLongbeard wrote: Wed Aug 02, 2023 2:12 pm Keyless for the win
Lots of Landrover owners might disagree.
Fairly well known exploit regarding some types of keyless ignitions.
Although what they end up with might protect you?
£5 faraday bag soon stops that, an obvious solution as not keeping your car keys next to the letter box
Taipan wrote: Wed Aug 02, 2023 9:08 pm You can even buy theYamaha immobiliser bypass units on eBay! :roll:
It is, or was a designed feature on Triumph alarms / immobilisers
Has thanked: 2552 times
Been thanked: 6257 times
MrLongbeard wrote: Wed Aug 02, 2023 9:51 pm
Another obvious one is keys which turn themselves off after lack of movement for a minute or two.
Relay theft. I turned keyless access off on my car.
Has thanked: 6198 times
Been thanked: 5088 times
Many cars (including top marques) have canbus connections easily accessible.
www.autoblog.com/amp/2023/04/18/vehicle ... od-update/
Dodgy69 wrote: Wed Aug 02, 2023 9:00 pm These same crimes continue, decade after decade. Are we doing something wrong. ? 🤔
Us, or manufacturers?
Has thanked: 1947 times
Been thanked: 1292 times
Post by Jody »
Bike starts
DT125's were even easier, reach in behind the headlight, pull the plug for ignition switch and it will start !
Has thanked: 2554 times
Been thanked: 2287 times
Pah! My first bike's 'key' was flat, no grooves, no serrations, nothing. I lost it so just used a screwdriver. BSA does not stand for Bike Secure Accesss.
Has thanked: 10272 times
Been thanked: 6889 times
Cousin Jack wrote: Thu Aug 03, 2023 9:06 pm Pah! My first bike's 'key' was flat, no grooves, no serrations, nothing. I lost it so just used a screwdriver. BSA does not stand for Bike Secure Accesss.
I always thought it was Bits Stuck Allover
Yebut they weren't stuck that well, bits tended to fall off.
