Luggage solutions
Has thanked: 2555 times
Been thanked: 2290 times
Re: Luggage solutions
No idea how the universal plate works and if you could use that, or adapt this plate without the 'arms' to your rack. I probably couldn't but some on here I'm sure can as they not as engineeringly challenged as me.
The Universal plate is included with the Givi Monolock (the smaller/lighter/cheaper version) and bolts on top of an existing luggage rack with U-bolts. With the Monokey boxes you must buy a separate plate and arms to mount it. Watch out, Monokey boxes and Monolock boxes are NOT the same fitting!
Has thanked: 4364 times
Been thanked: 2853 times
I've just had a look at the universal plate video, it mentions tubular racks but not existing plate racks, but from the vid might it work bolting it through the holes in your existing plate? If it does all you'll need is the top box
dern
Has thanked: 1017 times
Been thanked: 1782 times
Post by dern »
This is my bike with a 47l monokey box...
It's been brilliant for commuting. I can get everything I need in it in terms of laptops, spare clothes and the like. It's never leaked and I'm never worried about leaving stuff in it. You can definitely feel it in the corners if it's full though.
Has thanked: 839 times
Been thanked: 1242 times
I had an Oxford tail pack before I got a top box, it did the job but was a pain to fit and remove without me worrying about it falling off. You'll also need something to protect your paintwork as the straps will rub.
