Rear wheel installation
Re: Rear wheel installation
Stick with a correct size block of wood, for rear wheels anyway, that’s just looks like something else you have to hold and fiddle with to line up (as said above captive spacers make a huge difference)Noggin wrote: ↑Thu Oct 27, 2022 4:07 pmWow!! I want one!! No idea when I might take out and replace a rear wheel again, but DAMN that would make life easier (especially as my right arm won't be much help next time!!!)bernieeccles wrote: ↑Thu Oct 27, 2022 3:20 pm https://www.screwfix.com/p/hedgehog-eas ... lsrc=aw.ds
- Has thanked: 16257 times
- Been thanked: 3745 times
I used to use my boot, a bit of wood and both arms/hands to manhandle the wheel on to my boot then the wood and get the spindle throughmel wrote: ↑Thu Oct 27, 2022 8:38 pmStick with a correct size block of wood, for rear wheels anyway, that’s just looks like something else you have to hold and fiddle with to line up (as said above captive spacers make a huge difference)Noggin wrote: ↑Thu Oct 27, 2022 4:07 pmWow!! I want one!! No idea when I might take out and replace a rear wheel again, but DAMN that would make life easier (especially as my right arm won't be much help next time!!!)bernieeccles wrote: ↑Thu Oct 27, 2022 3:20 pm https://www.screwfix.com/p/hedgehog-eas ... lsrc=aw.ds
From what I remember, there's no way I could do it with only one good arm and a 50% able arm!! So, if I can roll the wheel onto an airbag thingy and then pump it up to get to the correct level, that just seems way easier.
Just have to hope that I don't need to do it I think!!
you put the wood in first, not any bit of wood , needs to be the correct height, then roll the wheel on the wood into place lob the chain over the sprocket so it hangs on inside and then put the spindle through- as said above captive spaces are the big ticket item ,whichever way you go about it there the game changer itemNoggin wrote: ↑Thu Oct 27, 2022 8:43 pmI used to use my boot, a bit of wood and both arms/hands to manhandle the wheel on to my boot then the wood and get the spindle through
- Has thanked: 1707 times
- Been thanked: 2011 times
How do you get the rod through. ?? I'm in the piece of wood gang, it's a faf but it gets done in the end.
Oh totally. A friend was planning to cut me 'the right' piece of wood, but until then I had to use myfoot to 'help' the wheel up onto a piece I had that was the right height. I did change the rear wheel on the 10 quite often (trackdays etc) but only for about a year and only towards the end of the year, did I get the advise about the right kind of bit of wood!! LOLmel wrote: ↑Fri Oct 28, 2022 12:13 amyou put the wood in first, not any bit of wood , needs to be the correct height, then roll the wheel on the wood into place lob the chain over the sprocket so it hangs on inside and then put the spindle through- as said above captive spaces are the big ticket item ,whichever way you go about it there the game changer itemNoggin wrote: ↑Thu Oct 27, 2022 8:43 pmI used to use my boot, a bit of wood and both arms/hands to manhandle the wheel on to my boot then the wood and get the spindle through
TBF, even with a correct 'ramp' type piece of wood, you still need both arms to be pretty usable, which one of mine isn't!!!
When I was an AA patrol a big screwdriver and a bent coathanger did the job. Mind you that was a long time ago. Although it still worked when my wife left her headlights on and the battery flattened so the remote locking wouldn't unlock.......
Noggin wrote: ↑Fri Oct 28, 2022 9:04 ammel wrote: ↑Fri Oct 28, 2022 12:13 amTechnical term - ur #u#k#d then- little no chance with one arm- you could have best spacers ,bit of wood , crap air bag thingy and still would not do itNoggin wrote: ↑Thu Oct 27, 2022 8:43 pm
Plan b get someone to hold the wheel and you put spindle in,quite often mrs Mel did it when racing , she only threw it once ( castle Combe) when I shouted at her “ which f ing way do you want it lifted
mel wrote: ↑Fri Oct 28, 2022 4:18 pm
I am really hoping to not need to do changes for a while. I did struggle to change it on my own before, but as you say, not gonna be likely or easy now. If I need to do anything like that on the monster I'll just have to call in help!! LOL
- Has thanked: 2632 times
- Been thanked: 1498 times
I used to do the boot under the wheel but since the hip started playing up, that's not really an option any more.
The method I figured out (after the 'adjustable wheel stand' turned out not to be adjustable low enough) is to use a tie-down strap over the seat and through the wheel. It's easy enough to get it to the right height and there's fore-and-aft moment too to help guide the spindle home.
- Has thanked: 1446 times
- Been thanked: 1331 times
I need to source another piece of wood for the ZX11. I have a piece of 4x8 for the ZRX11, but it looks like a piece of planed down 2x will work on the ZX owing to the wheel being a LOT closer to the ground on the main stand than the ZRX wheel is on the Pitbull.
On the "wooden tools" front I also have a piece of 2x to support the rear of the gastank on the ZRX while I faff about disconnecting the gubbins under it & a longer piece to go under the kickstand on the ZX11 so it doesn't lean over like a drunk.
- Has thanked: 3135 times
- Been thanked: 1624 times
This afternoons task was changing the rear sprocket on the Street Triple
I wasn't overly enthusiastic about doing the job,remembering what a PITA it was getting the rear wheel back in last time,then I realised I ended up using a specific piece of wood.Still an awkward job,but nowhere near as bad as the first time I did it without the right piece of wood.
It's surprising what unlikely objects end up becoming 'workshop essentials'
- Has thanked: 9680 times
- Been thanked: 9700 times
I bought a set of captive spacers and a bit of 20mm bar,the same diameter as the rear spindle. I forgot I had a set on the 10R,very handy.
I used the 20mm bar to hold the calipers carrier on the far side,stuck the wheel in and used the hydraulic bleed on the skylift to get the height for the spindle. No three hands juggling. Bingo.
- Has thanked: 2319 times
- Been thanked: 3373 times
I did mention that you'd wonder how you ever managed without the Skylift...
Had to refit the rear wheel on my XBR500 yesterday. Missing my wedge I had to call on my wife to give assistance. I'm not as strong as I once was, and getting the chain adjusters in was a real pain. I'm amazed that Honda and other manufacturers, despite brilliant design in so many areas, didn't copy QD rear wheel designs such as the Norton Commando. In fact it's almost there with the shock absorbing rubbers.
Yeah,you is bang on.mangocrazy wrote: ↑Tue Nov 15, 2022 6:12 pm I did mention that you'd wonder how you ever managed without the Skylift...
- gremlin
- Has thanked: 776 times
- Been thanked: 4514 times
I sit behind the bike with the rear wheel on my penis and think of Yorick in his Speedos.
