Incoming... NMTBD... The Slayer of trails.
Has thanked: 5450 times
Been thanked: 13085 times
Re: Incoming... NMTBD... The Slayer of trails.
Home, pedals and grips fitted, forks given air pressure (after pic was taken)
It's slack ! Jeez it's slack !
Image2022-11-05_04-16-18 by Steve Weeks, on Flickr
Has thanked: 6375 times
Been thanked: 4750 times
weeksy wrote: Sat Nov 05, 2022 4:18 pm Home, pedals and grips fitted, forks given air pressure (after pic was taken)
How many miles was that? :D
PS In the bike context, what does 'slack' mean?
Nearly 600.
Slack, like a Harley, forks stick out a long way, rake in motorbike terms I guess. Makes it better going downhills but worse on flat and ups.
Jobs then
1. Tubeless tyres. They're pre taped but tubed currently
2. Change rear to Assegai
3. 50mm stem
4. Maybe bars change
5. Check and change dropper lever angle
6. New rear shock spring and bushings
7. Ride it!
G.P
Has thanked: 2029 times
Been thanked: 1310 times
Post by G.P »
weeksy wrote: Sat Nov 05, 2022 12:09 pm
G.P wrote: Sat Nov 05, 2022 11:50 amwhere to?
Lol heading home with the new bicycle
Sorry, can't keep up! :)
G.P wrote: Sat Nov 05, 2022 5:19 pm
Sadly there's not enough people who say that, especially when race numbers get fitted
Has thanked: 2940 times
Been thanked: 1882 times
weeksy wrote: Sat Nov 05, 2022 5:19 pm
You need to channel your inner KHAN!!!!!!
MingtheMerciless wrote: Sat Nov 05, 2022 5:33 pm
I'm trying boss, honestly. But it's bloody hard lol.
Has thanked: 1829 times
Been thanked: 1469 times
weeksy wrote: Sat Nov 05, 2022 5:16 pm Jobs then
3. 50mm stem
7. Ride it!
But other than that, it is perfect?
Mr Moofo wrote: Sat Nov 05, 2022 7:14 pm
3. 50mm stem
7. Ride it!
Wouldn't you set your bike up?
That's like buying a car and leaving the seat and steering wheel where the last person put them.
Well, to some degree
But is would expect bushings and bearing done
Rear tyres - personal choice
Stem -50mm is long
Not running tubeless - is it 2015?
crust
Has thanked: 604 times
Been thanked: 515 times
Post by crust »
weeksy wrote: Fri Nov 04, 2022 9:24 pm
Not the most tactful.
I wonder if a pair of soft jaws would hold it without marking.
Hmmm
Looks easily doable. I'd use a couple of bits of wood rather than soft jaws.
We'll see then when new spring arrives this week
Couchy
Has thanked: 326 times
Been thanked: 2173 times
Post by Couchy »
I like that but grips and pedals should be black unless you are super fast or under 20 👍🤣
50mm stem, it’ll be like a tiller 😳
Couchy wrote: Sat Nov 05, 2022 7:43 pm I like that but grips and pedals should be black unless you are super fast or under 20 👍🤣
I was thinking he'll end up with a length of rope on the bar ends and steering it like an old go kart.😂
Front and rear are set up Tubeless. I was slightly mistaken as i thought it was an Assegai on the front but is a DHF.
I did try my Assegai on the rear as the Aggressor wasn't the biggest tread on the planet, but on the top brace of the chainstay, the clearance isn't massive and the Assegai is a little bit bigger. So went back to the Aggressor. The Assegai would have saved me another 400gr, so a decent savings.
Weight with pedals is 16.1kg, which for a 180mm beast running DD tyres is fairly decent i think.
Bike came with a little welcome pack which has Tubeless valves in there, some more bottom downtube frame protection and a different chainguard which i'll look at later, as well as some fork tokens for the Lyrics.
The bars come in at 820mm with the Deathgrips installed, which is too wide for me, so they'll either get swapped or trimmed to a sensible width
LOL it's a 40mm as stock... not exactly a massive difference.
it's going to be a very wet and muddy first ride ...
I’m going to have a pedal over to Alfriston in a minute, snorkel and periscope being bolted to the Curtis as I type……
Mr Moofo wrote: Sun Nov 06, 2022 9:33 am it's going to be a very wet and muddy first ride ...
NOt for a few days... I want to fit the Dyedbro protection kit along with the rear spring, neither of which are here yet.
