What Sort Of Pump Do I Need?
Has thanked: 6375 times
Been thanked: 4746 times
Re: What Sort Of Pump Do I Need?
Yorick wrote: Thu Sep 29, 2022 7:52 pm I've found exactly what I need
https://www.ebay.co.uk/itm/225131309085 ... BMtOOyqfFg
I've had one and it was really, really poor. Binned it having left it in the garage unused after the first attempt as it rusted solid anyway.
Has thanked: 484 times
Been thanked: 1427 times
Is that your basement rental to the right of that white path? If so why not add guttering/drain just at the start of the path and guide it either away down hill or into the black grass. Got to be better than standing in the rain with a drill
Felix wrote: Fri Sep 30, 2022 12:02 am Is that your basement rental to the right of that white path? If so why not add guttering/drain just at the start of the path and guide it either away down hill or into the black grass. Got to be better than standing in the rain with a drill
^^^^That.
That pump drill attachment also needs fixing to a baseboard or something that won't rotate. The eBay one looks a bit better than the one I had as they've put a hex shaft on it but I don't think I'd want to use my drill (even battery) in a deluge.
Has thanked: 218 times
Been thanked: 689 times
Maybe for about 5 minutes or until it finds a bit of gravel. I used 12v in line pumps on the boat, they self prime, and it's easy to screen for dirt on the end of the pump. I was using one for oil transfer in Wales from the spare kerosene tank.
Probably the best suggestion so far has been the sump with a submersible pump mentioned earlier.
Your drill powered pump is a total waste of time and money...not like you, Yozza.
Been thanked: 2612 times
A boat bilge pump might be enough if you think the drill pump will be. 12V ones are easily got
Has thanked: 10261 times
Been thanked: 6885 times
These might explain it better. It's a huge driveway and about 10% of rainwater goes towards the house and about 80% of the water goes to the main drain on the roundabout. Until that is overwhelmed and then it all goes to the house.
At the moment the main drain just goes onto the plot next door. They've started building there now so my pal is gonna dig out a big hole for a big water butt with a submersible pump. That should be OK
The drain at the top of the stairs is a mystery. Fills up straight away when the drive floods and no way to empty it. Water just pours down the apartment steps. It's not wide enough for a submersible pump.
So for here I need a portable emergency pump. A simple jobby with a hosepipe connection and a hosepipe connection out so I can send the water somewhere safe.
What could be simpler ? Aha, they are impossible to find :(
Has thanked: 6186 times
Been thanked: 5087 times
Could you redo the steps (actually the paving where your 'no drain' is) so there's a single step 'up' before going down, to act as a dam?
How deep does it get there?
Horse wrote: Mon Oct 03, 2022 3:04 pm Could you redo the steps (actually the paving where your 'no drain' is) so there's a single step 'up' before going down, to act as a dam?
Too dangerous for guests in the dark.
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Post by DefTrap »
If you're only looking at solutions where you need to be on-hand 24-7-365 anyway - you may as well just put up a temporary dam between those two high points at the top of the steps
Kneerly Down
Has thanked: 164 times
Been thanked: 308 times
Post by Kneerly Down »
Yorick wrote: Thu Sep 29, 2022 8:13 pm Gonna order it as see what happens.
Cheap drill pump.
I reckon, IF you can get it to prime, it'll pump for a couple of minutes and then the imperller will be knackered and it'll just spin but not push water through it.
Kneerly Down
cheb wrote: Fri Sep 30, 2022 12:02 pm A boat bilge pump might be enough if you think the drill pump will be. 12V ones are easily got
That^
I used to use a 700W mains pump with a big car battery and inverter to get water into our storage tank on the hill when the (surface of the) river froze.
Recent years I moved to a 12V bilge pump with a much smaller battery.
It takes a lot longer than the mains pump, but I can easily leave it there unattended for 40mins or so.
Has thanked: 1507 times
Been thanked: 1410 times
So yer gonna sit out there in the pissing rain with a Chinese drill/pump that would likely struggle to empty a bucket?
What ya need to do is connect that small trough to a 6 or 8in dia pipe that goes off the property.. which will involves pulling up pavers etc...
