Seems to have an idler wheel in the drive chain, which is fairly odd - for a motorbike anyway!Le_Fromage_Grande wrote: ↑Wed Sep 07, 2022 4:25 pm It has less effect on chain tension if they're close together, which in turn effects how the bike behaves on and off the throttle, looking at it the chain run is pretty awful
ENGINEERING PORN: CHRIS COSENTINO’S DUCATI HYPERMONO
- Has thanked: 2552 times
- Been thanked: 6262 times
Re: ENGINEERING PORN: CHRIS COSENTINO’S DUCATI HYPERMONO
- ChrisW
- Has thanked: 2920 times
- Been thanked: 2061 times
Looks like there's two - can just about make out a lower one too.Mr. Dazzle wrote: ↑Wed Sep 07, 2022 4:30 pmSeems to have an idler wheel in the drive chain, which is fairly odd - for a motorbike anyway!Le_Fromage_Grande wrote: ↑Wed Sep 07, 2022 4:25 pm It has less effect on chain tension if they're close together, which in turn effects how the bike behaves on and off the throttle, looking at it the chain run is pretty awful
- Been thanked: 4125 times
My Husqvarna 610 had a nylon bush that did this job, it was fucking hopeless and just made tensioning the chain a pain, I wasn't sad when it fell off.Mr. Dazzle wrote: ↑Wed Sep 07, 2022 4:30 pmSeems to have an idler wheel in the drive chain, which is fairly odd - for a motorbike anyway!Le_Fromage_Grande wrote: ↑Wed Sep 07, 2022 4:25 pm It has less effect on chain tension if they're close together, which in turn effects how the bike behaves on and off the throttle, looking at it the chain run is pretty awful
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
I had to look up as i thought the Foale design was similar to the Tesi and Vyrus which followed later. I couldnt place where i had seen it before till you mentioned HossackLe_Fromage_Grande wrote: ↑Wed Sep 07, 2022 8:43 am It's nicely made, weird that he credits Tony Foale as inspiration for what is clearly a Hossack front end, I don't remember Tony ever designing a bike with that type of front suspension.
- Bigyin
Interesting, never seen that beforeHorse wrote: ↑Wed Sep 07, 2022 9:31 am Get lost
For an hour, reading:
https://motochassis.com/Articles/Steer/STEER.htm
And more
- Has thanked: 1829 times
- Been thanked: 1469 times
Can I go against the heard and say, whilst it might be great engineering, I hate it!
- Has thanked: 255 times
- Been thanked: 143 times
as mentioned above he has idler wheels on the top and bottom runs, so he can tune the pro/anti squat independently of sprocket to swingarm pivot position. He previous ones had this too. the cases are billet, insane amount of work gone into the engine. be good to see what power and weight it ends up with.Le_Fromage_Grande wrote: ↑Wed Sep 07, 2022 4:25 pmIt has less effect on chain tension if they're close together, which in turn effects how the bike behaves on and off the throttle, looking at it the chain run is pretty awful
