MX5? All a tallish chap needs are goggles and a decent moustache wax on the ol' handlebar and chocks away!KungFooBob wrote: ↑Fri Aug 05, 2022 7:45 pmThere was that one time I thought about buying an MX5...Mr. Dazzle wrote: ↑Fri Aug 05, 2022 7:33 pmMaybe you could transfer some knowledge from standing up inside vans or sitting in a convertible without getting wind in your eyes.KungFooBob wrote: ↑Fri Aug 05, 2022 7:00 pm I'd like to help... but not being a midget means I have no relatable experience.
Getting your leg over
- Has thanked: 6382 times
- Been thanked: 4765 times
Re: Getting your leg over
- Has thanked: 4366 times
- Been thanked: 2855 times
On mine the top box is behind the back of the seat so doesn't impact getting on the bike at all.
- Has thanked: 1350 times
- Been thanked: 1729 times
The only real time bike height has been an issue for me has been kickstarting my KX500, just could do with having more height above the lickstart lever.
I reckon I'm about at average height at 5'10" though and I've never had a topbox yet.
- Been thanked: 4125 times
I'm 5ft 8, never had a problem with dirt bikes, even MX bikes that don't have stands, I haven't started a KX500, but I never had any problems with my KTM 250 which had the same chassis as the 500, and was left hand kick. I can't remember having any problems with CR500s either.
Though I doubt if I'm as flexible as I was 30 years ago.
- Has thanked: 326 times
- Been thanked: 2173 times
If you goose step towards the bike at a ninety degree angle and time it to perfection you should glide onto the seat
- DefTrap
- Has thanked: 2267 times
- Been thanked: 2193 times
Never kicked a left side KTM 250 over but always found 250s to be almost hand startable and 125s were deffo startable with a hand on the lever while working on the bike.Le_Fromage_Grande wrote: ↑Fri Aug 05, 2022 8:43 pm I'm 5ft 8, never had a problem with dirt bikes, even MX bikes that don't have stands, I haven't started a KX500, but I never had any problems with my KTM 250 which had the same chassis as the 500, and was left hand kick. I can't remember having any problems with CR500s either.
Not kicked a CR500 over and always assumed it would have been much the same as ny KX.
Me assuming don't mean shit though, its just a guess based on something else being kind of close ish.
- Has thanked: 261 times
- Been thanked: 1266 times
- wheelnut
- Has thanked: 908 times
- Been thanked: 1002 times
I suffer from a shortish legs and a long back. Not freakishly so, but it’s there all the same.
When I’m camping with the GSA I have a rolltop bag bungeed to the back seat. This makes getting off and on the thing quite comical. Getting on, I lift my right leg up and throw it over the seat and pretty much fall on to the seat. Getting off, I put my left leg down, take the weight and hop away until my right leg can rejoin the rest of my body.
- Has thanked: 6200 times
- Been thanked: 5090 times
Tall bike, bag strapped on the pillion seat, short legs ...
... I've had to start from a yard or so away, right leg up - and hop towards the bike
I've had the sidestand on a bike collapse, so was wary of using them as a step.
The KTM was harder to kick than a Japanese 250 of the same age (1986), the CR500 was an 85, but could have been shagged as it wasn't much quicker than a 250, so probably a bit Roger Irrelevantdemographic wrote: ↑Fri Aug 05, 2022 9:14 pmNever kicked a left side KTM 250 over but always found 250s to be almost hand startable and 125s were deffo startable with a hand on the lever while working on the bike.Le_Fromage_Grande wrote: ↑Fri Aug 05, 2022 8:43 pm I'm 5ft 8, never had a problem with dirt bikes, even MX bikes that don't have stands, I haven't started a KX500, but I never had any problems with my KTM 250 which had the same chassis as the 500, and was left hand kick. I can't remember having any problems with CR500s either.
- MrLongbeard
- Has thanked: 600 times
- Been thanked: 2451 times
- Has thanked: 10279 times
- Been thanked: 6891 times
When I have luggage on I lead with my knee and leg bent.
If Penny is already on, I do a sort of straight karate kick just above my seat. Voila, I'm on.
- ChrisW
- Has thanked: 2921 times
- Been thanked: 2061 times
- Scotsrich
- Has thanked: 70 times
- Been thanked: 549 times
On the GS I just mount it as you woulda horse.
Left foot on the peg and right leg over when you lift yourself up.
Admittedly the dealer had to show me how to do that in my test ride as there was no way I was getting on it the way I did lower bikes.
I’m not sure I’d try that on a non adventure bike but for a tall bike it’s the easiest way.
- Scotsrich
