The proof of the pudding is in the eating. Go to any decent hifi retailer and demo a mid range setup. If you then think it is in any way comparable then your next stop should be an audiologist.Slenver wrote: Sat Aug 06, 2022 8:59 pm
No it doesn't, not necessarily. That's what I'm trying to explain. In most cases this is true, but they make other products, including one that simply streams into your DAC and amp. As I explained above in my own setup.
And as for 'loss in wireless transmission', I'm not sure that's a thing. Do you find websites are lower quality on wi-fi than via an ethernet cable?![]()
As to Wi-Fi, vs decent speaker cable. The cable carries the signal in full fat analogue. A Wi-Fi is in compressed digital which is then compensated for by algorithims on the receiving device during the conversion process. Even streaming is a lossless format sounds flat compared to good CD transport or a decent turntable.
