So, it's decided then. The replacement for the XSR9 will be
Has thanked: 3266 times
Been thanked: 1737 times
Re: So, it's decided then. The replacement for the XSR9 will be
Only two cylinders? Build yourself one of these
https://mallelondon.com/the-malle-rally-royale/
Honda reliability?Wrong size wheels & It's got 4 cylinders but a CBR600RR should cope :wtf:
Bigyin
Has thanked: 1413 times
Been thanked: 2680 times
Post by Bigyin »
Le_Fromage_Grande wrote: Fri Apr 29, 2022 9:12 pm Just had a look at REs website, the Himalayan is like a modern day MZ ISDT bike, just needs a tool bag on top of the tank.
The Himalayan might be good for the off road part but is really limited when you want to cover miles as it is running out of breath at motorway limit speeds . Mate has one he bought for touring one and it didnt stay long as the idea was there but practically its limited to shorter distances on rough terrain
Out of the big adventure bikes some are very good at long distance on roads, some more adept on trails than others, not many excel on both
I would say a Multistrada obviously but for your requirements it has too many cc unless you go for the 950, wheels are wrong size unless you go for the Enduro which is mahoosive. I have covered 800 miles in a day on mine touring, taken it off road up rock strewn loose gravel mountain tracks with luggage and done track day laps on it. Is it perfect at them all, not really, but its a superb all rounder that not much else can match
Bigjawa
Has thanked: 221 times
Been thanked: 879 times
Post by Bigjawa »
Bigyin wrote: Sat Apr 30, 2022 8:43 pm
Sounds daft, but my Himalayan seemed to get smoother at 65+ after about 5 minutes. I just got the thought that it'd blow up if you did it too often!
Has thanked: 2636 times
Been thanked: 1523 times
Word is a CB3 890 Tenere is on the way...
G.P
Has thanked: 2029 times
Been thanked: 1310 times
Post by G.P »
790 / 890 KTM is best fit for your spec, not sure you'd get an Africa twin for your Budget. 800XC Triumph works too (I'll ignore you're ask for max 2 cyl :) )
