Best bike related inventions
- Has thanked: 2636 times
- Been thanked: 1523 times
Re: Best bike related inventions
Stick on mohicans...
- Has thanked: 9845 times
- Been thanked: 10157 times
Boil in the bag for feet.Rockburner wrote: ↑Wed Mar 30, 2022 2:41 pm
My first pair of "bike-boots" were Derriboots - fecking horrible things.
- Has thanked: 6382 times
- Been thanked: 4770 times
Oddly enough I had a pair of leather soled 'cowboy' boots - bought from a stall in the Grainger market Newcastle - for summer riding. They got a lovely patina across the left boot from the gear shift. Considering the purchase location they were remarkably well made and lasted for years and years. I think they were Argentinian gaucho style, quite chunky. I was heartbroken(ish ) when they finally had to be abandoned.Horse wrote: ↑Wed Mar 30, 2022 3:52 pmMy first motorcycle boots were from Lewis Leathers and actually heavy duty pull on cowboy* boots. When polished and dubbined they were waterproof.Count Steer wrote: ↑Wed Mar 30, 2022 7:37 amUnfortunately the best I could get for the feet were Derriboots - remember them? Waterproof, but basically wellingtons.Waterproofs that are actually waterproof
Goretex boots
* A pedant notes: I learnt many years later that cowboy boots have higher heels, for grip in stirrups, so what I had were 'ropers'.
- Has thanked: 2409 times
- Been thanked: 3639 times
Decent suspension and grippy (tubeless) tyres. I was forcibly reminded of this when riding the LC the other day and felt the spindly 32mm (!) forks flexing and wobbling over dodgy surfaces, aided and abetted by the skinny 18" tyres. Have I ever mentioned that I hate inner tubes?
- Bigyin
- Has thanked: 1413 times
- Been thanked: 2680 times
Pinlocks are one of the things where i wonder how the feck we coped without them in the 80/90's
Heated grips are superb and allow me to wear thinner gloves all year round
As for slipper clutches and ABS i have them fitted on the Ducati and have yet to make either kick in after 35 years riding without locking the brakes or dumping the clutch lever. I have used the slipper clutch on track but thats about it and i can live without both easily
- Has thanked: 6202 times
- Been thanked: 5090 times
'Fond' memories of hearing the drilled disks on my R100RT making loud 'whirring' noises as the forks twisted mid-corner ...
No surprise that these were popular
Fairy Liquid or Bob Heath visor spray for the posh. Or open visor and an eyeball power wash.
- Has thanked: 7822 times
- Been thanked: 2532 times
- Has thanked: 1751 times
- Been thanked: 2089 times
- Has thanked: 15993 times
- Been thanked: 10261 times
I used to like going for a ride in an area I don't know. Then 3 lefts and a right etc. Some of my best rides have been when I didn't know where I'm going and I've found some nice places that I wouldn't have found otherwise. Not saying they don't have their uses, as they clearly do, but they are not a great biking invention for me.
- Has thanked: 2554 times
- Been thanked: 6262 times
- Cousin Jack
- Has thanked: 2561 times
- Been thanked: 2292 times
I started this from the other end. What do I remember (with some hatred) from my 1960s era biking.
Inadequate gloves, neither warm nor waterproof. My Dad (an ex-biker) recommended sheepskin mittens, but I was way too cool for them.
Boots - the only waterproof boot was a wellie.
Biking gear generally. The only real waterproof gear was oilskins. Not cool and not comfortable, never designed for biking so water always found a way in eventually.
So, in my book Goretex is the No1 biking innovation! In gloves, boots, and clothing.
Tyres were also a bit of a nightmare. They were mostly like narrow car tyres, vaguely rounded IIRC, but with pathetic grip by modern standards. So decent modern rubber is a massive improvement.
Related to that is brakes. Even the most pathetic modern disc brakes are massive improvement on the drum brakes I had. Even exotic 60's bikes with TLS brakes were pathetic.
Being able to stop and go around corners, even in the wet, is awesome!
And the final thing that I remember not-so-fondly is the kick start. Kicking a recalcitrant bike into life on a cold morning was not something I enjoyed. Even worse was trying to restart a bike that you had just stalled in heavy traffic - remember it will be pissing down with rain, and you are enveloped in oilskins and wellies. Any more than 2 kicks and you will be sweating like the proverbial pig, and will probably flood the carb and have to do the push of shame!
The electric starter is a wonderful thing!
All the other stuff (ABS, heated grips, FI, decent lights, traction control, etc) is icing on the cake!
Vice versa, by letting the GPS work out routes I've also found places and particularly roads that I wouldn't have found as well.Taipan wrote: ↑Wed Mar 30, 2022 8:15 pmI used to like going for a ride in an area I don't know. Then 3 lefts and a right etc. Some of my best rides have been when I didn't know where I'm going and I've found some nice places that I wouldn't have found otherwise. Not saying they don't have their uses, as they clearly do, but they are not a great biking invention for me.
(Me and Hairy Ben did negotiate a route once by heading to the right of the setting sun once knowing we needed to head north though ).
I had two instances of knowing [almost] where I was that convinced me that GPS might be beneficial.
One was out in countryside, within a couple of miles of where I wanted to be. The council had taken the signs down.
Other was two names meeting on the same stretch of road. I was knocking on the wrong number 112 - correct one was 50 yards away.
And I still use Fairy Liquid.
Tried a Pinlock for about a week... vision at night was significantly worse.
I had an early Garmin GPSIII which couldn't do routing. It simply put a line on the map which told you the direction to head to your destination. I rode from one of the ports (Caen IIRC) down towards the Pyrenees simply following that line. It was a wonderful ride. Bits of autoroute followed by a section of twisty minor road, and even a couple of dirt roads, one of which took me out through the farm yard where the farmer was stacking bales... much to his surprise to see a fully loaded GP plated FZ750 emerge down his farm track and turn out onto the road. The only tricky bit was that I'd completely forgotten I'd need to cross the Loire and it's a BIG river at the seaward end with not so many bridges... I was really lucky to emerge into a town with a car ferry!Count Steer wrote: ↑Wed Mar 30, 2022 8:37 pm
I'd agree with that. I rarely ride either at night or in crap conditions,so I can enjoy the benefits of a visor insert without the penalties. Pinlock isn't a perfect solution for everyone,but it's viable for some.The Spin Doctor wrote: ↑Wed Mar 30, 2022 10:19 pmAnd I still use Fairy Liquid.
- Cousin Jack
One strange feature of a pinlock was when I used one with my polarizing sunglasses. Absolutely weird colour effects (like blue grass!). Somewhat off-putting!Skub wrote: ↑Wed Mar 30, 2022 10:28 pmI'd agree with that. I rarely ride either at night or in crap conditions,so I can enjoy the benefits of a visor insert without the penalties. Pinlock isn't a perfect solution for everyone,but it's viable for some.The Spin Doctor wrote: ↑Wed Mar 30, 2022 10:19 pmAnd I still use Fairy Liquid.
Sounds like an infrared thing. Old IR film used to turn grass blue.Cousin Jack wrote: ↑Wed Mar 30, 2022 10:57 pm One strange feature of a pinlock was when I used one with my polarizing sunglasses. Absolutely weird colour effects (like blue grass!). Somewhat off-putting!
I find that glass and clear plastic in general often look weird through polarised glasses. Tempered safety glass in particular often looks odd, you can see the built in stress patterns.Cousin Jack wrote: ↑Wed Mar 30, 2022 10:57 pmOne strange feature of a pinlock was when I used one with my polarizing sunglasses. Absolutely weird colour effects (like blue grass!). Somewhat off-putting!Skub wrote: ↑Wed Mar 30, 2022 10:28 pmI'd agree with that. I rarely ride either at night or in crap conditions,so I can enjoy the benefits of a visor insert without the penalties. Pinlock isn't a perfect solution for everyone,but it's viable for some.The Spin Doctor wrote: ↑Wed Mar 30, 2022 10:19 pm
I have a pair of polarised sunglasses which turn most orange LEDs neon green. You have to make a mental note of jt when driving.
