That was Keith Code too. The guy knows everything.
Power Steering, for bikes???
- Has thanked: 9845 times
- Been thanked: 10157 times
Re: Power Steering, for bikes???
- Has thanked: 1264 times
- Been thanked: 1188 times
- Has thanked: 6202 times
- Been thanked: 5090 times
He taught the Earth how to suck
- Has thanked: 2409 times
- Been thanked: 3639 times
Citroens of a certain age that had hydropneumatic suspension had the ability to modify active ride height and self-level. Its party trick was the ability to change a wheel without the use of a jack. You could also lower the car to a degree that made it impossible to clamp the wheel(s). More than one way to skin a cat.Mr. Dazzle wrote: ↑Sun Mar 27, 2022 9:07 am It makes a lot of sense really, electric things can move more quickly and push as well as passively react. I know for a fact one supercar OEM is developing electric dampers for their future models. They'll be able to actively push the wheels up/down so you can do things like "hold them up" as the wheel skips over a pothole.
He and Tom Cruise are actually Thetans,like Connor Macleod of the clan Macleod,the pair of them,big swords,the lot.
- Has thanked: 2554 times
- Been thanked: 6262 times
mangocrazy wrote: ↑Sun Mar 27, 2022 1:56 pmCitroens of a certain age that had hydropneumatic suspension had the ability to modify active ride height and self-level. Its party trick was the ability to change a wheel without the use of a jack. You could also lower the car to a degree that made it impossible to clamp the wheel(s). More than one way to skin a cat.Mr. Dazzle wrote: ↑Sun Mar 27, 2022 9:07 am It makes a lot of sense really, electric things can move more quickly and push as well as passively react. I know for a fact one supercar OEM is developing electric dampers for their future models. They'll be able to actively push the wheels up/down so you can do things like "hold them up" as the wheel skips over a pothole.
McLaren do the same thing now with their cars. Its still only a reactive system though, it can't "push" the wheels beyond (relatively) slow movement to change ride height.
But yeah...as I often say: There are no new ideas!
Yes I know all that. The point is, the whole situation which lead to the aircraft crashing was recoverable if the pilots had known what to do. In fact the same situation had been recovered by a pilot who DID know what to do in other examples, unfortunately that knowledge was not as universal as it should have been.
Of course, the situation shouldn't have needed recovering in the first place, which speaks to my larger point about the difficulty of integrating complex operations and human operators.
- wull
- Has thanked: 881 times
- Been thanked: 1552 times
It’s the fact you stated that it did what it was meant to do during those accidents, which it didn’t, you made it out like the system was working correctly.
The other incidents were pilots who were aware of the MCAS, lucky them.
- Has thanked: 6382 times
- Been thanked: 4770 times
I had one of the last off the production line CXs (a Croisette saloon), the suspension was quite a party trick and, as you say, unclampable Sadly it was also the weak point (apart from the weedy engine) of the whole thing. Once it went wrong.....mangocrazy wrote: ↑Sun Mar 27, 2022 1:56 pmCitroens of a certain age that had hydropneumatic suspension had the ability to modify active ride height and self-level. Its party trick was the ability to change a wheel without the use of a jack. You could also lower the car to a degree that made it impossible to clamp the wheel(s). More than one way to skin a cat.Mr. Dazzle wrote: ↑Sun Mar 27, 2022 9:07 am It makes a lot of sense really, electric things can move more quickly and push as well as passively react. I know for a fact one supercar OEM is developing electric dampers for their future models. They'll be able to actively push the wheels up/down so you can do things like "hold them up" as the wheel skips over a pothole.
Volvo had a test system that could raise the suspension on the 'outside' of a corner, to lean the car into the bend.Mr. Dazzle wrote: ↑Sun Mar 27, 2022 1:59 pmIts still only a reactive system though, it can't "push" the wheels beyond (relatively) slow movement to change ride height.mangocrazy wrote: ↑Sun Mar 27, 2022 1:56 pmCitroens of a certain age that had hydropneumatic suspension had the ability to modify active ride height and self-level. Its party trick was the ability to change a wheel without the use of a jack.Mr. Dazzle wrote: ↑Sun Mar 27, 2022 9:07 amone supercar OEM is developing electric dampers for their future models. They'll be able to actively push the wheels up/down so you can do things like "hold them up" as the wheel skips over a pothole.
Apparently much more comfortable for the occupants.
Unfortunately, it reduced 'feel' so much for the driver that there was little feedback on reaching grip limits.
Yes, unless you were on first name terms with a (good) Citroen specialist you were stuffed. Conventional garages didn't have a clue. I had a TD XM in the mid/late '90s and it was a fabulous car but spent more time in the garage due to overheating issues than it spent on the road. Eventually it was diagnosed with a porous cylinder head. I particularly liked the suspension options - standard for when you wanted to waft along and sport for when you wanted to 'make progress'.Count Steer wrote: ↑Sun Mar 27, 2022 2:45 pmI had one of the last off the production line CXs (a Croisette saloon), the suspension was quite a party trick and, as you say, unclampable Sadly it was also the weak point (apart from the weedy engine) of the whole thing. Once it went wrong.....mangocrazy wrote: ↑Sun Mar 27, 2022 1:56 pmCitroens of a certain age that had hydropneumatic suspension had the ability to modify active ride height and self-level. Its party trick was the ability to change a wheel without the use of a jack. You could also lower the car to a degree that made it impossible to clamp the wheel(s). More than one way to skin a cat.Mr. Dazzle wrote: ↑Sun Mar 27, 2022 9:07 am It makes a lot of sense really, electric things can move more quickly and push as well as passively react. I know for a fact one supercar OEM is developing electric dampers for their future models. They'll be able to actively push the wheels up/down so you can do things like "hold them up" as the wheel skips over a pothole.
- Has thanked: 2636 times
- Been thanked: 1523 times
Code also invented POSITIVE steering, apparently
- Has thanked: 1751 times
- Been thanked: 2089 times
mangocrazy wrote: ↑Sun Mar 27, 2022 3:10 pmCount Steer wrote: ↑Sun Mar 27, 2022 2:45 pmI had one of the last off the production line CXs (a Croisette saloon), the suspension was quite a party trick and, as you say, unclampable Sadly it was also the weak point (apart from the weedy engine) of the whole thing. Once it went wrong.....mangocrazy wrote: ↑Sun Mar 27, 2022 1:56 pm
Not that fabulous then..
- Has thanked: 1350 times
- Been thanked: 1730 times
About the only benefit I can see is actually damping out steering wobbles without making the steering heavy at the same time.
The usual complaint of power steering seems to be that it makes it feel 'dead'. I can't imagine that would be great on a bike where we depend so much on front end feel to sense what the bike's doing. It's not so important when in the wheel at each corner shopping buggy.
Once the cyl head issue was sorted, it was a fabulous car. But I had to sell it (along with a couple of bikes) to keep food on the table when I was out of work for 15 months when the Y2K bubble burst..Dodgy knees wrote: ↑Sun Mar 27, 2022 5:28 pmmangocrazy wrote: ↑Sun Mar 27, 2022 3:10 pmCount Steer wrote: ↑Sun Mar 27, 2022 2:45 pm
- Has thanked: 70 times
- Been thanked: 108 times
Active suspension, nothing new there then, can't be arsed googling when that came about, I drove a very simplified version of it on a Citroen Xantia 20ish years ago. Didn't Lotus put the full fat version on an Esprit?
Bullshit electronic intervention of things that don't need it, let down by flaky software and cut price electrical components and connectors, bought by brain-washed idiots, says it all really.
Thankfully there's no guesstimation in how to fly a plane, especially one full of disconnection between pilot input and control output. You learn to fly these aircraft from manuals and simulators. If you 'had to know what to do' and pilots didn't, blame fairly and squarely on the manufacturer who devised the training regime in the first place.Mr. Dazzle wrote: ↑Sun Mar 27, 2022 2:02 pmYes I know all that. The point is, the whole situation which lead to the aircraft crashing was recoverable if the pilots had known what to do. In fact the same situation had been recovered by a pilot who DID know what to do in other examples, unfortunately that knowledge was not as universal as it should have been.
It's getting more and more difficult to buy things (not just bikes) without it.Hairybiker84 wrote: ↑Sun Mar 27, 2022 11:02 pm Active suspension, nothing new there then, can't be arsed googling when that came about, I drove a very simplified version of it on a Citroen Xantia 20ish years ago. Didn't Lotus put the full fat version on an Esprit?
I read that as, specifically, the Lotus eaters, errr, buyers.Count Steer wrote: ↑Mon Mar 28, 2022 7:32 amIt's getting more and more difficult to buy things (not just bikes) without it.Hairybiker84 wrote: ↑Sun Mar 27, 2022 11:02 pm Active suspension, nothing new there then, can't be arsed googling when that came about, I drove a very simplified version of it on a Citroen Xantia 20ish years ago. Didn't Lotus put the full fat version on an Esprit?
