Don't quote me but believe that the ECU sees low voltage due to excessive power draw by the starter motor, so shuts off the ignition causing no start. Strong battery and associated cabling required to help.....
Speed triple 955i
- Has thanked: 2249 times
- Been thanked: 1243 times
Re: Speed triple 955i
- Been thanked: 7543 times
That's to stop it not turning over fully, back firing and taking out the sprag, iirc.v8-powered wrote: ↑Thu Mar 17, 2022 3:01 pmDon't quote me but believe that the ECU sees low voltage due to excessive power draw by the starter motor, so shuts off the ignition causing no start. Strong battery and associated cabling required to help.....
- the_priest
- Has thanked: 1874 times
- Been thanked: 2171 times
Check draglink bearings. Mine are totally shot on my 2001 Speed Triple.
- Has thanked: 2554 times
- Been thanked: 6262 times
My one went through a spate of refusing to start when hot. No warning lights or other symptoms, it would just merrily spin away and not catch.
I say "went through a spate"...it would still do it, if it weren't for the fact its laid up in my garage.
- Trogladyte
- Has thanked: 68 times
- Been thanked: 89 times
- Has thanked: 1264 times
- Been thanked: 1188 times
- the_priest
Dyslexic sprag clutches are a real pain, it does not know if it is in the right order or not.
- Trogladyte
- Has thanked: 2636 times
- Been thanked: 1523 times
Only a couple?
- Trogladyte
Looking to replace the standard starter circuit cabling with some heavier gauge. Can find a kit for the tiger 1050 on square deals website but nothing for the 1050.
Anyone able to recommend some suppliers to check?
Thanks
Thanks
