Abba stands?
Has thanked: 4088 times
Re: Abba stands?
Skub wrote: Sat Feb 19, 2022 1:29 pm Great bits of kit. I never use my paddock stands now. The front lift works well enough when you get the bike up,but the actual process of pushing down on the rear while tightening the strap can be a bit of a faff. I probably don't do it often enough.
Learn from this guy's mistakes and don't overtighten the swinger mounts.
^^^That's the video I mentioned up there^^^
It was good of him to post it :thumbup:
Re: Abba stands?
I've got a set of these for when pals bring their bikes round
Re: Abba stands?
Yorick wrote: Sat Feb 19, 2022 1:28 pm
Taipan wrote: Sat Feb 19, 2022 1:26 pm
Yorick wrote: Sat Feb 19, 2022 1:20 pm Last time used my Abba stand was to take the Ohlins shock from my last GSXR about 3 years ago. Prefer the paddock stand for normal jobs.
Can I borrow it then? Could you drop it off tomorrow morning?
I'll drop it off in the morning . Hope it's not cold over there ?
Few clouds in the Sky at Canvey island at the moment, but still lovely and warm...
Re: Abba stands?
Taipan wrote: Sat Feb 19, 2022 1:40 pm
Get the barbie on :)
Re: Abba stands?
Yorick wrote: Sat Feb 19, 2022 1:44 pm
:thumbup:
:? :lol:
exportman
Has thanked: 8 times
Been thanked: 64 times
Re: Abba stands?
Post by exportman »
One of the things I noticed on the lift over the stand is the right hand support has a hex socket screw as well as the hand screw.
Has thanked: 3644 times
Been thanked: 2502 times
Re: Abba stands?
Makes getting at the back of the ZH2 much easier and safer than using the paddock stand. Its a big heavy bike and I'm a scrawny runt.
dern
Has thanked: 1183 times
Been thanked: 2277 times
Re: Abba stands?
Post by dern »
If you want to do some bigger jobs then the skylift is worth its weight. I couldn't see the point of the stand over paddock stands but if you're not confident with paddock stands then it looks more stable.
Been thanked: 3504 times
Re: Abba stands?
Yorick wrote: Sat Feb 19, 2022 1:37 pm I've got a set of these for when pals bring their bikes round
I'd use those for the amount of time needed. They can slip though.
Re: Abba stands?
MingtheMerciless wrote: Sat Feb 19, 2022 2:21 pm Makes getting at the back of the ZH2 much easier and safer than using the paddock stand. Its a big heavy bike and I'm a scrawny runt.
Start a thread to make it lighter. :thumbup:
dosruedas
Has thanked: 1 time
Been thanked: 18 times
Re: Abba stands?
Post by dosruedas »
OK not a stand but I have the Abba Skylift. It is a great bit of kit, will lift front or rear of bike or raise both ends equally and makes working on the underside of the bike a doddle. Downside is that it takes up more space than the stands and is more expensive. However, definitely worthwhile if you have any back problems.
Has thanked: 10959 times
Been thanked: 3995 times
Re: Abba stands?
I've got one i bought when i had Mad Liz's 955i. Tbh I'd completely forgotten about it until i cleared my stuff from the old garage.
Anyone want it? They never made fittings for the 1150 BMWs, and i doubt they'll make fittings for a Featherbed frame, so it's not much use to me tbh.
Re: Abba stands?
Rockburner wrote: Sat Feb 19, 2022 5:55 pm I've got one i bought when i had Mad Liz's 955i. Tbh I'd completely forgotten about it until i cleared my stuff from the old garage.
Check out the swingarm removal kit.
It mounts the ABBA fittings on a footpeg hanger bolt. I'm gonna try it on my KRS at some point.
dosruedas
Has thanked: 1 time
Re: Abba stands?
Post by dosruedas »
Fitting kits are just mild steel. If you have access to a lathe, it's only a few minutes work to turn most of them up. One or two, like those for a Multistrada are a bit more complicated.
Re: Abba stands?
I've finally used my abbastand and I'm quit impressed at how much more accessible it makes the bike over a paddock stand. Thinking of adding the front wheel lift, as it looks like a good accessory for it. Anyone got one? Happy with it?
Re: Abba stands?
Mama, at Waterloo Napoleon did surrender....
Re: Abba stands?
Yorick wrote: Tue Oct 25, 2022 1:56 pm Mama, at Waterloo Napoleon did surrender....
I thought it was 'My, my'.
Re: Abba stands?
KungFooBob wrote: Tue Oct 25, 2022 2:04 pm
My My Mia?
Re: Abba stands?
Mine was the Queen version.
.... just killed a man.
asmethurst99
Has thanked: 1331 times
Been thanked: 484 times
Re: Abba stands?
Post by asmethurst99 »
Mine means I can change the oil without taking bodywork off - also easier to use to use on your own
