2022 champion, who, why?
- wull
- Has thanked: 979 times
- Been thanked: 1858 times
Re: 2022 champion, who, why?
It’s such a fine line though, there are so many variables even lap on lap, the consistency you would have to have with inputs for it to react the same way every lap at the exact same point on the track, so I don’t think it’s as clear cut as “this is the line, so don’t go over it”………..
It’s like when Brooksy a few years ago when he won the BSB he says that in every corner he thought he was going to crash, he was pushing that hard that in his own words he wasn’t sure he’d make it out of the corner.
- Been thanked: 15503 times
Oh absolutely... i'm not even going to begin to try and imagine it. But being able to learn when to stop is obviously the difference between a champion and not. Look at O'Halloran last year for example, he should have romped it.... But a couple of crashes and he's suddenly not champion. Marquez has learned the lesson is expensive too as without his crashes he would likely still be the dominant force in GPs.wull wrote: Thu Feb 10, 2022 8:08 am It’s such a fine line though, there are so many variables even lap on lap, the consistency you would have to have with inputs for it to react the same way every lap at the exact same point on the track, so I don’t think it’s as clear cut as “this is the line, so don’t go over it”………..
lostboy
- Has thanked: 2152 times
- Been thanked: 426 times
Eight world titles suggests he knows when to not go past that limit and that the learning has been done. Was it the 19 season that he didn't have a result lower than second in races that he finished and only one DNF?weeksy wrote: Thu Feb 10, 2022 7:55 amHow many crashes does it take to find when to not go past that limit though ? That's the issue. Surely 'learning' implies that after a certain number of passing the limits, you stop just before them ?
Every time he makes a change to the bike he's got to know where that limit is, hence why he's stepped off a few in practice.
- Has thanked: 12615 times
- Been thanked: 8540 times
What I meant was that he's not just pottering about scared. He's still pushing as hard as before.weeksy wrote: Thu Feb 10, 2022 7:55 amHow many crashes does it take to find when to not go past that limit though ? That's the issue. Surely 'learning' implies that after a certain number of passing the limits, you stop just before them ?
I'm still going with these 3.weeksy wrote: Tue Jan 25, 2022 1:33 pm Motogp Marquez
Wsb Rea
BSB Sykes (assuming he gets the Bird Ducati)
So who've you got and why?
