Motorbike rear wheel spinners, any good?
- Has thanked: 1693 times
- Been thanked: 2013 times
Re: Motorbike rear wheel spinners, any good?
How do you hold bike upright and lube at the same time. Looks dodgy to me.
- Has thanked: 5375 times
- Been thanked: 12766 times
- Has thanked: 9853 times
- Been thanked: 6651 times
I remember a photo of a lady with fancy black amd purple painted nails who had done that. Her nails looked good, the rest of her fingers less so.
- Has thanked: 3054 times
- Been thanked: 1628 times
I use that tool for wedging my Street triple swing arm when I lube the chain.If I had a MT07 I would use it for the same purpose.
- dern
- Has thanked: 987 times
- Been thanked: 1723 times
I do all my bikes that have a centre stand or fit on the paddock stand like this. 1st gear, pot of oil and a paint brush.
- Has thanked: 15277 times
- Been thanked: 9856 times
The "puck" you can see in the middle goes under the side stand then you just turn the wheel with one hand whilst oiling the chain with the other hand. I suspect I will try the engine running method at some point though!Dodgy knees wrote: ↑Fri Jan 28, 2022 9:43 am How do you hold bike upright and lube at the same time. Looks dodgy to me.
- DefTrap
- Has thanked: 2181 times
- Been thanked: 2089 times
Or just get yourself a decent shaft drive bike.
You can do the proper wheelies then as well.
- Has thanked: 9505 times
- Been thanked: 9716 times
Placing the bike on an Abba stand I turn the rear wheel by hand,lovingly and fastidiously cleaning and oiling each wonderfully created link.
It's only right.
It's only right.
- Has thanked: 7457 times
- Been thanked: 2401 times
Oi weeksy, you used the wrong login.
Taipan wrote: ↑Fri Jan 28, 2022 12:21 pmThe "puck" you can see in the middle goes under the side stand then you just turn the wheel with one hand whilst oiling the chain with the other hand. I suspect I will try the engine running method at some point though!Dodgy knees wrote: ↑Fri Jan 28, 2022 9:43 am How do you hold bike upright and lube at the same time. Looks dodgy to me.
I think with these rollers it would be safer to turn wheel by hand as you say. Running in first could be risky, if say it went out of line or summot. Paddock stand running in first is fine. And only a daft bugger would wrap his hand in the rear sprocket.
- Has thanked: 1264 times
- Been thanked: 1188 times
The remote control should make it easierTaipan wrote: ↑Fri Jan 28, 2022 9:35 am Bought one from Busters/M&P snd it arrived 2 days later. Good heavy bit of kit and not flimsy as expected. I’ll give it a try over the weekend.
upload pic
I can watch Moto GP on my digital dash!slowsider wrote: ↑Fri Jan 28, 2022 3:41 pmThe remote control should make it easierTaipan wrote: ↑Fri Jan 28, 2022 9:35 am Bought one from Busters/M&P snd it arrived 2 days later. Good heavy bit of kit and not flimsy as expected. I’ll give it a try over the weekend.
upload pic
- Has thanked: 2490 times
- Been thanked: 6017 times
I tried it out today. First fault it moves when you try and roll the bike onto it. This was on decking, but I assume concrete will be worse. The get round is to stand behind the bike with your feet or foot against the stand and pull the bike onto it. Easy enough on a light bike like Mine but wouldn’t want to do it with anything much heavier tbh.
Moving onto oiling the chain; I used a squirty can but think puring out of a bottle with a outer would be better. I found turning the wheel with your left hand whilst putting the oil onto the chain as it rotates on the rear sprocket is best. Turning it with a spray lubricate would probably be the best solution and may knock the rating up a point?
I’m summary, centre staNd get the gold, paddock stand silver and this is an also ran! It’ll do what I want, which is saving me get the paddock stand from the shed and bringing it round the front and I suspect it’ll get hetter as I get used to using it, but I can only give it 3/5.
A trolley jack under the swinging arm or exhaust will do the job
- Has thanked: 6197 times
- Been thanked: 4614 times
Glue some rubber under it?
Again, that's something I'd have to go and get,whereas this will live under the hedge in the front garden, so I can just use it easily.
Maybe if the roller was permanently fixed somewhere handy,then it would be less of a faff?
