Don't you have to be scruffy and unwashed with goatee beard to use them?
Cleaning exhaust headers
- Has thanked: 10282 times
- Been thanked: 6894 times
Re: Cleaning exhaust headers
- Has thanked: 1264 times
- Been thanked: 1188 times
From my personal experience of Triumph headers, they'll turn brown again about 90 seconds after you start the engine. Save yourself a load of grief and just hose them down to get the worst of the dirt off
- Cousin Jack
- Has thanked: 2561 times
- Been thanked: 2292 times
Le_Fromage_Grande wrote: ↑Mon Jan 17, 2022 4:32 pmDid you use the yellow or the white?Cousin Jack wrote: ↑Mon Jan 17, 2022 2:11 pm Only from Weeksy..............!
Autosol (or something similar). impregnate some strong cloth tape with it, and wrap it around and saw it too and fro. Once upon a time I used to have a source of such tape, pre-impregnated with metal polish but I very much doubt it exists today.
Yellow, with white to finish. I think, it was a looooong time ago!
- Trinity765
- Has thanked: 2442 times
- Been thanked: 2398 times
Rounded up the bits I need to start on this job. Walked into Wemoto and the guy behind the counter knew what bike I had - I guess that's as close to feeling famous as I'm ever going to get
I need to remove the radiator first so that will get a good clean while I'm at it. I have some of this stuff coming GTG Condenser Cleaning Foam - has anyone used anything similar (for radiators, not headers ).
https://www.amazon.co.uk/gp/product/B09 ... UTF8&psc=1
- Has thanked: 2636 times
- Been thanked: 1523 times
I'd be very cautious using that on a radiator made from aluminium. Alkalis - which is what this is said to be - corrode exposed aluminium.Trinity765 wrote: ↑Sat Feb 05, 2022 10:17 am Rounded up the bits I need to start on this job. Walked into Wemoto and the guy behind the counter knew what bike I had - I guess that's as close to feeling famous as I'm ever going to get
Doesn't take more than a pinprick hole and the radiator's done for... I had a tiny salt corrosion hole on the Hornet's radiator a couple of years back... the first warning was a warm, wet boot on a hot summer's day.
- Trinity765
OK thanks - I'll hold back on it.The Spin Doctor wrote: ↑Sat Feb 05, 2022 10:27 amI'd be very cautious using that on a radiator made from aluminium. Alkalis - which is what this is said to be - corrode exposed aluminium.Trinity765 wrote: ↑Sat Feb 05, 2022 10:17 am Rounded up the bits I need to start on this job. Walked into Wemoto and the guy behind the counter knew what bike I had - I guess that's as close to feeling famous as I'm ever going to get
- Trinity765
This is why I like crochet.
2022-02-05_12-30-17 by Trinity 765, on Flickr
2022-02-05_12-41-53 by Trinity 765, on Flickr
- Has thanked: 4367 times
- Been thanked: 2856 times
- Trinity765
- Has thanked: 9848 times
- Been thanked: 10163 times
Get some stainless studs and nuts while you are in there.
I'd give those header nuts a good soaking too,before trying to loosen.
- Trinity765
They are soaking now
I picked up my Crème Brule torch when I popped home in case things get really tough.
I was just looking at those... they're worse than the ones on my 40 year old Honda.
- Has thanked: 2948 times
- Been thanked: 1884 times
Is that a submarine exhaust system?Trinity765 wrote: ↑Sat Feb 05, 2022 12:33 pm
- Trinity765
inewham wrote: ↑Sat Feb 05, 2022 3:26 pmIf they won't shift have a dessert!Trinity765 wrote: ↑Sat Feb 05, 2022 2:24 pm I picked up my Crème Brule torch when I popped home in case things get really tough.
- Trinity765
How would I get the studs out? The nuts are obvious - I can see those (not taken the headers off yet).
Put two nuts onto the stud and tighten them together using two spanners,then use the back nut to loosen the stud.Trinity765 wrote: ↑Sat Feb 05, 2022 4:00 pmHow would I get the studs out? The nuts are obvious - I can see those (not taken the headers off yet).
- Trinity765
Thanks.Skub wrote: ↑Sat Feb 05, 2022 4:10 pmPut two nuts onto the stud and tighten them together using two spanners,then use the back nut to loosen the stud.Trinity765 wrote: ↑Sat Feb 05, 2022 4:00 pmHow would I get the studs out? The nuts are obvious - I can see those (not taken the headers off yet).
- Has thanked: 7822 times
- Been thanked: 2532 times
If you get more than 3 out complete, ie not snapped, I'll be very impressed. Best of luck!Trinity765 wrote: ↑Sat Feb 05, 2022 4:00 pmHow would I get the studs out? The nuts are obvious - I can see those (not taken the headers off yet).
