I now think I've cracked it - the tiny voltage step up gadgets arrived and work superbly. Set to 6.8 volts and the whole setup works fine including with headlight / stop lamp activated. I'm now looking for an opportunity to use the other 2.....
They have a very sensitive continuously variable output - I was a bit concerned they would be a discrete set of steps.
These are the step-up units - they're only about an inch long: https://www.ebay.co.uk/itm/334237098344
6 volt indicator question
- Has thanked: 261 times
- Been thanked: 1265 times
Re: 6 volt indicator question
Yes I just bought a 3 amp version, for LED purposes and it’s about the size of a commemorative postage stamp!
Glad to hear you’re now flashing merrily.
