Re: Gsxr 1000 K9
Posted: Mon Nov 22, 2021 12:44 pm
I also used a nut and bolt to grab the bobbins tight. Then put head into a drill. The spinning sometimes frees the bobbins.
New discs time.
Motorbikes, Sportsbikes, Adventure bike, Supermotos, banter, chat, friends and whatever else you can imagine. KTM, Ducati, Aprilia, Suzuki, Yamaha, BMW, Moto Guzzi, Laverda
https://revtothelimit.co.uk/
Fair play to you, I know a lot of people, myself included, who have struggled using track pumps to seat MTB tyres!wull wrote: Sun Nov 21, 2021 9:46 pm ... I decided to try my track pump to see if I could inflate the tyre and pop the bead. I usually take my wheels to the garage to the machine after fitting the tyres without ever attempting my own pump and I can confirm that it works perfectly well.
Cheers for that. My brakes are good as new but can you recommend something to get rid of the headache?Yorick wrote: Mon Nov 22, 2021 12:44 pmI also used a nut and bolt to grab the bobbins tight. Then put head into a drill. The spinning sometimes frees the bobbins.
New discs time.
What pads did you use with your PFM discs? I've got PFMs on my Falco and the only pads I've used so far are Performance Friction 95 compound, but they're hellish expensive and difficult to get hold of in the UK. I tried some SBS Sinter RS and took them off after less than 100 miles as they were horribly grabby.KungFooBob wrote: Sun Nov 21, 2021 9:07 pm I warped the discs on my 98 Blade at Cadwell.
Swapped them for PFM Cast Iron jobbies, with a later 06+ Blade radial MC. I spent a lot on suspension and tuning on that bike, the discs were the modification that made the biggest difference.
Yeah, I was annoyed with myself for buying the sintered pads. I knew that they tend to wear the discs but bought them anyway. D'uh...KungFooBob wrote: Sat Nov 27, 2021 12:14 pm PFM say not to use sintered pads with them as they wear the discs out before the pads... except for Bendix ones (which were PFM's no.1 recommendation, but barely lasted a trackday). I ended up using Ferodo Platinum as they're organic and worked really well.
Don’t want to be a party pooper but not sure I would have that video online. That’s a court case and jail these days…l.
Mind the days of the imports with the 180kph limiters still in place, that’s what the K9 is likeKungFooBob wrote: Sat Dec 04, 2021 8:11 pm There's a video on youtube of someone very much like me doing an indicated 166mph on an R6, it's been there for almost 20 years and I aint done no porridge.
My L3 hit 187 on the Sat Nav at Bedford Aerodrome.wull wrote: Sat Dec 04, 2021 9:33 pmMind the days of the imports with the 180kph limiters still in place, that’s what the K9 is likeKungFooBob wrote: Sat Dec 04, 2021 8:11 pm There's a video on youtube of someone very much like me doing an indicated 166mph on an R6, it's been there for almost 20 years and I aint done no porridge.
