Winter Tweaks/Improvements for the Bike?
Been thanked: 4125 times
Re: Winter Tweaks/Improvements for the Bike?
Druid wrote: Fri Oct 01, 2021 8:09 pm Suspension upgrade for the Speed Triple, front forks are rather firm and don't like the agricultural roads up here. Might stretch to a new rear shock, or perhaps just a new spring and a service.
The GS750 is pissing petrol out of the connecting pipes between the carbs. New pipes are not available so I may have to find an alternative solution. Or I may leave it covered up at the back of the garage and ignore it some more
They're just bits of rubber pipe, fiddly to replace but not impossible.
Has it still got the original Mikuni slide carbs?
Has thanked: 2948 times
Been thanked: 1884 times
Drown the ZH2 in ACF-50, maybe insulate the bike garage.
It does not need the ECU flash with 40 more BHP peak and over 100 at the red line (throttle bodies start closing after 10K with the stock tune).
Has thanked: 2554 times
Been thanked: 6262 times
Hopefully get the Bonneville back and actually working :lol:.
Probably gonna flog the 5TA to my wife's Uncle.
The CBR doesn't need much. Well....it probably needs something doing in the carbs, new emulsion tubes by the sounds of it. However the worst that happens is that it hits a bit of a wall at 7k and part throttle so I can ride around that. Really not sure I can be arsed with stripping and rebuilding them.
I'm supposed to be starting restoration of my Speed Triple but a combination of too much effort going into the Bonneville and much more interesting things happening at work means I've not bothered yet.
Druid
Has thanked: 276 times
Been thanked: 900 times
Post by Druid »
Le_Fromage_Grande wrote: Sun Oct 03, 2021 9:49 am
It still has the Mikunis, but they're not just bits of pipe. They're rubber mouldings over metal pipes, the layer ones have metal pipes with O rings.
Druid wrote: Sun Oct 03, 2021 10:53 am
Didn't know that, I'll have to have a look at the 33mm Smoothbores I've got tucked away.
Could you make some?
Been thanked: 7544 times
Just bought these for the KRS...
Just about the cheapest I've seen them recently (I bought a set for £25 once).
I much prefer the R&G to the Oxfords. The controller is a bit low rent compared to the Oxfords, but they get much warmer and are much more reliable.
Has thanked: 2636 times
Been thanked: 1523 times
I might clean it... if it's lucky!
