Page 2 of 2
Re: budget digital vernier callipers ....
Posted: Mon Aug 23, 2021 4:29 pm
Count Steer wrote: Mon Aug 23, 2021 4:24 pm
Interesting. That's the same model that's reduced from £137 to £88 on Amazon. There are others that have been reduced but not that much.
A seller feedback score of only two,that may be a thing....
Posted: Mon Aug 23, 2021 5:18 pm
by cheb
It's been suggested on a couple of other forums I'm on, technical ones, that there's a lot of fake Mitotuyo out there, and very convincing fakes at that.
Whether it's true or makes a difference I don't know.
Posted: Mon Aug 23, 2021 6:13 pm
by MrLongbeard
Either nicked or knocks off's I reckon.
Posted: Mon Aug 23, 2021 6:34 pm
by Mr Moofo
MrLongbeard wrote: Mon Aug 23, 2021 6:13 pm
I was suspicious that I thought they were fake - the paperwork behind is in Chinese.
On the prior ones, and some of the others, it is in Japanese ...
Posted: Tue Aug 24, 2021 11:35 am
by Mr Moofo
they all fakes ...
I am beginning to learn how to spot them!
I don't need 90 quid ones ...
Posted: Tue Sep 28, 2021 4:38 pm
by Demannu
DIGITAL!!!!!!!!
FFS.
Do you need that level of accuracy or can't use proper ones?
Got a set of old school mituyo 'borrowed' from a now defunct engineering firm. Anything I do is only 2dp max so no need for owt fancy.
Found they go out of spec quickly when dropped off the machine beds several times!
Posted: Tue Sep 28, 2021 7:03 pm
by Mr Moofo
Demannu wrote: Tue Sep 28, 2021 4:38 pm
DIGITAL!!!!!!!!
FFS.
And I should also use a slide rule …
Posted: Tue Sep 28, 2021 8:23 pm
by Demannu
Question still stands, do you need that level of accuracy?
Posted: Tue Sep 28, 2021 8:42 pm
by Mussels
Demannu wrote: Tue Sep 28, 2021 8:23 pm
The question may be better as "do you need that level of precision?', I wouldn't expect digital ones to be any more accurate.
Posted: Wed Sep 29, 2021 9:32 am
by Mr Moofo
Absolutely not.
I am not a real engineer, you know!
Posted: Wed Sep 29, 2021 11:29 am
by iansoady
Ooh, I love a precision / accuracy debate!
Posted: Wed Sep 29, 2021 4:41 pm
by Demannu
accuracy as describing a combination of both types of observational error above (random and systematic), so high accuracy requires both high precision and high trueness.
Posted: Wed Sep 29, 2021 5:05 pm
When I served my time in the 70s we used all non digital measuring gear. As a result I'm at home using the old stuff,but I can see how a different generation will find it easier and quicker reading a screen,rather than using the older method.
Tech moves on and if the operator can work to the level of tolerance required,it doesn't really matter how he/she gets there.
There are good bargains to be had buying old Moore & Wright stuff,so that's a plus.
Posted: Wed Sep 29, 2021 9:01 pm
- 1632945279107.png (863.26 KiB) Viewed 466 times
Posted: Thu Sep 30, 2021 4:44 pm
by iansoady
I like it.....
Posted: Wed Oct 27, 2021 5:01 pm
by Ant
Have a look at Cromwell tools, they have some cheaper options which are very good. Personally out of all of my calipers, the dial indicator is my fave, but they do have a pair of Moore and Wright digitals for around £30.
