A seller feedback score of only two,that may be a thing....Count Steer wrote: Mon Aug 23, 2021 4:24 pm Interesting. That's the same model that's reduced from £137 to £88 on Amazon. There are others that have been reduced but not that much.
budget digital vernier callipers ....
Re: budget digital vernier callipers ....
- Been thanked: 2727 times
It's been suggested on a couple of other forums I'm on, technical ones, that there's a lot of fake Mitotuyo out there, and very convincing fakes at that.
Whether it's true or makes a difference I don't know.
- MrLongbeard
- Has thanked: 778 times
- Been thanked: 3216 times
Either nicked or knocks off's I reckon.Skub wrote: Mon Aug 23, 2021 4:00 pm £34 new on the bay?
https://www.ebay.co.uk/itm/174901528928 ... %3A2334524
- Has thanked: 1926 times
- Been thanked: 1728 times
I was suspicious that I thought they were fake - the paperwork behind is in Chinese.MrLongbeard wrote: Mon Aug 23, 2021 6:13 pmEither nicked or knocks off's I reckon.Skub wrote: Mon Aug 23, 2021 4:00 pm £34 new on the bay?
On the prior ones, and some of the others, it is in Japanese ...
they all fakes ...MrLongbeard wrote: Mon Aug 23, 2021 6:13 pmEither nicked or knocks off's I reckon.Skub wrote: Mon Aug 23, 2021 4:00 pm £34 new on the bay?
I am beginning to learn how to spot them!
I don't need 90 quid ones ...
Demannu
- Has thanked: 65 times
- Been thanked: 1234 times
DIGITAL!!!!!!!!
FFS.
Do you need that level of accuracy or can't use proper ones?
Got a set of old school mituyo 'borrowed' from a now defunct engineering firm. Anything I do is only 2dp max so no need for owt fancy.
Found they go out of spec quickly when dropped off the machine beds several times!
FFS.
And I should also use a slide rule …Demannu wrote: Tue Sep 28, 2021 4:38 pm DIGITAL!!!!!!!!
FFS.
Demannu
Question still stands, do you need that level of accuracy?
- Has thanked: 781 times
- Been thanked: 1072 times
The question may be better as "do you need that level of precision?', I wouldn't expect digital ones to be any more accurate.
Demannu
accuracy as describing a combination of both types of observational error above (random and systematic), so high accuracy requires both high precision and high trueness.
When I served my time in the 70s we used all non digital measuring gear. As a result I'm at home using the old stuff,but I can see how a different generation will find it easier and quicker reading a screen,rather than using the older method.
Tech moves on and if the operator can work to the level of tolerance required,it doesn't really matter how he/she gets there.
There are good bargains to be had buying old Moore & Wright stuff,so that's a plus.
- Has thanked: 12606 times
- Been thanked: 8536 times
Have a look at Cromwell tools, they have some cheaper options which are very good. Personally out of all of my calipers, the dial indicator is my fave, but they do have a pair of Moore and Wright digitals for around £30.
