2016 KTM690 What do I need to know!
SSR Suspension
Has thanked: 2 times
Been thanked: 67 times
Re: 2016 KTM690 What do I need to know!
Post by SSR Suspension »
The suspension is dreadful, even for a road bike (I had one for 4 months earlier this year). I fitted myself some K-Tech kit and made some small geometry adjustments for the owner and really enjoyed it as a commuter.
SSR Suspension wrote: Tue Oct 05, 2021 3:34 pm The suspension is dreadful, even for a road bike (I had one for 4 months earlier this year). I fitted myself some K-Tech kit and made some small geometry adjustments for the owner and really enjoyed it as a commuter.
Not convinced i agree with that personally. But i guess it depends on what your end-goal was and is.
Image25-03-2016 Rockingham trackday photographs by Steve Weeks, on Flickr
This was completely stock on this day.
However, i'm certainly interested to hear about what you fitted, how much and what geometry changes. I could certainly be tempted by a shock at the right money.
Supermofo wrote: Mon Oct 04, 2021 12:18 pm
weeksy wrote: Mon Oct 04, 2021 11:34 am
Supermofo wrote: Mon Oct 04, 2021 11:17 am Good job, inspite of fancying a change I still love my 690.
I might buy one today :)
For real? Do tell?
viewtopic.php?f=4&t=3874
SSR Suspension
The forks are a 20mm internal cartridge design, which are non adjustable externally unless you have the Duke R. I fitted a K-Tech fork piston kit to the stock 'R' WP forks, altered the airgap and sprung the bike firmer. The stock R forks have a narrow range of adjustment and are damped very sparsely.
The shock is also damped sparsely and has a progressive spring, so I fitted a bladder conversion to reduce the shock from overheating and increase feel, revalved the internals and fitted a linear spring.
The rear of the bike was raised to get better anti squat geometry (the owner sourced his own link arms) and the forks were dropped by 2mm to alter the front end geometry.
Geometry is part personal preference and part science depending upon your needs and what the bike needs to do.
Both variants are under sprung, with 6.0N front and 6.5N front for the 'R' spec, the rear being 70N and the sag numbers printed in the owners manuals are way off being correct!
Static sag in the front should be 25-30mm and 5-10mm in the rear, rider sags should be circa 38-42mm up front and 30-35mm in the rear with the correct rated springs.
Who knows within 6 months time I might even be working full time at WP in Austria in R&D, an opportunity presented itself so have applied to leave blighty! :-)
If you do not have an 'R the only options are Nitron fork carts/shock, otherwise the only option available for the non-R would be firmer linear shock springs with no fork springs being available off the shelf currently.
I'll be interested what Jody thinks when he rides his, I've found the front end fine on track. The rear gets a bit weavy at speed on dropping out of corners on the road but it's controlled so not a massive issue, but s shock deffo helps.
I'm currently waiting for my Nitron to sell from the XSR before jumping in on a shock for it.
Has thanked: 2317 times
Been thanked: 1821 times
Post by Jody »
Bike collected :)
As expected it's a bit tatty but it's a 20,000 mile KTM!
Dropped it off with my MOT guy and hopefully pick it up on Monday
Braaap Braaaaaaaap mudda truckers
Jody wrote: Sun Oct 10, 2021 7:14 am Bike collected :)
Yay. Get to KTM and get a 15t front.
Post by Jody »
weeksy wrote: Sun Oct 10, 2021 8:28 am
It's on the list mate along with.....
Handlebars, it's got some awful aftermarket ones on with shit looking risers
Axle sliders
Bar ends. I've not 100% decided yet, it currently has one missing, I have a brand new set of end caps I can fit for free, or I may go for the R+G ones ?
Brake pads, I need to check whats in there and how much they have left!
A good clean, not a weeksy clean, but cleaner than it currently is !
Then it's onto bolts, I have some stock of KTM ones so I'll see what how far I can get with those :)
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Post by Demannu »
On the bright side, when it goes bang, it'll fit in the back of my van for recovery :banana-wrench:
SSR Suspension
Also please note, I have assessed the suspension based on shock dyno forces not just riding the bike. No point giving you numbers as they won't mean anything, but there should be a key amount of damping force produced when the forks or shock are put thru very specific tests on a shock dyno and these which will change depending upon what springs are fitted, many OEM manufacturers get these numbers very wrong. Some Under damp, overs Over damp and sometimes they get it right!
Has thanked: 3644 times
Been thanked: 2502 times
Going on the other thread, drown the bike in WD40 before attempting to unscrew anything.
Post by Jody »
SSR Suspension wrote: Mon Oct 11, 2021 4:17 pm Also please note, I have assessed the suspension based on shock dyno forces not just riding the bike. No point giving you numbers as they won't mean anything, but there should be a key amount of damping force produced when the forks or shock are put thru very specific tests on a shock dyno and these which will change depending upon what springs are fitted, many OEM manufacturers get these numbers very wrong. Some Under damp, overs Over damp and sometimes they get it right!
One of my fork seals has a slight weap. As they need to come apart, how much are we looking at to uprate them?
