It's only a teeny bit pink: GSX-R1100N
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Re: It's only a teeny bit pink: GSX-R1100N
Post by Bigyin »
KungFooBob wrote: Sat Jul 03, 2021 9:23 pm Just checked the V5, 4 Weeksy clones.
The MOT history is even better
2006 .... 10,994 miles
2021 .... 12,668 miles
1674 miles in 15 years :mrgreen: :mrgreen:
Has thanked: 15949 times
Been thanked: 10243 times
Happy New Bike day!! Must admit I was going to run a book on what would happen first, you get this or DerektheBadger start his KX500!
Has thanked: 2550 times
Been thanked: 6244 times
I like the colour. So there.
The rest of the bike is a monstrous 90s barge. Colour is cool though.
Monstrous 90s barge sums up Slingshot GSXR1100s.
It is a very clean barge though.
Why are they called Slingshots anyway? Well before my time and I never bothered to find out...
Only thing I can think of is the shape of the frame?
Edit: Ha, apparently its the shape of the carbs. There are some very strong opinions on the matter out there :D
I think the genuine reason is Suzuki marketing, but it started with the 750s, when they went from the early shape to the curvy shape in 1988 Suzuki went from slide carbs to CV carbs, it was seen as a backward step by some people at the time (including me) so Suzuki said they had "slingshot" carbs that worked as well as the slide carbs.
Which brings about the question did they work as well or better than the slide carbs they replaced, top speed of a 1988 750 is about the same as a 1985 750, the CV carbs were easier to live with, the slides have better throttle response so long as you got it right, but if you got it wrong it bogged down.
Yeah I can imagine....the Bonnevile has slide carbs, slide carbs which are about as simple as they come. If you just crack the throttle you go nowhere, you have to feel your way up.
As someone who grew up with either EFI or "final generation" carb bikes it was a bit of an eye opener.
Been thanked: 7526 times
75 miles this afternoon, between thunderstorms.
Gear change is fine now I'm more used to it.
The chain is too tight, I need to do something about that.
The brakes are fine, had the wheel chirping hard braking for a 30 zone.
It'll hit an indicated 140mph in 4th before it hits the limiter.
The rear shock is way too soft, I looked am myself in a shop window and it looked like I was riding a chopper!
It handles fine, even on the superseded touring tyres they fitted... but I didn't get my knee down.
Got the tyres run in.
Chain slackened off a bit, it was like a bow string with me sat on the bike, the mechanic must have set it static without the suspension compressed. Much better now.
Checked the rear shock. There's 7 pre-load steps... it was on one. Put my c-spanner on it and couldn't get it to shift, needed more leverage....
Bit heath robinson, but it worked.
It's now set to 6. Because I'm a fat bastard. We'll see what difference it makes next time I go out.
I've also spotted that the fusebox has been relocated.
The red circles are where the fuse box should be and the blue is the fusebox. No idea why it's been moved.
Mr. Dazzle wrote: Sun Jul 04, 2021 3:43 pm Yeah I can imagine....the Bonnevile has slide carbs, slide carbs which are about as simple as they come. If you just crack the throttle you go nowhere, you have to feel your way up.
That's going to take some getting used to, you should try a big slide carb, my Husky had a 40mm DellOrto, it could be bloody horrible, or absolutely superb, depending on how awake you were.
The fuse box may have been moved so something could be stored under the seat
There's only 'Steady' spots left. It's the pinicle of 1992 Suzuki engineering, it belongs in fast!
Has thanked: 5450 times
Been thanked: 13085 times
KungFooBob wrote: Tue Jul 06, 2021 10:42 am There's only 'Steady' spots left. It's the pinicle of 1992 Suzuki engineering, it belongs in fast!
Who would ride it for you ?
How cruel!
Last year (or the year before) there was no difference between steady and inters, I started out in Inters and moved down to Steady, there was no difference in the pace.
Not that I'd want to ride that barge round Cadwell, but it'd be fun watching you do it.
If it had proper tyres on it instead of previous gen touring tyres I would be seriously tempted, but I think I've spend enough money this month.
If you'd ridden my K1200Rs you wouldn't call the GSXR a barge. It's funny they're parked next to each other in the garage and Big red is almost twice the size!
G.P
Has thanked: 2029 times
Been thanked: 1310 times
Post by G.P »
Very Noice indeed.
Must admit I'd struggle living with the paint scheme, that other one for sale at £7k is a much more saleable bike! :D
I'm getting used to the paint, it's very 90's. Which I like.
I spent an hour last night polishing it and putting some washers under the idiot light cover to stop it rattling, but now I've run out of jobs to do!
Next pay day I might buy a rear braided brake hose, and one from the front MC to the splitter (the two from the splitter to the calipers are already braided).
I'd quite like a proper carbon fibre yoke protector (like a fibre-lyte one from the 90's), I've noticed my boots mark up the heel plates too, some solvo fixed them, but if I could fine some CF ones I'd be really happy.
KungFooBob wrote: Tue Jul 06, 2021 11:34 am I'm getting used to the paint, it's very 90's. Which I like.
The colours and graphics are horrendously shell suit 90s. But it's a bike from 1992 so WTF else would you expect?! I don't really go in for the 'make it look moden' thing, why would buy a 90s bike and complain it's stupid 90s colours?
I'd draw the line at that though!
