Turntable
Re: Turntable
6mm steel plate tek screwed the Lazy Susan to the plate added a rope handle for ease of transport also handy to stand on and stop the plate spinning when putting the bike on the plate. Safe links
https://www.dropbox.com/s/dbrhcd7jomfdk ... 3.jpg?dl=0
https://www.dropbox.com/s/di5d3dtnaxyft ... 9.jpg?dl=0
- Has thanked: 6187 times
- Been thanked: 5087 times
Re: Turntable
Just thinking about my old K75/100s - you needed a hefty shove and hold on the seat to get the front wheel off the ground
Might be something for OP to consider?
Re: Turntable
See my post above dropbox links. Mate turns his FJR 1300 on it and Beancounter turns his Caponard and 1150Gs on it without any issues
Re: Turntable
The xmax is quite well balanced front to rear on the centre stand although with a slight (perhaps 5kg or so) bias to the front wheel.
Re: Turntable
Yes the idea is to keep it as low as possible or you will struggle to get the bike up on the stand
- Has thanked: 7814 times
- Been thanked: 2527 times
Re: Turntable
I've got one of them, it's useless unless the floor surface is utterly flat (think polished marble)Cousin Jack wrote: ↑Sat Jul 03, 2021 3:51 pm https://www.ebay.co.uk/itm/391969687426 ... dc417a6255
Not too far above your budget.
- the_priest
- Has thanked: 1874 times
- Been thanked: 2170 times
Re: Turntable
Makes it look so easy that. I like the cheerful thumbs up!
Re: Turntable
Man of your size could probably pick it up and turn it around no need for the turntable
the_priest wrote: ↑Wed Jul 07, 2021 10:31 am Makes it look so easy that. I like the cheerful thumbs up!
Re: Turntable
Well I've made one. Lazy susan from simply bearings and some 5mm ply from a local skip (2 rectangles glued together to make 10mm), and 4 1/4" BSCy nuts & bolts. It works very well although getting the bike onto it requires a fair bit of effort - it may be worth running the back wheel onto a suitable plant to make life easier. Or maybe Mk II will have aplate made of 5mm alloy.
The strips of gaffer tape are to help locate the centre stand feet.
- Has thanked: 1264 times
- Been thanked: 1188 times
Re: Turntable
I think he means just the turney bit, so both front and rear wheels are off the ground.
Think of it as as like se-saw, with a fixed centre.
But instead of uppey downey, it's roundey roundey.
If you made the top a long 'T' shape: _____!____ then could you leave the bike on the sidestand?
Re: Turntable
Does the board or the bearing go on the floor in your design? I assumed it was the bearing
Re: Turntable
If the strips of tape are to help locate the stand, they wouldn't be too helpful if facing down
Re: Turntable
Yes, the bearing faces down. I was going to add a plate but it seems quite stable as it is (300mm / 1ft diameter and flat) so won't bother.
The T shape would probably be an "advanced" design but actually I'm pretty happy with it as it is. Till I and the bike end up in an undignified heap.....
Oh, and when I say "locate" that's just visually although I was contemplating a length of 2x1 just in front of the centre point to act as a stop. But it doesn't seem to need it.
Re: Turntable
Would have worked well when you tried to ride away
