Pool upgrade
Has thanked: 1507 times
Been thanked: 1412 times
Re: Pool upgrade
The lazy buggers didn't show up on Friday either. Apparently they're going to show up Monday & be done by teatime.
The pool light has 10 screws & tabs to clamp the light fitting to the part in the pool wall. There's a 1/2in thick rubber gasket doohicky betweem that keeps the water out & the electricity in.
The two parts are held together by 10 small brass tabs secured by 1/2in 10-24 screws. The tabs & screws were completely seized together. Online search finds the brass tabs are $18 EACH, but I can find the screws for 22c each. Almost removed a thumb trying to separate the crews from the tabs.
Decided to give them on overnight soak in Kroil (what WD40 wants to be when it grows up, go buy some)
This morning it was a doddle to crack the screws loose & separate them by finger pressure.
Spiffy light bulb showed up along with new rubber gasket for the fitting yesterday.
Re: Pool upgrade
Six guys showed up with about 60 trowels between them. This is one of six similar buckets...
This is the sample they made on the spot before starting:
First coat
Re: Pool upgrade
Guy in the green shirt of the glass bead thrower...
Re: Pool upgrade
Re: Pool upgrade
Done by noon. I'll start filling it late tonight. Once it's full one guy comes back to put some acid in the water which removes the haze from the finish, that's why it looks dirty right now. (same principle as removing the haze from tile after you get done grouting). Then next mon or tues our regular pool guy comes over to adjust the Ph & turn on the pumps & filters etc.
Re: Pool upgrade
Pool filling started at 8.10pm.
9.15pm:
10.15pm:
Re: Pool upgrade
11.15pm.... & I'm off to my pit.
Has thanked: 836 times
Been thanked: 1238 times
Re: Pool upgrade
I thought all American's got pools filled with water delivered by a tanker, never quite understood why.
Re: Pool upgrade
Mussels wrote: Tue Jun 08, 2021 12:37 pm I thought all American's got pools filled with water delivered by a tanker, never quite understood why.
Depends on the local water company. Ours doesn't, but the next nearest one does & at bulk rates.... They won't deliver here even though they're only a couple of miles away..
If you use tankers you can fill a 50k gal pool in an hour.
This is where we're at after 10 hours..... & it's going to take all fucking day at this rate. It looks like it went up maybe 1ft between 3 & 6am
19in to go.
Re: Pool upgrade
I don't understand how it can be cheaper to deliver water in a tanker rather than through pipes already installed. Strange people.
Your water pressure is better than mine, it takes me all day to fill up my pool which is a fraction of the size of yours.
Re: Pool upgrade
Mussels wrote: Tue Jun 08, 2021 3:10 pm I don't understand how it can be cheaper to deliver water in a tanker rather than through pipes already installed. Strange people.
Domestic vs Bulk rates.
Pressure has dropped right off since last night now every bugger is up & taking a shower, plus early morning sprinkler systems. At my old place the water pressure was often around 140psi, kept the plumbers busy fixing pipes... Twice I rinsed a coffee mug under the tap & was left holding the handle with no mug attached..
Re: Pool upgrade
Current rate of fill puts it around 12.30-1pm to the full mark (plus the hot tub part)
Re: Pool upgrade
Well damn, I must have remembered some HS math. 12.30 estimate was pretty much right on the money, turned the water off at 12.32 Hot tub filled via the equalizer doodad, pool dude showed up & put 5 gallons of acid in the pool.
Even had a Blue Belly show up to check it out.
Has thanked: 5450 times
Been thanked: 13085 times
Re: Pool upgrade
Looks fabulous!!!
Re: Pool upgrade
Can't actually use it until some time next week. It's getting all new filter set up next week, but we'll run it with the old set up for a while to get all the snarge caught in the old filters, not the spiffy new set up.
Has thanked: 15949 times
Been thanked: 10243 times
Re: Pool upgrade
I didn't expect to enjoy this thread half as much as I did!
Has thanked: 1264 times
Been thanked: 1188 times
Re: Pool upgrade
Post by slowsider »
Taipan wrote: Wed Jun 09, 2021 12:45 pm I didn't expect to enjoy this thread half as much as I did!
Refreshing and yet relaxing, like having a pool prolly :mrgreen:
Re: Pool upgrade
Probably wouldn't have been so enjoyable if I'd posted all 120+ pics ;)
Re: Pool upgrade
Post by slowsider »
ZRX61 wrote: Wed Jun 09, 2021 3:55 pm
I was waiting for the video 8-)
asmethurst99
Has thanked: 1042 times
Been thanked: 362 times
Re: Pool upgrade
Post by asmethurst99 »
slowsider wrote: Wed Jun 09, 2021 2:43 pm
I thought the same thing too - My mate lives in Perth WA he posts on FB his hard work getting his pool up and running .
